Old September 16th, 2006, 16:02   #1
PDJetta
PDJetta's Avatar
Default Recommendation for a Good TDI Mechanic in Dallas/Ft. Worth Tx. Area?
My mother needs to have the timing belt replaced on her 2000 Jetta TDI and is in Cleburne, Tx, which is about 75 miles southwest of the Dallas Ft. Worth Texas area. Does anyone have suggestions for a good mechanic or dealership that can do this and replace all the one-time use items/fastners that need to be done with this job?
Thanks.
--Nate
Old September 16th, 2006, 16:47   #2
paramedick
paramedick's Avatar
If you can get the car to Austin, runonbeer is one of the best in the country.
Old September 18th, 2006, 01:12   #3
TornadoRed
TornadoRed's Avatar
www.runonbeer.com
There have been a number of threads regarding DFW dealerships. Some are terrible, others merely mediocre. Even if you found a good one, it would cost much more than if your mom takes a drive down to Austin.
'03 Golf with 800k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat fuel filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, Delvac1
Become a TDI Club Contributor. http://forums.tdiclub.com/payments.php
TornadoRed is online now   Reply With Quote
Old September 18th, 2006, 06:13   #4
PDJetta
PDJetta's Avatar
Thanks Paramedick and TornadoRed. I'll pass this along to my mom and try to convince her to go to Austin.
--Nate
Old September 18th, 2006, 08:59   #5
TornadoRed
TornadoRed's Avatar
--Nate
It's a once-every-100k-mile thing. I'm not suggesting she drive half-way across Texas to get an oil change, or anything like that.
Old September 18th, 2006, 14:15   #6
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
If she is an hour SW of DFW, she is already 1/3 of the way to Austin....
runonbeer
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old September 18th, 2006, 18:24   #7
spoilsport
Default drive to austin!
It's only 2 hours 43 minutes, according to Yahoo! Maps.
This is a no-brainer.
spoilsport is offline   Reply With Quote
Page generated in 0.15051 seconds with 10 queries
[Output: 78.32 Kb. compressed to 67.44 Kb. by saving 10.88 Kb. (13.89%)]
