Golf2K
I was replacing the left front wheel bearing and afterward I torque the axel nut to 150lbs, I rotated the nut 1/2 turn, I went to move the car back and heard a snap or crack, the car no longer drives and you can hear something rotating when you rev the engine. The axels look ok to me but maybe they are worn out, is this a broken Diff? Car is ALH MANUAL trans 515,000kms. 2nd transmission.
When I was beginning the job the drive axel nut was a little bit of a struggle, the wheel wanted to turn, so i put the car in 5th gear, I had the car half way into the garage so the ground was on even.
Idk...
Idk...
