Old March 13th, 2015, 09:15   #91
cardetailer18
Does anyone know where I can get a Beige Rear Center Console with cup holders for my 2002 VW Jetta GLS TDI. I also would like to get a beige leather wrapped e-brake, so I don't have to bend mine. ECS Tuning only carries black. Thanks!
cardetailer18 is offline   Reply With Quote
Old August 26th, 2015, 09:06   #92
Sharkey
Sharkey's Avatar
Hi All,
I've resurrected this thread as I've scoured the interweb looking for a grey rear center console kit and can't seem to locate one at any of the mentioned vendors. Does anyone have a link to a supplier who might have one?
Thank you!!!
Sharkey is offline   Reply With Quote
Old August 26th, 2015, 10:25   #93
SFHGolfTDI
SFHGolfTDI's Avatar
Originally Posted by Sharkey View Post
Hi All,
Thank you!!!
I'd keep an eye out for used ones on eBay (I found a black one but not a grey one). Sometimes you could also find wreckers on eBay parting gray interior cars and message them directly. I've found parts that way in the past since they don't post every part they have. Also, ask AArodriguez (fixmyvw.com) if he can get one. Looks like they may no longer be available.
Best option is swap your interior to black
Front end swap (Jolf), GTI tails, heated GTI leathers, GLI steering wheel, aluminum trim, center console w/cupholders, homelink visor, SGII, front/rear fogs, remote windows, 35% ceramic tint, Q5/Touareg rear wiper, roof rack, vented, PD engine cover mounts, Fumoto F106SW, panzer skid, Bilstein HDs, mudflaps, Conti PureContacts, custom 2" class II hitch. Kerma tuning. VCDS available (K-II USB).
SFHGolfTDI is offline   Reply With Quote
Old August 26th, 2015, 11:04   #94
Sharkey
Sharkey's Avatar
Thanks for the tips mate, I'll keep my eyes open!
Cheers,
Sharkey
Old January 16th, 2019, 10:12   #95
flash9
flash9's Avatar
Fuel Economy: 49/43/37
Question
I know this a very old thread, but it is the best one I was able to find.
I want to remove my Center Console Extension from my 2003 Jetta.
I can not figure out how to access the two screws boxed in the image below:
If my center console was like the one in my Bentley Manual I could find them, but my 2003 has a different design and I can not figure out how to get to them.
Would it become obvious if I removed the armrest?
2003 TDI Jetta Wagon GLS 5-Speed
Favorite Upgrade:
Power/Memory Drivers Seat
flash9 is offline   Reply With Quote
Old January 16th, 2019, 10:38   #96
DIESELMAN3500
if you have the ashtray you must remove the red tray upwards and you will have access.
Since you have the cupholder you must slide the cupholder out towards the rear of the car, it moves on a gear track. There aren't any tabs to press just gently walk it out and the screw holes will be right there.
DIESELMAN3500 is offline   Reply With Quote
Old January 16th, 2019, 15:24   #97
flash9
flash9's Avatar
Question
OK - Pulled it up and out and removed the cup holder.
But I do not see any screw holes anywhere?
Favorite Upgrade:
Old January 16th, 2019, 16:00   #98
flash9
flash9's Avatar
Exclamation
OK - Figured out that I needed to pry up the plastic track the cup holder rides in.
Favorite Upgrade:
Page generated in 0.09232 seconds with 12 queries
[Output: 86.54 Kb. compressed to 74.39 Kb. by saving 12.15 Kb. (14.04%)]
