wonneber
- Joined
- Oct 12, 2011
- Location
- Monroe, NY, USA
- TDI
- 2014 Jetta Sportwagon,2003 Jetta 261K Sold but not forgotten
The diesel trans has different gearing then the gassers.just pull the trans for one of my other cars
Is it beneficial to soak it with penetrant or maybe use heat?
Are you talking about nickel anti-seize?
Thanks for the heads up!
Yes, I have heard this, but I hear commonly that the gearing is desired for many people because if the highway gearing that helps the gassers not rev so high. I hope to leave it in this car and drive it as it is .The diesel trans has different gearing then the gassers.
I plan on checking out the turbo next.Pull the intake pipe coming into the turbo and use both an inspection mirror and your fingers. Usually if it's lunched it's pretty obvious -- not always, but usually.
But the oil in the I/C pipe in any sort of volume is pretty much proof that it's toast.
The best "no disassembly" option to figure out what the odds of a bent rod are is a compression test. Given the mess you had come out of all the holes it's entirely possible you bent more than one rod, but if all holes are in-spec for compression and there's no material variation you might have gotten lucky. The definitive test is to measure piston protrusion but to do that you need to pull the head and now you're into it for a timing belt kit, head gasket and assortment of one-time fasteners (e.g. head bolts, mount bolts to do the timing belt, etc) you have to remove. While you CAN put it back together with the existing belt that's a losing proposition since you don't have a KNOWN good history on it. If you break or strip the belt you're **guaranteed** to do serious cylinder head damage (read: get out your wallet or find a used but in good-condition replacement head.)
In addition at that age I'd consider the oil pump and tensioner while you have it apart as once again a failure there and you're likely to lunch the engine -- and at that mileage you're getting into the zone where it can and has failed on people, although there are some folks who have gotten 500k+ miles without it dying, so....
Speaking of which since you don't have solid knowledge of the time on the existing timing belt I'd do a complete kit anyway. So if you're lucky then it's that plus a working turbo and you're back online. If not and you bent rods then you have some decisions to make. At this age and with what you paid for the car it all comes down to what you're willing to spend and which way you want to go -- the options are to fix what you have or find a running take-out engine, do the belt, water pump and rollers while it's out of the car (MUCH easier since you're not fighting the mounts, brackets, etc.) and then install it.
So low-end you find a working used turbo (maybe one someone swapped out during a tune + power increase binge) and install that, plus a timing belt kit. On the other extreme it's one or more rods + having them balanced + the fasteners for the head and the proper gasket after you get them back and measure protrusion + that timing belt kit and then considering whether you want to do the oil pump as well in an attempt to protect your materially larger investment from a possible "aw crap" sort of failure shortly thereafter. If you DO pull the head for some reason (or even if not and you're just doing the timing belt) DO check the cam and lifter condition; it doesn't take long to pop the caps off and see what you got there, and again, you're in the mileage range where you could have something going on there that's getting close to failure as well.
I have not laid eyes on this yet, physically, but I do now know that I need a modified 17mm wrench, and I can get that together and have it ready. Very handy information. Thank you!Sooo what would happen if he ran it with the turbo outlet disconnected?
He could see how much oil is spewing from it.
Also I think sometimes the reason the turbo oil supply line twists with the line nut is because it's threaded to another fitting that turns.
So when you loosen the nut it doesn't actually loosen,..
it turns the turbo fitting.
I think you can take a 17mm wrench and grind on it until you can fit it on the lands of the turbo fitting, to hold it still while the line nut is loosened.
You still have to watch to see if the line is turning with the line nut.
Yes, I'd like to just pull this engine and dig into it later...but if this one is 'okay', I'd much rather run it for a bit and learn some diesel quirks first hand. It would be a challenge to pull a diesel and put another used one in without having any experience with how one runs at all. I think I could do it, but it would be much more worrisome I think. I mentioned in a post above that I will go so far as to put a turbo on this one if the one in it seems bad, but I don't see myself pulling the head off of this one while in the car if compression is not good, or doing a rebuild on this engine because I just don't have a good place to do that the right just yet. At that point, I'll pull the engine and put another in, but that's not what I'm hoping for. I need this one to run for a little while. Maybe it will."I'm not the guy who would ever complain about receiving basic information. It's better(in my opinion) to hear something again than to have never heard it altogether. Getting information twice won't hurt you, but not getting information at all...now that makes things much harder."
Phew, glad I didn't appear to be condescending. You're getting good info,
but it can be overwhelming. For me, if I understand the principles,
I've got a chance to be able to work it out.
We're getting back to one of my original suggestions though, pull the motor.
Genesis has the right technical advice/knowledge to really check it out.
Or find another engine, and rebuild this one at leisure as time and money
allow. Once you get these motors right, they go and go and go. But you do have to get them right.
German engineering doesn't allow much fudge factor, especially with diesels.
I keep it all in mind and approach the line removal with caution.The penetrating oil certainty wouldn’t hurt.
Yes the high temp.
I’ve been successful in getting all my lines off in one piece. I’ve done about 10 or so turbo swaps . Usually when I get a car it’s one of the first things to come off as I take them apart to clean the VNT mechanism 90% of them are stiff to move .
I’ve got 5 TDI’s in the stable ATM. One for me, one for each of my kids and one I’m putting back together that someone botched a TB job , replaced two pistons and one bent connecting rod. Right now she’s purring like a kitten and will be a spare car in case one of the kids car goes down or mine for repair.
Aha! Just make a homemade line wrench of sorts, huh? Great idea! That can definitely happen. Thanks!Do a Google search for ALH-tdi turbo line wrench. An, if I remember right, 17 Mill box wrench cut open just wide enough to slip over the line. Works great for holding the fitting on the turbo
Thanks! Great information!1. When you turn the ignition to "on" it will pull in for a couple of seconds, then drop. When you start to crank it pulls in and remains in when the engine is running. That's the "primary" means the ECU has to control the car getting fuel and running.
2. If it's a gasser fuel pump I would get it out of there. The PD engines have an in-tank pump but the ALH does not from the factory. The problem with an in-tank pump is that you really do need to have it powered off a relay that's tapped from the pull-to-run solenoid or it's quite dangerous if you're in a wreck or similar since it will stay energized any time the ignition is on and if there's a crash and a fuel leak you DEFINITELY do not want that. Diesel isn't gasoline, but still...
3. Definitely not on the pressure. The IP produces pressure WAY beyond what the in-tank pump can do. Not even close.
4. If you have the intake pipe off at the EGR valve (top of the engine) then you can't ingest a slug of oil. It's ok to start the engine in that circumstance but be careful that nothing can be ingested down that hole and have something that can't be ingested you can stuff in it if necessary to shut off the air. The turbo is part of the exhaust manifold; if you pull the outlet then you've got hot exhaust gas coming out of the bottom, and if you remove the entire assembly now you have open exhaust ports. I would NOT crank it under that circumstance if there's any chance it fires; 1,000F exhaust gas going places where you're not sure what can burn is probably a bad idea. Remove the wire from the pull-to-run solenoid on the IP and you can crank with the engine getting no fuel, but if there's oil residue in the cylinder or intake it MAY fire on that for at least a couple of rotations, so do pay attention. This may throw a code (disconnecting the large IP wiring harness connection definitely WILL throw a code) but it's easily cleared. I'm assuming you want to crank it without it firing for a compression test, which makes sense.
One other thing to be aware of is that these engines frequently build up a LOT of carbon in the intake pipe and ports. This is not a big deal normally, other than when it gets silly you have to take that apart and clean it, but in the event of a major oil ingestion event you could knock a decent amount of that loose and if you do, and it goes down the intake, it could jam an intake valve open and now you've got real trouble (as in piston-valve collision.) This is one of the reasons you have to proceed with care in a situation like you've had occur.
BTW one final thing -- while it's much easier to access all the timing belt components with the engine out it is absolutely essential that the engine is at TDC when you install the new belt to align the cam and crank correctly. The bellhousing is where the alignment pin is for the flywheel, which, if you pull the engine leaving the transmission in the car, won't be there. There ARE other means of determining TDC (e.g. probe down #1's glow plug hole, etc) but you have to be BANG ON when doing that job -- the margin of error before you have a valve/piston collision is only about 7 degrees of rotation!
4. No. The intake pipe, which you have disconnected from the I/C piping from what you've described, is what I'm talking about. If the EGR was removed then in all probability the intake is clear and doesn't have build-up in it.
If you remove the single wire on the front of the pump the engine will not start since that solenoid is "pull to run"; you don't have to disconnect the rectangular wiring harness although it doesn't hurt to do so.
I understand what you're saying about the pump. I'll have to pull it and see what I can tell from it. I don't know if there will be any identifying information on it or not. It's possible that it is actually a lift pump, because I have since learned that the PO didn't do any of the work but someone else did. Maybe there's a ray of hope that this person knew a little...maybe.Downside of an inoperable pump in your tank is that it could restrict flow. ALH injection pump low pressure side pulls fuel from the tank, high pressure side then distributes fuel to the injectors. Grind the thickness of that 17 mm wrench down or it will grab both the turbo fitting and the nut on the line, leading to uncontrollable profanity. Have you ever checked static timing? Look up DIY TDI timing tools. I made my own and have used them several times. Just don’t rotate the engine by the cam, use the crank or compression is working against the belt.
I have not checked the timing in any way yet. It is one of the very next things I'll be trying to do. Once I found out that the engine could be fully rotated via the crank, I felt that timing was either ok, or valves were already bent and that I wasn't going to really hurt them any more by moving forward with just trying to see if it would run as it sits. I have wanted to check the timing but I have not really been under the car more than to just turn the crank bolt and pull the pipe off of the intercooler and to drill a small hole in the intercooler to see what was in it.If cam to crank timing is ok, cranking or running it should not be a problem, as long as you pull the boost pipe from the intake, as previously mentioned. If you are going to do a compression test, be aware that oil in the cylinders will raise compression, possibly beyond capability of the gauge. If crank/cam are in time I would not be afraid to fire it and clear the cylinders. Just be ready with a rag to choke it if rpm’s climb on their own. And keep in mind oil is most likely being pumped into the intake tract, so what is in the pan will be going down
Just get a stock ALH sending unit and be done with it. Lift pumps are unnecessary on that car unless you are pushing 200+HP plus it adds another point of failure. A gasser pump will absolutely not work and likely blow the seals out in the injection pump.
IF this was my car I would do the following steps:
1. check timing belt and components. Belt should be tight. No timing marks, timing is set using locking tools.
2. Run some fuel lines from a clean jug of diesel to the fuel filter. This will be a temporary fuel supply to see if the engine runs.
3.Disconnect the upper intake hose going into the intake manifold. This will insure if the turbo is passing oil that it won't go into the engine and cause a runaway.
4.Remove glow plugs and turn over engine. Make sure ALL oil is out. Doesn't take very much to bend a rod.
5. Install glow plugs and bleed fuel system. Use a mityvac to suck the fuel into the pump and crack loose the injector lines. Crank until fuel squirts out.
6. Tighten the lines and try to fire it up. A lumpy start may indicate a bent rod.
7. If the engine runs OK then a compression test would be a good idea. Harbor freight makes a diesel compression tester that works OK.
8.Assuming you made it this far and everything checks out, now take a look at the turbo to see if its dumping oil or not. Pull the intake tube, outlet pipe and run the engine. Look for oil dripping out.
Doing these steps will set you in the right direction. I know people are just trying to help but there are a LOT of armchair mechanics in this thread.
I know just the spot you're talking about. I've definitely used it, but the gassers I've messed with also had some sort of mark on the crank pulley or gear for reference...just to let you know when you are close while your rotating the crank...You watch that mark and at least you know your within one revolution of TDC. Maybe the TDI has something like that too. At 350,000 miles, this thing has surely had at least one new flywheel...maybe an aftermarket...I wonder if all flywheels have the witness marks? I'll be letting you know soon enough. haha.Timing check is all done from under the hood. Pull the airbox and you can view the flywheel by putting your eyes just above the fender and looking at the top of the bell housing there is a rubber plug that pulls out. Pulling the valve cover you We’ll see a slot in the back of the cam, it should be horizontal while the two cam lobes on cylinder number one are pointing in an upward direction
Yes! That's why I was wondering about any mark around the crank pulley. It could take a little time. I can pull the valve cover first I suppose and look at the cam lobes to know when I'm getting close. I'll find it.The flywheel mark can be hard to find, I ink marked mine. I also ink. marked a line on both sides of that mark, orange on one side and green on the other. And then an orange and green dot on each side of the inspection hole so that by whatever color is showing on the flywheel I know which way to rotate it to find the timing mark. The slot in the cam is where the lock slides into and sits on the machined surface where the valve cover mates to the head
