Old January 2nd, 2019, 11:05   #91
davidlp
Fuel Economy: 47
Thanks. I learned of the SX version later on another thread and have ordered that.
1977 Rabbit, 1982 Rabbit, 1986 Golf Diesel, 1991 Golf GTI 8V, 2002 Jetta TDI, 2015 Golf GSW TDI #1, 2015 Golf GSW TDI #2
davidlp is offline   Reply With Quote
Old January 4th, 2019, 05:55   #92
740GLE
did the 30K change on the passat wednesday night, I gotta say I think the Passat has way more room by the filter than the Golf, it wasn't that bad except some splashing when dumping the oil filter housing plug.
I did seem to misplace my T25 socket, I used it to take the belly pan off, when I went to replace it could not for the life of me find the socket, I've searched all over the garage and boom utterly disappeared, I feel so defeated.
Old March 9th, 2019, 19:44   #93
jerryfreak
how do you reset service indicator?
jerryfreak is offline   Reply With Quote
Old March 10th, 2019, 08:26   #94
jason_
Hold trip while turning on ignition for oil.
Service might need vcds?
Sent from my 2PS64 using Tapatalk
jason_ is offline   Reply With Quote
Old November 4th, 2019, 07:33   #95
Iridebikesalot
Jason,
You rock. I managed to get everything done start to finish in 42 min
Would've been a much bigger headache without your amazing tutorial. Thanks so much!
Iridebikesalot is offline   Reply With Quote
Margey's guide to fuel filter change outs LargeMarge VW MKV-A5 Golf/Jettas 24 January 18th, 2010 19:33
error in timing belt change guide zeaustar VW MKIV-A4 TDIs (VE and PD) 2 April 30th, 2009 13:15
Need TB change guide in Brighton, MI area. master cylinder VW MKIV-A4 TDIs (VE and PD) 6 May 9th, 2004 09:47
Page generated in 0.14516 seconds with 13 queries
[Output: 67.65 Kb. compressed to 59.93 Kb. by saving 7.72 Kb. (11.42%)]
