Old January 18th, 2019, 16:43   #1
Yourbuddysatin
Default Mk6 Jetta headlights
Has anyone upgraded their headlights on the mk6 Jetta? The factory beams suck so Iíd like better lighting. Was looking into led or HID but there isnít very much info on this upgrade. Any info will help!
Yourbuddysatin is online now   Reply With Quote
Old January 19th, 2019, 16:01   #2
Yourbuddysatin
No one at all? Some one had to of done some sort of upgrade. Maybe even all new headlights?
Old January 19th, 2019, 17:23   #3
tomo366
TDI Lifer
tomo366's Avatar
I love the Headlights on my 2015 Jetta HiDS
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old January 19th, 2019, 19:34   #4
Yourbuddysatin
Is it factory HIDs?
Old January 19th, 2019, 19:50   #5
tomo366
TDI Lifer
tomo366's Avatar
Originally Posted by Yourbuddysatin View Post
Is it factory HIDs?
Yes it has the Lighting and Drivers Assistance Package was a 1400 option included the Lighting Package and blind spot monitoring Front and rear collision avoidance....pretty rare because of the expense and even more rare on Stick shift cars
Old January 19th, 2019, 20:16   #6
Yourbuddysatin
Are the swappable to a plain Jane Jetta do you know?
Old January 19th, 2019, 20:20   #7
tomo366
TDI Lifer
tomo366's Avatar
Do not know probably a huge hassle
Old January 19th, 2019, 20:56   #8
Yourbuddysatin
I’m new to the mk6 so I have a lot of research and learning to do. I’m so use to mk4 just changing whatever you wanted out most of the time. Guess I’ll just do more searching to see what I can come up with. Thanks for the input tomo366.
Old January 23rd, 2019, 19:30   #9
CTD_Chevrolet
CTD_Chevrolet's Avatar
Fuel Economy: 2015:46 Highway 26 City - 2002: 42 Highway 28 City
You can swap the factory HIDs in, but from what I've run across it's a ton of work, and they are really expensive.
You can google 'hid projector retrofit' (there are also several threads on the forums here), which is another option.
I'm with you on the stock lights absolutely sucking. I'm finally getting around to doing the retrofit on this car this week. I've hit a couple snags but these housings are enormous compared to the mk4 and it's been a pretty straightforward process.
'15 Jetta S DSG - New old stock, 30% tint, 1 sticker
'02 Jetta 5 spd - 17/22, Race 520s, 11mm pump, ARP studs, 3" straight pipe, SBC Stage 2 Endurance w/secret sauce plate and 14lb SMF, Kerma Tuning, tons of stickers
'95 Chevy K2500 Brodozer - P Pump Cummins, NV4500, Dana 60, most stickers
CTD_Chevrolet is offline   Reply With Quote
Old January 23rd, 2019, 21:26   #10
Yourbuddysatin
CTD_Checrolet are they big enough to withstand heat from leds running? I had led in my mk4 and never had a problem so maybe I should just drop in leds.
Old January 23rd, 2019, 21:54   #11
CTD_Chevrolet
I'd assume so if that's the route you wanted to go. The housing is probably twice the volume of the mk4 housing. There's also way more clearance between the back of the bowl and the back of the housing
Old January 24th, 2019, 05:51   #12
Yourbuddysatin
I’ve been meaning to get under the hood and look but as usual I’m either tied with something else or too lazy. A few things I read online said there is a major heat problem since led are so hot when running. I would think if my mk4 didn’t have a problem why would this mk6. Thanks for the input!!!
New oem hid/led headlights, kuftec auto leveling and wire kit, highline bcm mk6 jetta Herationkane Private TDI Items for Sale/Wanted 12 April 17th, 2018 06:56
MK6 Jetta Aftermarket High Quality Headlights MikeyDoubleDEE Private TDI Items for Sale/Wanted 2 December 21st, 2016 13:26
FS: RNS-510 w/ June 2015 Maps, OEM Mk6 LED tails, Mk6 bixenon headlights, fog lights pillpusher84 Private TDI Items for Sale/Wanted 16 September 7th, 2016 16:39
FS: mk6 jetta headlights pdt165 Private TDI Items for Sale/Wanted 0 July 4th, 2015 10:49
Fs: Oem mk6 jetta bi-xenon headlights CLETDI Private TDI Items for Sale/Wanted 0 February 2nd, 2015 19:03
Page generated in 0.14292 seconds with 13 queries
[Output: 106.42 Kb. compressed to 89.30 Kb. by saving 17.12 Kb. (16.09%)]
