Old November 22nd, 2005, 12:42   #1
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
Default How To extend glow time with Vag-com - ALH
First and foremost....Big thanks to member Fred (samfisher) who did the experimenting to find this info out. This mod will help a lot of folks with cold start problems who cannot rectify them with a timing adjustment.
Now as we all now, some cars have a difficult time starting when it is just above the freezing mark. This is due to the fact the glow plugs do not come on if the temps are above 9*C or 48*F (or somewhere around there). Any warmer and the ambient temp is usually ok to start fine and any colder than that and the plugs will glow to asist with starting. Of course there is a margin of error a few degrees either way. Also, atmoshperic pressure will affect your glow time too. The higher the pressure, the shorter the glow time. Thats why people at higher elevations will have a longer glow time, even above 9*C.
So in order to extend the glow time, you simply have to log into the engine module and make an adaptation change in group 12.
Here are the directions:
1) Turn on ignition
2) Go to engine controler
3) Log in using 12233 as the code
4) Click on Adaptation and go to group 12.
5) Change adaptation number from 32768 (default) to somewhere around 32700
6) Click test, then save the new value.
7) Close controler
8) Turn off ignition and turn back on again.
9) Go to the engine controler & log in again.
10) Go to adaptation block 12 and you should see a change in the second window. This value is the amount of time in seconds that the glow plugs will be active.
Note, you must do this with a cold engine to be able to see the results of your adaptation. You can do the adaptation at any time, but won't notice anything till the engine temp is cold. Also, the new glow time will not appear in the second window (no units) after you do the adaptaion. You must turn the ignition off & on and re-log in to the engine controler to see the results of the adaptation.
I did some experimenting at different temps and this is what I found:
Engine coolant temp was at 7.2*C
Normal glow time is 1.01 seconds
I then changed the adaptation value to 32700 (same ECT)
Glow duration is now 2.88 seconds
And finally, I changed the adaptation to 32650
Glow time was 6.61 seconds:
Now, in my opinion, this last adaptation seting is too much. We only need a few seconds of glow as these plugs get hot very quickly. If you adapt it to this setting, you may prematurely burn out your plugs? Now having said that, everyones car is different and you may have more or less glow time than me at that setting & temp. You will have to adjust it according to your own cars needs. I would recommend setting it to 32700 first and see if your car starts ok and then leave it. If not, and you need a litle more glow time, adjust accordingly. I also have to mention, that this adaptation was done on an ALH engine. I have not tried it on a 1Z(pre 99.5) or BEW PD engine. Hopefully others will experiment and post their results.
For reference, here are some screen shots I took at 13.5*C
Stock setting - no glow
And with an adaptation setting of 32650
glow time is 2.57 seconds
So basically, what you need to do, is find out at what temperature your car has a hard time starting and adjust the glow time according to that temperature. Around 3 seconds is all you need, so if you have a hard time starting the car at 13.5*C (56*F), then set the adaptation to around 32650. If you car starts fine at that temp, but has a hard time around 7*C (45*F), then set the adaptation value to around 32700. Again, this is only my own car and yours may differ slightly. I am also very close to sea level, so if you are higher than sea level, your values may differ also...this is just a guideline.
I hope this helps out all of you who have cold starting issues. But also be aware that glow time is not the only thing to affect cold starts. Do not do this mod to mask another underlying problem. Poor injection timing (mechanical) will also affect cold starts and you should check & adjust that as well before trying this adjustment.
Good luck to all and thanks again to samfisher for the legwork on finding this info out.
Disclaimer: Even though i did this to my car, you are doing it to your car at your own risk. If you blow glow plugs at a high rate, you are your own warranty. This is for informational purposes only
Moving? Need boxes?
Go green and check out FROGBOX.com
Old Ride (2000 Black Sedan): Gone
New Ride: (2003 Silver Wagon): Malone Tuned, T4 injectors, 11mm pump, 2.5" Magnaflow cat back, PD150 intake, OMI, Wingnut SS, ERF 6 speed, Bilstein TC Sport susp. w/GTI springs, Neuspeed RSB, Santa Monica's, Autometer Cobalt Boost & EGT, MFA Sport cluster, GLI Leather seats, SS vacuum lines, AVIC Z3 Nav and I still get 4.5L/100km (I got 3.9L/100k on a tank once)
Some handy 'How to's'
Wingnut is offline   Reply With Quote
Old November 22nd, 2005, 14:16   #2
veryhumid
TDI(s): 2006 Jetta
awesome write-up! i'll see how my car does when things get colder.
veryhumid is offline   Reply With Quote
Old November 22nd, 2005, 14:59   #3
BrianM
Fuel Economy: 56max/47avg/42min
LOL!!! I wanted to see what effect altitude had... (I don't have the ability to take screenshots on my VAGcom laptop right now ~ fixed)
Standard setting, 65*C, 5.36 seconds of GP time. I upped the adaptation # to 32800 and it dropped to 5.31 seconds.
Since my car has done 4~6 8+ second GP burns every day for 8 months, I doubt that a 6~7 sec burn will have any issue for most people. I'm going to fuss with this though and see how short of a GP burn I can get away with at altitude. Thanks to Wingnut AND SamFischer for the information.
Edited to add an image ~ I got Paint loaded back onto my laptop without having to reboot.
BrianM is offline   Reply With Quote
Old November 22nd, 2005, 15:40   #4
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
COOL!!! Now I don't need to double plug anymore!!! THANKS!!!
I'm doing this right now!!!
EDIT Done! Engine was too hot to see anything right now, can check tomorow. Oh, and Wingnut, your engine comptuer certinally has an interesting part description
-J
Present:
2018 Tesla Model 3 DM. 17,000 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 28,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old November 22nd, 2005, 17:03   #5
JETaah
Fuel Economy: 53 max, 42 min, average 46
Take a bow guys!!!!
this is terrific news in Michigan.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old November 22nd, 2005, 17:07   #6
dieseldorf
top post dawg
dieseldorf's Avatar
Thumbs up
I'm luvin' it! Excellent job once again, Wingnut, for another
Wingnut exclusiv !!!!!!!!!!!
C&D magazine on the DSG:
Old November 23rd, 2005, 07:25   #7
Wingnut
Wingnut's Avatar
Wow, thats a long glow time at such a high temp. Good to know the plugs will be ok at that duration. I knew altitude extended the glow time, but I had no idea it was that dramatic. Thanks for the info.
Moving? Need boxes?
Old November 23rd, 2005, 10:38   #8
compu_85
Gadget Guy
compu_85's Avatar
Remember the plugs run continuously below 2400 rmp (or whatever the cutoff it, it's right around there) until the engine starts to warm up. That is usually a couple of minutes on my car, so a few extra seconds of preglow shouldn't hurt anything IMHO.
-J
Old November 23rd, 2005, 10:42   #9
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
Damn, you got there before me...
Yup, if you look at any of the tech info on these modern Bosch g/ps, you'll find that they have two elements, the one at the tip as a heater, plus a longer coil farther along the body which acts as a current limiter. This and clever selection of element wire alloy results in a fast heatup and a low-enough steady state temperature that they can be energised damn-near endlessly.
DPM is offline   Reply With Quote
Old November 23rd, 2005, 11:25   #10
compu_85
Gadget Guy
compu_85's Avatar
On my car:
I settled on this last setting.
-J
Present:
Past:
Old November 23rd, 2005, 19:27   #11
P-car
TDI(s): 2000 Jetta
Fuel Economy: 42 to 47 mpg
Thanks for the info. I have been wanting to extend my glow time for a while now. I had a 4 sec glow at 0degs. Now I have a 9 sec. glow at 0degs.
Thanks again
Dean
Dean
2010 Jetta Sport Wagon "Time Bomb" Gone
2000 Jetta TDI Silver/Black
P-car is offline   Reply With Quote
Old November 26th, 2005, 15:22   #12
dieseldorf
top post dawg
dieseldorf's Avatar
This will be a distinct benefit to those with hi mileage GPs....Remember: they get much weaker before they fail.
Bumping up the cold glow period should be a real benefit to those in cold climates!
Junk:
New:
Old November 27th, 2005, 06:25   #13
mtltdi
mtltdi's Avatar
Fuel Economy: 63.21/46.88/30.25
Thumbs up
damn! That looks like a little lightsaber. hehe
Great info, to be saved to my harddrive immediately.
My Page
mtltdi is offline   Reply With Quote
Old November 30th, 2005, 03:26   #14
rotarykid
rotarykid's Avatar
Fuel Economy: 64 .1city @ 30-60 mph/ 52-53 @ 70-85 mph hyway ( 52 to just under 60 normal around town)on LSD
Talking
Verry Kool , I'm going to have to add this to my favs.
rotarykid is offline   Reply With Quote
Old November 30th, 2005, 04:35   #15
Variant TDI
Fuel Economy: 36.4min/44average/56.4max. Recently improved commuting from 42mpg to 50mpg with 'new' driving habits and Scangauge.
I'm curious... Do the glowplugs shut off after the glowplug light goes out? Or is the Glow plug light just an idiot timer to ask you not to start the car until the light turns off?
I guess my question is... Can't you just wait a few extra seconds to start the car?
The plugs are supposed to be on durring periods when the engine running, but still cold. Do they shut off, just to turn back on again?
--Tim (member: 900 Club... x4, best: 56.4mpg)
2002 Golf Wagon TDI - - 2007 Subaru WRX -
Variant TDI is offline   Reply With Quote
PD engine Glow Plug - extend time?? Diesel Mania_26 TDI 101 3 January 27th, 2014 18:54
Glow time TDIDSG4ME VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 January 9th, 2012 18:40
Anyone in Guelph with a Vagcom and want to extend GP time? timmyd Ontario 20 November 5th, 2006 20:15
VAG-COM, Control of glow plug ON time? canbluegolf OBD Scanners 5 October 18th, 2003 02:05
Glow Plug "glow time" of ca. 1.5 sec at 32deg F Dale Wehrle VW MKIV-A4 TDIs (VE and PD) 14 October 30th, 2001 01:51
Page generated in 0.35714 seconds with 11 queries
[Output: 142.30 Kb. compressed to 119.89 Kb. by saving 22.41 Kb. (15.75%)]
