Old January 21st, 2019, 18:56   #1
bigb
Default Charge Air Cooler Water Radiator EA288
If I am correct the water radiator for the CAC is located in front of the main radiator but I am confused if the CAC radiator is connected to the engine cooling system or not and shares coolant, and if not what is in it? Is it sealed for life, no maintenance needed? Looking at the diagrams it looks like it might be totally independent but can't tell for sure.
bigb is offline   Reply With Quote
Old January 21st, 2019, 19:00   #2
kdawg89
http://pics3.tdiclub.com/data/517/820433_EA288.pdf
Everything you could want to know is in this document
15 Golf TDI SEL DSG, Kerma TDI Tunes
Sold:06 Jetta, Darkside GTB1749V turbo, stage 4 malone tuning, 3 bar map, EGR delete, ASV deleted, buzzken catless downpipe, IDParts billet cam
kdawg89 is offline   Reply With Quote
Old January 21st, 2019, 19:07   #3
bigb
I actually have that doc but couldn't find the info in the CAC section but just as the email came in announcing your reply I happened to find it in the regular cooling system section....
Old January 22nd, 2019, 07:06   #4
740GLE
Amazing that VW media actually put this document together with such detail yet screws up so much other information they put out to the public.
Old January 25th, 2019, 16:25   #5
adjat84th
adjat84th's Avatar
Fuel Economy: ~50 in mixed driving
The circuit is separate. There's a one-way valve that allows coolant to only enter the circuit if it's low. There are two different versions of the radiator, a hot climate and normal. Dimensions are 5mm wider and 11mm more depth on the hot climate vs normal.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
adjat84th is offline   Reply With Quote
Old January 25th, 2019, 16:39   #6
750HMF
Not sure if the mk7 plumbing is the same as my 2015 passat or not, but if I plug my car in (canadian model) for a few hours, my charge air cooler is just as warm as the head, so the 2 cooling circuits must be joined someplace else other than the one way valve, otherwise it wouldn't warm up from the circulating coolant heater.
Sent from my SM-G960W using Tapatalk
750HMF is online now   Reply With Quote
Old January 25th, 2019, 16:56   #7
bigb
Thanks, when you say two versions are you referring to the engine coolant radiator or the CAC cooler? My car is hot country on the build sheet.
Old January 25th, 2019, 16:58   #8
adjat84th
adjat84th's Avatar
There are two different versions of each radiator, yes
Sent from my Pixel 2 using Tapatalk
2015 TDI EA288 Water Intercooler/2nd Radiator ZippyTDI VW Passat Family (NMS and B7) TDIs (2012+) 16 February 13th, 2015 10:38
1JO 121 467A air guide for charge air cooler jaredaggie TDI 101 2 November 27th, 2011 07:55
Oil leak from charge air cooler? corpsman VW MKV-A5 Golf/Jettas 7 April 7th, 2011 05:12
charge air cooler sensor plug ed1380 VW MKIV-A4 TDIs (VE and PD) 3 January 2nd, 2010 14:29
Air - Water charge cooling. rake TDI Power Enhancements 12 September 19th, 2007 09:39
Page generated in 0.13998 seconds with 13 queries
[Output: 86.59 Kb. compressed to 74.67 Kb. by saving 11.93 Kb. (13.77%)]
