Old January 8th, 2019, 08:50   #16
bmwM5power
bmwM5power's Avatar
Originally Posted by BMAN View Post
I trying to see what 54786-2 will look like on the Golf. I heard it gives a reverse rake which I don't want. I like it to sit even front & back. I would like it to sit like my old GTI but not as low just even.
if you get rake you can use these 8J0512149 rubber spring packing instead of the existing ones it will raise the rear about 1/4" or so
bmwM5power is offline   Reply With Quote
Old January 8th, 2019, 08:57   #17
BMAN
Fuel Economy: BMAN
Good to know, thanks
BMAN is offline   Reply With Quote
Old January 8th, 2019, 11:12   #18
AGOODHI
TDI(s): MKVII GSW
stock shocks on HR sport 54788
i'm running same setup on stock shocks. on mine, the rear sits a tad bit higher than front.
2015 GSW SE (new 60 miles) | Black | DSG | Bi-Xenon | Pano | Fender | Madico Onyx Tint | Ceramic Pro | deAutoKey LEDs | H&R Sport Springs
AGOODHI is offline   Reply With Quote
Old January 8th, 2019, 17:20   #19
bmwM5power
bmwM5power's Avatar
same here, thats what i need
Old January 8th, 2019, 18:08   #20
Picaroon
Picaroon's Avatar
Here's some info that helped me decide. http://forums.tdiclub.com/showthread.php?t=488538
Ended up with the H&R's with stock shocks.
Picaroon is offline   Reply With Quote
Old January 8th, 2019, 21:19   #21
tleader
tleader's Avatar
TDI(s): 15 GSW
Fuel Economy: 43-48
I used the EMD (Emmanuele Designs) springs. The are linear and not progressive like many springs. They have a more "stock" feel/ride. The site says they will not work on the TDI, but after research and speaking with others who have used them on a TDI, they fit and work perfectly fine. They even come with rear spacers that you can use or leave out depending on the look and amount of travel you like.
https://www.emdauto.com/collections/...nt=22072159687
tleader is online now   Reply With Quote
Old January 9th, 2019, 04:22   #22
BMAN
Fuel Economy: BMAN
My 4X4 TDI for now
Old January 9th, 2019, 18:34   #23
mikesarge
Thanks for posting. This is the look I'm after. Are these H&R springs? If so are these the one for the TDI? Part # 54786-2
No sweat- I believe so. I ordered them from a non-tdiclub vendor that happened to be having a blowout sale back when I got them, they were less than $200 when on sale. Any vendor on this site will be competitive with any current deals and I'd check through them, they'll know what's correct. here's a link to forum vendors
To each their own, but I'd really recommend doing at least the front shocks while it's all apart. you'll almost certainly blow out the stock fronts within a short time if you continue to run the stockers, and doing that job twice on jack stands will suck. Maybe I'm the only one that hates spring compressors and strut spreaders. I waited to do the rears, but I'm already feeling a degradation in ride quality so once I get paid I'll order up the rear konis and throw them in.
mikesarge is offline   Reply With Quote
Old January 10th, 2019, 03:57   #24
BMAN
Fuel Economy: BMAN
Thanks for the info. Yes, I agree, as I mentioned on page 1 I'm planning on using Bilstein B8 Plus with H&R lowering springs.
Old January 10th, 2019, 06:38   #25
BMAN
Fuel Economy: BMAN
I'm guess with our solid TDI rear axle we can't adjust camber or toe?
Old January 15th, 2019, 19:00   #26
sprstu
Fuel Economy: average:42 best:48
Does anyone know if the MK6 springs and struts are usable on the MBQ platform? I have 3 sets of mk6 springs in the garage: VWR, Golf R and H&R, and I would love to use them on my GSW. I understand that the rear is now a solid vs independent but it seems strange if the MK6 and MK7 aren't close enough for it to work.
81 Caddy 1.6TD
2015 Platimun GSW 6spd, post fix Kerma Tune
sprstu is offline   Reply With Quote
Old January 16th, 2019, 04:37   #27
bmwM5power
bmwM5power's Avatar
id say youre gonna have to try it, at least the rears, 30 min job
Lowering Springs for TDI Sportwagon! daniik Private TDI Items for Sale/Wanted 2 April 20th, 2015 19:18
WTT: lowering springs for stock springs MK4 or buy a good set gquenstedt Private TDI Items for Sale/Wanted 9 August 12th, 2013 17:05
Swap 1-1/2" Lowering Springs for Jetta III Stock Springs Gobi Private TDI Items for Sale/Wanted 0 April 1st, 2009 08:36
WTB 1-2.5" lowering kit, or lowering springs GOTLIFT02 Private TDI Items for Sale/Wanted 0 September 15th, 2005 23:07
lowering springs for the 2004 Golf tdi laminated Upgrades (non TDI Engine related) 4 May 24th, 2004 23:09
Page generated in 0.15690 seconds with 13 queries
[Output: 110.92 Kb. compressed to 93.86 Kb. by saving 17.07 Kb. (15.39%)]
