Old February 2nd, 2011, 09:29   #16
fase2000TDI
Fuel Economy: 52, 45 38
I wish this video could have been done on a bench. I would not do this while on the car.
TDI service available - timing belts, clutch jobs, cv joint rebuilds, engine rebuilds, maintenance, low power diagnosis, suspension. DSG service $180 Have CAN VCDS for CR TDI's PM here, call or email JeremyTDI@yahoo.com (401)-919-0466 Quotes available, very fair rates
fase2000TDI is offline   Reply With Quote
Old February 2nd, 2011, 15:38   #17
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Way better off doing it in the car. The timing belt will hold the pump in the on cam position.
Perhaps you should actually watch the video.
runonbeer is offline   Reply With Quote
Old February 2nd, 2011, 16:04   #18
Losha
Losha's Avatar
Its better to do in the car if your are only replacing head and top seals, but if want to replace front seal or timing piston cover seals and bottom sensor (cant remember what its called right now), then you have to remove pump to do on bench.
VDUB Auto Repair www.vdubauto.com
Malone Tuning Dealer for SD, ND NE, IA, MN
'06 Jetta TDI DSG - Malone tune, Bilsteins B6, H&R Sport Springs, GLI front end, HID
Losha is offline   Reply With Quote
Old February 2nd, 2011, 18:40   #19
B100
B100's Avatar
TDI(s): 2003 Golf
I easily replaced the large O-ring on the driver's side while the pump was in the car, and this video was a large help with that. In addition to the fantastic writeup by DieselGeek.
2003 Golf 5-spd with ESP, DLC 1019 injectors, Koni Sports, CAT fuel filter, Panzer Plate, DieselGeek's bypass oil filter kit, Stage 4 Malone tune, South Bend SMF clutch, BV39 Turbo...
B100 is offline   Reply With Quote
Old June 7th, 2011, 21:58   #20
CopaMundial
It's sad to think about how many people go through their entire lives and never find an online resource as helpful as Fred's. To those poor lost souls the internet is nothing but porn, pop-up ads, and Aunt Rita's inane facebook messages.
This thread has motivated me to make another donation to TDIClub as a sign of my ever-increasing appreciation for community members who are so generous with their time and knowledge.
CopaMundial is offline   Reply With Quote
Old November 23rd, 2011, 21:33   #21
marc olivares
TDI(s): 03' jetta
fantastic tech... just finished mine.
if you're ever in the SLC, I owe you your body weight in beer
marc olivares is offline   Reply With Quote
Old November 27th, 2011, 12:39   #22
tommydee
I just did this job - one note !! DO NOT forget to tighten the nut for the fuel shutoff wire !! Dont ask how I found this out !!! I got in a hurry to finish and failed to tighten it fully - had it start fine and just die for no reason - until an hour later i figured out my mistake.
One other note - YOU REALLY need the mirror to make sure the o ring is seated on the bottom ...
Just my 2cents
2003 Jetta TDI Wagon GLS Leather Monsoon
tommydee is offline   Reply With Quote
Old November 27th, 2011, 16:02   #23
runonbeer
Tighten bolts/nuts. Good tip.
Old November 27th, 2011, 16:23   #24
whitedog
After playing with a junk pump on the bench and watching the video, I'm comfortable doing this if I ever need to. I used to be scared of it, but now, I'm confident I can do it right the first time. Thanks, Robby.
Old November 27th, 2011, 18:34   #25
ELM
I just did the IP seals on my 2002 beetle yesterday and it went great no more leaks and the video helped so much to watch it being done. Today I just finished the timing belt kit from Dieselgeek.
ELM is offline   Reply With Quote
Old November 27th, 2011, 18:51   #26
whitedog
Funny thing when I was looking at the videos. I noticed there were about 3-5000 views then there was another video listed about Cancun and it had over 2,000,000 views. I wonder if it had anything to do with the girls in the bikinis?
Old November 28th, 2011, 07:54   #27
runonbeer
I'm wearing a bikini in the video, you just can't tell.
Old November 28th, 2011, 07:55   #28
runonbeer
High five!
Old November 28th, 2011, 08:38   #29
jdross440
TDI(s): 2002 Jetta
I did mine Friday. Without the video I would have pulled the pump and taken to a rebuild shop. Saved me a bunch of money. Thanks for the excellent job. As a side note the fuel leaking down on the alternator took it out, so had to replace it also. Replace 90A with a 120A.
02 Jetta TDI automatic
jdross440 is offline   Reply With Quote
Old November 28th, 2011, 09:17   #30
runonbeer
High five!
Page generated in 0.15469 seconds with 10 queries
[Output: 122.53 Kb. compressed to 101.50 Kb. by saving 21.02 Kb. (17.16%)]
