Hello,
I have a 2002 Jetta TDI auto.I am chipped (upsolute)and have had my EGR adjusted.
I was recently at a GTG in Toronto and was told by someone that because I am chipped my EGR will still open somewhat, even though is was adjusted with the VAg-com.
He told me that the best thing to do was into install an Epsolian device, this way my EGR could be disconnected from working altogether and not put exhaust gases into my intake.
The Epsolian device is some contraption that the vacuum hose(originally connected to the EGR) connects to which is tied into the MAF wires. He told me this way the ECU thinks that its connected to the EGR and won't give any fault codes.
This guys car had this device and his EGR vacuum hose was not connected. This way he said there will be no exhaust gases going into his intake at all.
He showed my his oil and it was clean. There was no soot in there AT ALL!!!!!
My question is:
If the EGR vacuum hose is disconnected the EGR will be in the closed position where the plunger inside is all the way down to keep the exhaust gases from going into the EGR and intake manifold.
Am I correct that the engine exhaust comes into the EGR from the bottom via the metal flex hose?
If this is the case why not just leave the vacuum hose connected to the EGR and place a BLIND GASKET (A flange gasket without any holes to keep exhaust gases from coming into the EGR in the first place)at the bottom of the EGR between the EGR and the metal flex hose. This way the EGR doesn't have to be adjusted with the Vag-com. The ECU thinks that the EGR is working properly because its controlling it.
I don't think anything will be damaged because with it done the other way (with the Epsolian device) the EGR plunger was in the closed position anyways. Keeping the exhaust gases from coming in.
Also, my CCV is disconnected so that there is no oil vapours going to the turbo.
What do you think??
Comments would be appreciated.
I want to do this to my car.
Rod
My question is:
What do you think??
Rod
