How-To: Replace a MKIV ALH Diesel Injection Pump without Changing the Timing Belt
dgoldsmith
Olympia, WA
'06 Jetta sedan, "stick," with in-dash 6-CD changer, Sat., & AUX jack in glovebox that I'm no longer trying to figure out how to use, thanks to slamhouse! :-)))
Anyone happen to know how similar the procedure is for the B5 (i.e., '05 Passat wagon)? Or know of a relevant replacement how-to? Thanks!
rocketeer928
Enfield, Connecticut
2003 Jetta GLS TDI 5-speed
Anybody know the washers part no.?
I assume you mean the copper washers. They come with the re-manufactured or new IP. Alternatively, if you have the old washers then your best bet is to take them to an auto store (e.g., AutoZone, Pep Boys, Advanced Auto, etc.) and get replacements at the same size. I've done this several times for copper washers. You will not find copper washers at a home improvement store, though perhaps at a local hardware store.
rocketeer928
Please note that Posts 1 - 8 of this thread are copyrighted via a Creative Commons 3.0 BY-NC-SA license.
The PDF created by MrErlo at Post Nr. 24 will also be copyrighted. It was his wise suggestion to do this because about 50 people per month have been downloading it pretty consistently for the past year, and there are some document scraping sites that are starting to strip the PDF away from TDIClub, and from the Omaha Biofuels Coop servers where the PDF has been hosted.
archie
Canada
2002 Beetle
troublshooting 2001 1.9 TDI Jetta
I have a 2001 1.9 TDI Jetta in the garage. It died when the guy was driving. I have good fuel going in and out of pump. All timing marks are good, compression is very good. I have injection coming out of the injectors. My question is .......Can the hub on the injection pump have turn? ( The customer ran the car with gas for about 20km 1 month prior to this break down.)
Thank you
Archie :confused:
syntrix
Little Rock (was vegas), AR
05 Passat Wagon TDI - 03 NB TDI
Working on this slowly with a 500000+ 2001.
I can't get the timing belt off the injection pump sprocket (edit it's loose, belt is off , but cant clear the following:, the acc belt tensioner is in the way (yours is pictured). Figured I'd ask if it's a really tight fit before getting back into it tomorrow and pulling the acc belt tensioner.
Tensioner is all the way back. Everything is aligned and now un-pinned. Don't know what else to say. Oh, the belt is off the cam sprocket (marked some points before removing just in case), just can't clear it without it seeming like it would cause some stress on the timing belt.
edit: nevermind... wiggle wiggle wiggle with the belt still looped over the sprocket. yay
syntrix
I put paint marks on the timing belt and the cam pulley and the injection pump pulley, aka 1.8T style.
I was able to put the injector pump pulley on easily using the mark, with the cam locked, and then verifying the flywheel mark in the tranny. This helped since I didn't have to pull the cam sprocket.
However, I started to panic when a full rotation didn't align the marks, another rotation, no alignment... It appears that the timing belt is not static to the pulleys. I did about 6 rotations of the cam, then verified everything. It's all in check, but the paint marks are off by about 5-6 teeth for some reason....
Don't know why, but it's all in check after those rotations... very unlike the bazillion 1.8T jobs I have done. This is just a new project tdi that I traded for, so let's hope it's working as intended :)
eddie_1
Hannover, Germany formerly Toronto & NY
Jetta Wagon 2003 TDI tuned to 170HP, A6 Wagon 2008 TDI 2.7L tuned to 340HP
Exactly right. The pulleys (except for crank) have to be loose on their axes so they can do their thing (move back and forth) as the belt is tensioned, whilst the engine is locked down. That is essentially the heart of the tdi job.
TDIJetta99
Port Jervis, New York, USA
03... Faster than yours =]
with all that time you spent with painting marks and turning it over, you could have just popped the cam gear off and done it right LOL... Seriously it only takes 10 minutes to remove the valve cover and vacuum pump to put the cam lock tool in...
ymz
Between Toronto & Montreal
2003 Jetta TDI Wagon, 2003 Jetta TDI Wagon
Correction: it takes YOU 10 minutes to do the above... For some of us it takes about an hour and a half just to retrieve the tools from whatever "safe" place we put them the last time...
Cheers,
Yuri
TDIJetta99
I was going to say 5 minutes LOL... If you're removing an injection pump, you should already have your wenches and sockets available, and you shouldn't even think about touching a VW without a 5mm allen handy haha..
Ol'Rattler
PNA
2006 BRM Jetta
Great write-up. My only nit would be turning the engine over from the cam.
When you turn the engine in the direction of normal rotation from the cam, the turning force to turn the engine is bearing against the tensioner potentially damaging the tensioner and making the results from tensioning wrong.
Turning from the crank will give you more accurate timing with the lock tools and also more accurate tensioning because you are not putting forces on the tensioner it was not designed for.
rocketeer928
I agree with you, Ol'Rattler, and I learned that after I had written this procedure and performed the swap myself. Thanks for bringing that up.
arne487
Fort Collins, CO
'03 Golf TDI, '10 TDI Cup Jetta
Thanks for the writeup. I just used it three times in a row. At least the process got faster each time.
#1 - install 12mm pump
#2 - swap QA (and timing valve that can't be swapped while installed) with old pump because it won't start the car
#3 - put all the original parts back in because the car still wouldn't start
I guess I'll be sending my Frankenstein pump to Giles to work on the low pressure vane pump.
taugust
Austin, TX
2002 Jetta
It seems the link for the pdf is not working. Is there another source, or can someone send it to me? I need to dig into it today. Thanks
rocketeer928
Since the PDF link no longer works, just use the directions and pictures I outlined within this thread or use the myturbodiesel link. I did not create the pdf; someone else did.
edgewatertom
Edgewater, MD
2001 Jetta 5spd GLS; 2010 Jetta 6spd; 2003 Golf 2DR 5spd; 2016 GMC Canyon 2.8DuraMAX
The short story is the car starts, revs a bit higher than expected and immediately dies.
I just finished replacing the 10mm IP with a used 11mm IP on my 2001. I got the pump a while ago from a member on here. He said it was working fine when it was removed and I had no reason to think otherwise.
I am getting P1562 on the Scan Gauge.
I've tried my second key and get the same results.
I've searched for this scenario and have not been successful. Seems like every condition but this has been discussed...If it has please just point me in the right direction. I have a few days to troubleshoot before I put the 10mm back in.
Update: It's running!!! If I keep it above 1500 RPM it is smooth. Below 1500 it surges. If I take my foot off of the accelerator it will run by itself, sometimes a few minutes, sometimes it almost immediately shuts off.
I was able to run VCDS and got this
2 Faults Found:
17969 - Quantity Adjuster (N146)
P1561 - 35-10 - Control Deviation - Intermittent
17970 - Quantity Adjuster (N146)
P1562 - 35-00 - Upper Limit Reached
Readiness: 1 1 0 0 0
Thoughts on the surging? IP needs a rebuild?
UhOh
PNW
Sounds like the QA might be toasted. There's a thread that was recently resurrected not too long ago on fixing QA problems: what's great about it is that it's worked for a lot of people, people that would have otherwise had to resign to swapping out their IPs. The QA can get crudded up, metal particles are attracted to the QA bits (because of the magnetic field from the current that gets applied to it?).
runonbeer
Maintenance EnthusiastVendor
Austin, TX/Chapel Hill, NC
'00 Golf 02M, '10 Golf 02E, '02 UTE 02M
Look at MB019 key on engine off. report back.
You probably will have to pull the top cover off of that pump and mechanically free up the the QA. It is likely that the pump has been sitting a while and has become sticky.
Once you free up the QA, go drive it. Get it nice and hot. take it up to full load a few times then look at MB019 again after that.
May also try running a can of Lubro Moly Diesel Purge through it. I've free'd up stuck QA's with that stuff. Couldn't believe it actually worked.
cbman18j
Savannah
03 Jetta TDI (First Diesel)
Thanks for to this thread I was able to swap my none working 10mm pump to a 11mm pump with removing my timing belt. Just as an add I removed my idler roller that was between my camshaft pulley and IP to help facilitate IP removal and installation. Now what to do with my old IP?
edgewatertom
Edgewater, MD
Update to go with post 54 above. ^
I have a happy car again!!!
I took it out for a drive and must have unstuck all of the sticky parts. That was a fun drive. My apologies to Al Gore. I'd better go plant some trees.
Thanks guys.
