Old January 22nd, 2019, 21:45   #196
ratkc135
ratkc135's Avatar
From my research: am I correct in that if I donít have any codes my GPs and harness are working normally? It was 5 degrees a couple days ago and it took 5-7 seconds of cranking engine to start. So Iím gonna try this GP trick and see if that helps. Otherwise could be a starter and/or battery issue. I noticed this earlier this winter and assumed battery. OíReillys tested battery and alternator and both checked ok. So I just want to confirm the car would tell me if any GPs failed and/or if the harness is bad (I have a spare harness and set of plugs).
If this trick doesnít help perhaps itís my starter...
I have a 2002 with 179K miles.
Rat
2002 Jetta TDI GLS - White
2013 Passat TDI - SOLD Back to VW
ratkc135 is online now   Reply With Quote
Old January 27th, 2019, 16:54   #197
ratkc135
ratkc135's Avatar
So is 9.95s the maximum it uses? My coolant was -15.3C and no matter what value I used it never changed from 9.95.
Rat
Old January 27th, 2019, 17:06   #198
ratkc135
ratkc135's Avatar
Per a previous post: anything above 32768 decreases glow time....Iím going with that and left it at 32768. I guess since itís so cold I canít confirm if changes in adaptation is actually doing anything?
Rat
Old February 1st, 2019, 16:02   #199
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
I had an A3 so not certain if the A4s operate the same, but the ECU in my A3 would monitor GPs 1-2 and 3-4 to look for a difference between the pairs to trip the glow plug code. So if both pairs are bad but read the same to the ECU it won't trip the code.
I'd suggest testing for continuity on each glow plug by removing the harness. I would then test for 12v at each plug on the harness with the key on.
Additionally you could remove each glow plug and put 12v direct to them as a test, each glow plug should get bright red the entire length of the plug within 10 seconds of being energized.
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old February 1st, 2019, 16:03   #200
greenskeeper
Fuel Economy: 53mpg
lower adaptation number increases glow time
Old February 3rd, 2019, 00:46   #201
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57 mpg driving like a granny on HWY-5 from LA to SF
suscribed
1/4 mile run----13.98 sec. @ 105.37 mph 8 years ago
I dynoed at 275HP at LCD back then, now 2.0 TDI with the real bolt ons, HP and TQ who knows???
MAXRPM is offline   Reply With Quote
Old February 3rd, 2019, 06:17   #202
2005passatsteve
My jetta has 440,000km. Cranks great normal but in -15 or lower it is slow (diesel needs 600rpm approx min). I put a new starter on for $220. Night and day!!! Even at -29C it cranked over so fast! It started in only a few revolutions.
Because i am PD and my highest adaptation for some reason is 30,000 (and it is less GP time than the original 00000 value), i added a manual push button in my dash. I soldered 4 wires (trailer wiring) to each wire under hood just before it goes to the plugs. I soldered that to a main thick wire and ran it to the button. I fed the power to the button from one of the strip fuses on the battery. I tested it with a volt meter, and its awesome. Only snag is that the system is programmed to be full to the plugs, then immediately drop to 5v, so my button with 12v is scary - jusy 2-3sec max maybe.
2005passatsteve is offline   Reply With Quote
Old February 4th, 2019, 09:10   #203
djrhetoric
Wrong. More like ~300 before fuel is injected. But that might even be an old wives tale at this point based on what year you have.
djrhetoric is offline   Reply With Quote
Old February 4th, 2019, 14:33   #204
2005passatsteve
Great job! I was always told minimum rpm to start a diesel ignition process was 600rpm (from a diesel pump repair facility) back in the old 1980's years. Reviewing your reply, i dug up the specs of "150-250" to ignite with heat of compression of air and the injected fuel into that heated zone. Man, even 300 sounds really really slow. I will put tach tape on my balancer and see what i get one day. I know for a fact that i LOVE my new starter!
Old February 4th, 2019, 14:46   #205
TornadoRed
TornadoRed's Avatar
I've read 300 rpm here at TDI Club, and I've read 275 rpm. Whichever it is, anything lower results in fuel not being injected. Obviously the faster it cranks the more likely the engine is to start.
'03 Golf with 745k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, TDT or Delvac1
Like TDI Club? Got PayPal? Got $1 or $5 or $10? Contribution link on the main page.
Old February 4th, 2019, 16:57   #206
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
Fuel Economy: 57/43/32
I though 250 cranking RPM was the cutoff for no fuel injection, but I may be confusing that number with my 2003 sprinter.
As far as extending glow period goes, I don't really see the point, I've started my Jetta at -30F at high elevation and I've never messed with the glow duration. If you feel you need to do this you have something else that needs to be fixed, not the glow duration.
$.02
Hp vs. TQ
jackbombay is offline   Reply With Quote
Old February 5th, 2019, 05:54   #207
2005passatsteve
Something else wrong: yes! My car (jetta+passat PD's) used to start awesome, even in timmins. Then i did the stupid glow plug recall because ceramics were breaking off inside. They changed the voltage to the new s.steel ones. Then nobody's car would start, and they recalled the recall! My passat was hooked up for a full day directly to VW tech from the dealer and they couldnt get it to program. They were at the point of replacing the ecu (wish we did). My thoughts were, looking at Diesel Gate, was this was very first sign of "reverting back mode" but nobody understood what they were seeing. Anyway, it was not a good recall for me!
PD engine Glow Plug - extend time?? Diesel Mania_26 TDI 101 3 January 27th, 2014 18:54
Glow time TDIDSG4ME VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 January 9th, 2012 18:40
Anyone in Guelph with a Vagcom and want to extend GP time? timmyd Ontario 20 November 5th, 2006 20:15
VAG-COM, Control of glow plug ON time? canbluegolf OBD Scanners 5 October 18th, 2003 02:05
Glow Plug "glow time" of ca. 1.5 sec at 32deg F Dale Wehrle VW MKIV-A4 TDIs (VE and PD) 14 October 30th, 2001 01:51
Page generated in 0.16527 seconds with 11 queries
[Output: 114.84 Kb. compressed to 97.38 Kb. by saving 17.46 Kb. (15.21%)]
