Old December 13th, 2018, 10:43   #7141
Steve Addy
TDI(s): 97 Mk3
Originally Posted by ToddA1 View Post
The winter tires on the Rondos were subjective. 2 Blizzaks, were reaching the end of their treadlife. The Kellys had great tread left, but I was seeing cracking at the sidewalks. The tread blocks reminded me of old Army Jeep tires. These came with the B4V, so they’re at least 10 years old.
I probably could have gotten away with one more season, but I decided to get a new set. Winter Claw- Arctic Claw Winter XSi... some research said they were Coopers, made in China... marketed under many different names. I went to the store to look at them; they’re made in Europe, and bear the 3 peaked mountain with snowflake icon.
I decided to get a set. Going from 195/55/15 to 185/65/14 reduced the cost pretty dramatically. With instant rebates and discounts I ended up with a set for under $165 mounted and balanced. They’re still in the trunk of the Rotbox.
Trying to figure out what to do with the 3 Coopers, on the Sebrings. Tread still looks great, but Cooper discontinued the Weathermaster ST2, and after reading reviews I want a complete set again. Been searching for the past few nights to find a spare tire.
Interestingly enough, Cooper told me winter tires are made to order. The dealers place their orders in the spring, tires go into production, then they’re shipped out. No more winter tires are made, until the following year.
-Todd
Even if the sidewalls have some cracking, if it's not too bad I would still run them for the short amount of time that they're needed. In addition I would check the date code to see exactly how old they are but even in that case I have had 10 yo tires that are still ok.
If the cracking is minor then I see no reason not to use them. I know there are some people out there who are not comfortable doing that but sometimes I think there's a degree of paranoia with regard to tires even though I accept the fact that tire quality seems to be sliding some, at least with the lower priced tires.
I wouldn't toss the Cooper tires even though you now only have three, perhaps you can replace two of them with new model new next season?
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old December 13th, 2018, 19:20   #7142
ToddA1
Fuel Economy: Dismal
The Kellys are gone. I have tires behind the shed that I need to go through. Some are good and some are bad. Over the summer, I bought a set of tires for the wagon... I could have saved some money, if I’d thought to look. Long story short, I’m trying to clear some stuff out.
The new tires are still in the trunk, but I took a look at them this morning. These are made in the USA. The tire I was shown was the same brand and model, but a different size. Wasn’t expecting that.
No plans to get rid of the 3 Coopers, especially now. Last night, I was doing more searching. I don’t remember how I found it, but the Weathermaster appeared at Discount Tire Direct, as “call for inventory”. I tried searching this morning, before going to work, but I couldn’t find it again. It didn’t show on their site under brand, size, etc.
I called and they had 1 in stock. I got a 30% discount and ordered it. I probably have at least 4-5 hours into searching for this tire. I may have found the last one out there.
The Evolution replaced the Weathermaster, and it doesn’t come in 195/55/15. I originally thought I’d have to order a pair of another brand. The Blizzaks and Kellys worked fine, together. I was looking at Antares winter tires, before I chose the Artic Claws.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old January 4th, 2019, 07:55   #7143
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
Gave "the beast" a good wash and emulsified the salt on the under body.
I was recently educated that these car wash "salt buster" packages are simply soap and water.. the brine they use around our area sticks to the underside of our vehicles and soap and water won't touch it.. once the salt/brine gets warm and/or wet it is actually reactivated.
We do vehicle detailing along side graphics, etc and found a chemical which emulsifies the brine & salt.
While underneath the Passat this fall putting Fluid Film on my brake lines and other items I noticed the salt/brine took quite the toll under there.
Looking forward to seeing how this emulsifier works this spring.
'97 Passat: 319,XXX Miles, Malone Eco Tune, Bosio PP 502, FAT/KFC Mod, Ventectomy, DRL Kill, 1000 Mile Club x3 / Auto Trim DESIGN
97B4TDi is offline   Reply With Quote
Old January 6th, 2019, 00:14   #7144
abbeyinc
Fuel Economy: High 30s in town. High 40s on the highway.
vacuum hoses under the hood, oil change, wash.
'53 Bel-Air, all original
'96 B4 Sedan TDi RIP, '96 B4 happily re-homed,
'96 B4 Wagon new to the family in 2018.
'03 Dodge Diesel with some mild mods.
abbeyinc is offline   Reply With Quote
Old January 18th, 2019, 18:06   #7145
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
Tried to have my brake fluid changed but 3 out of the 4 bleeder screws were seized...
Guess I’m waiting until it needs a full brake job.
Old January 18th, 2019, 21:16   #7146
Steve Addy
TDI(s): 97 Mk3
Start soaking them down now every time you have a chance and maybe the next time you go to do the fluid change more than just the one will come.
Also, sometimes if you try and tighten every so slightly before loosening they will come free. I've had that work before too, but I've also had them break off just the same.
Steve
Old January 19th, 2019, 05:08   #7147
ToddA1
What Steve said. A little heat and wiggling the bleeder back and forth, also helps. If it breaks free, definitely more lube and wiggling, until it’s free. I always wire wheel the threads and apply anti seize. Be sure the bleeders are clear, and I always hose them out with brake clean, after bleeding. Don’t forget the caps.
Personally, I think fluid flushing is pretty important, especially if a vehicle sits. The Rotbox just had a front caliper replaced. Piston would come out, but wouldn’t release, causing pad dragging and burning. All seals and sliders were good. I couldn’t get it in, and I was cranking on the c-clamp.
PO replaced the calipers pads and rotors, but I’m unsure if the fluid was ever flushed, and I neglected to do it. I’ll be doing it very soon. I’m sure if I pull the piston, it’ll be rusted.
Just flushed the fluid, in a new to me GTI, and the reservoir had a layer of, what looked to be mud, inside.
-Todd
'97 B4: Stock
Rabbit build
Old January 19th, 2019, 18:09   #7148
ToddA1
Flushed the Rotbox’s brake and clutch system. It didn’t look terrible, but I remembered that I bled (didn’t flush) the system, when I replaced the rusted brake line, a few months back. Seeing light amber fluid go water clear, should help keep it on the road a bit longer.
-Todd
'97 B4: Stock
Rabbit build
Old January 19th, 2019, 18:42   #7149
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
I’ll start soaking the bleeders and work on freeing them up.
Old January 21st, 2019, 10:52   #7150
Steve Addy
TDI(s): 97 Mk3
Ditto on what Todd said about wire brush, if you can get in there and wire brush off the excess crust it'll make a clearer path for the lubricant to get in there and do its job.
I've even used a 1/4" drive impact on very low pressure, just enough power to tap against the bleeder but not enough to snap it off.
So what you're saying is you acquired another car? We're going to need some photos of that ASAP.
Steve
Old January 21st, 2019, 18:30   #7151
ToddA1
Yeah, 84 Rabbit GTI was acquired mid December. I’m back in the gas game... came up for sale locally, and I couldn’t resist being back in a Rabbit GTI. It’s the first VW, I ever owned, hence my screen name.
Seller called me the day we were meeting, and it left him stranded, lol. CV came loose from the drive cup. It’s 35 y/o, and barely molested... I bought it, without driving it. The next day, I spent several hours on my back, in the rain, trying to fix it. Drive cup needed to be replaced.
Pics from roughly 3 weeks ago.
Seems like I’ve been wrenching on it nonstop...
New drive cup and both axle seals
Removed the aftermarket alarm (that I was told was disconnected) because I couldn’t start the car, after I disconnected the battery.
Rehung the TT exhaust... murder to get apart
Rebuilt the shift linkage
Redid their A3 wiper motor swap
All of the windows were tinted... steamed it all off
Flattened the door panels
Fixed the blower motor issue and replaced the resistor pack
Installed bigger front brakes and flushed the brake fluid
Removed the Raceland coilovers and went back to a cup kit... my teeth were rattling out.
A lot more small stuff, that seems to take forever.
My big issue is I clean, blast then repaint everything, before reinstalling.
There’s some minor performance stuff done and the car is a blast to drive!
-Todd
'97 B4: Stock
Rabbit build
Old January 21st, 2019, 20:05   #7152
Steve Addy
TDI(s): 97 Mk3
-Todd
Wow, that's like a complete about face from where you were headed before. So what happens to the other stuff? You still moving ahead with the tdi Mk1? So much time put into the Mk1 tdi I'd hate to see it get shelved for very long.
That does look nice though and the non-molested part is key. I will buy neglected stuff but when it comes to molested vehicles they take a lot bigger discount.
Wish I could find something like that out this way, even a carcass in that condition would be nice. I've been thinking more recently about doing a Mk2 Golf 4dr tdi or even a Mk3 4dr Golf converted to TDI, but finding anything in this area that is worthy of working on it impossible.
Steve
Old January 22nd, 2019, 04:57   #7153
ToddA1
Well, I suppose I’m expecting the Rotbox to go back to the earth, sooner or later. Don’t remind me about the lack of progress on the project car... I’m not giving up on it, though. I drive about 7-7.5k, per year, so the lesser gas mileage won’t really be seen.
Unmolested cars show up from time to time; keep your eyes open, if truly looking.
Although unmolested, the car definitely needs work. Typical rot in the rear arches and pan, torn front seats, AC was removed and the car was rattle canned, 2 owners back.
The car came with replacement metal and about $600 worth of new parts, still in boxes. Used seat parts and Cabby AC brackets were purchased... still looking for 1 more cushion.
If/when I choose to sell it, I’ll get my money back.
-Todd
'97 B4: Stock
Rabbit build
Old January 25th, 2019, 18:34   #7154
Wagone
Cleaned out the snow screen in the intake air box. Pretty sure it had never been done before because I found a 1cm thick "pre-filter" made mostly of what looked like hood insulation material. (Might make a nice mouse nest for someone; free for postage.)
Wagone is offline   Reply With Quote
Old January 25th, 2019, 21:39   #7155
TDIL3dad
on my black 1996 Passat sedan - replaced the following:
1. Driver door window regulator / lifter (OEM from VAG via Harbour View VW in Vancouver, BC)
2. Driver door contact switch. (OEM from local VW dealer)
3. Driver seat "receiving end' of seat belt. (parts seller on Vortex)
4. Relay 36 buzzer relay. (OEM from local VW dealer but made in China)
5. Compressor. (OEM from local VW dealer)
6. Starter. (rebuilt OEM from local VW dealer).
Car sounds much quieter now without the rattle and whine of dying compressor. Starter did not want to work on a very cold night last week until I hit it with a wrench, and then it woke up, so it was time to replace. Items 2,3 & 4 seem to have fixed the sporadic flashing of the seat belt icon on the instrument cluster.
TDIL3dad is offline   Reply With Quote
Page generated in 0.21305 seconds with 10 queries
[Output: 136.14 Kb. compressed to 115.01 Kb. by saving 21.13 Kb. (15.52%)]
