Old January 7th, 2019, 16:02   #31
jayb79
Originally Posted by Ol'Rattler View Post
I have heard of people pulling the head ar 400K miles and they posted pictures showing the factory cross hatches on the cylinder walls still visible.
410K miles is impressive considering 20K OCI's. At your present mileage, you saved $4,000 to $5,000 over people that have the ridiculous idea oil and filters needs to be changed at 3K to 4K miles.
I did a head gasket around 390k and that is what I saw. My Y2K NB was treated the same way and was sold at just over 400k still running great and with great compression. Keep in mind that both vehicles were/are driven 90% highway and not slowly .
01Golf(410k), 2013 Mustang V6 28-30 summer mpg, 2016 F150 RCSB 2WD 2.7L ecoboost.
jayb79 is offline   Reply With Quote
Old January 10th, 2019, 00:15   #32
enginesgeek
Lightbulb May this works
You can check on these oils for 6.0 powerstroke, though they are not originally meant for TDI, I found many positive reviews from the owners of other models.
enginesgeek is offline   Reply With Quote
Old January 10th, 2019, 06:22   #33
skromfols
So far I haven't had to add any oil between changes, even when towing up in the mountains.
2014 JSW, 6 sp manual with Malone 2.0 tune
2017 Jaguar XE TDI
skromfols is offline   Reply With Quote
Old January 12th, 2019, 13:31   #34
jjblbi
Fuel Economy: 41ish mpg post fix
In every TDI I have owned they take about one pint at 7500 miles on a 10k change interval. Mobil 1 Delvac.
jjblbi is offline   Reply With Quote
Old January 12th, 2019, 13:37   #35
tdiman
tdiman's Avatar
Has Been my experience also ..
tdiman is offline   Reply With Quote
Old January 12th, 2019, 13:42   #36
turbobrick240
turbobrick240's Avatar
Same here. I added nearly a full quart during one interval that included a 5500 mile road trip.
Old January 12th, 2019, 13:43   #37
tdiman
tdiman's Avatar
I think itís the norm for these cars and if u are running them down the road doings 75 to 85
Old January 12th, 2019, 14:18   #38
skromfols
Damn, I'd better start checking my oil. I've become lazy and if my oil pressure is good and the engine temp is good I don't bother checking the oil level, and the mechanic I have do the oil change never mentioned it being low when I took it in for an oil change.
2017 Jaguar XE TDI
Old January 12th, 2019, 14:25   #39
tdiman
tdiman's Avatar
Default Oil changes after 100,000 miles
Good idea to look at it at every fuel up or once every weekend also on my 2015 Jetta if the oil gets to low a yellow oil can light comes up on the instrument cluster take a littler over quart to bring back up to mid range on dip stick . I believe what resets the lights is opening the hood and closing it.
Old January 12th, 2019, 14:30   #40
skromfols
If my oil light never comes on and the temp and oil pressure gauges both read good, am I doing any damage if it runs a pint low or so between oil changes?
2017 Jaguar XE TDI
Old January 12th, 2019, 14:34   #41
tdiman
tdiman's Avatar
Not going to kill it but if u no your car use oil I would keep a eye on it and add when needed .
Old January 15th, 2019, 10:34   #42
tikal
Fuel Economy: 37 MPG (~ 45% city)
What, no Amsoil oils!
Just kidding
Thanks for sharing the lst.
tikal is offline   Reply With Quote
Old January 15th, 2019, 21:32   #43
Nevada_TDI
skromfols, you mention rattlesnakes around your house. Are you aware that "moth balls" irritate their Jacob's organ tissues and cause them to find other places to hang out? I do not believe a pint low could cause trouble, unless you were at WOT in a hard turn at high speed and starve the engine for oil pressure even momentarily is bad on turbos.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Old January 16th, 2019, 06:36   #44
skromfols
Nevada_TDI, I hesitate to castrate a bunch of moths in order to keep rattlesnakes away. Well, to be honest, I'm too lazy to try catching that many moths and my eyesight isn't good enough to do what's necessary. But thanks for the information.
2017 Jaguar XE TDI
What else to look at at 100,000 miles? gearheadgrrrl VW MKIV-A4 TDIs (VE and PD) 5 July 23rd, 2011 11:48
100,000 miles, less than $100 in repairs! gearheadgrrrl VW MKIV-A4 TDIs (VE and PD) 10 April 19th, 2011 05:38
What are the results of running over 100,000 miles without replacing DSG oil? GibsonLP TDI 101 8 March 20th, 2011 23:03
Just went over 100,000 miles. xxl VW MKIV-A4 TDIs (VE and PD) 7 May 26th, 2005 11:48
100,000 Miles - Had Oil Analysis LagoonBlueTDI VW MKIV-A4 TDIs (VE and PD) 7 February 12th, 2004 16:51
Page generated in 0.16799 seconds with 13 queries
[Output: 120.56 Kb. compressed to 100.74 Kb. by saving 19.82 Kb. (16.44%)]
