Norwescan
Hiya, I have zero experience on V6 Tdi 2.5L with VP44 I/p and I'm pretty sure this is the first car here in North America as I brought it over from Germany. My son complained of a long crank on cold and I decided to hook up my VCDS (professional) to peer at the Tdi timing (basic settings group 004) and chose Tdi timing and it is way retarded but I noticed it cycled between base timing and it advanced to way advanced and kept cycling.
Never seen VCDS do this on any ALH / AHU engines that I've worked on. I'm pretty sure the long crank is due to the retarded Start of Injection and I have bought all the jigs to do the Timing Belts. Has anyone seen this cycling in VCDS Tdi timing?
Cheers!
Cheers!
