mattfrayage
this is what happened:
BTW the bold ABS fault says module clearing not recognized-contact RT for assistance
the 2 underlined faults for window motors wold only clear after rolling each rear window all the way up and down
the first try before doing this just made them pop back!
just in case someone else ever has this problem...
09 did not read because we did this on the fly on the way to a grocery store- but it did have an exceeded and lower limit fault which easily cleared...
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
Part No SW: 03L 906 012 BN HW: 03L 907 309 S
Component: R4 2,0L EDC H21 4804
Revision: 71H21--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 00009 009 28888
ASAM Dataset: EV_ECM20TDI01103L906012BN 004007
ROD: EV_ECM20TDI01103L906012BN.rod
VCID: 71C7378CA0B2B3966BD-8024
3 Faults Found:
16705 - Ignition Switch; Run/Start Position Circuit
P2533 00 [096] - Open or Short to Ground
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
17262 - Terminal 30
U140A 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
4629 - ECM Power Relay Load Circuit: (J271)
P068A 00 [032] - De-Energized Performance Too Early
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3522
Revision: 05551213 Serial number: --------------
Coding: 0000020
Shop #: WSC 09003 957 00200
VCID: 24690ED8E7C0563ED0B-8071
2 Faults Found:
16947 - System Voltage
P0563 - 000 - Too High - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 28214 km
Time Indication: 0
Date: 2016.14.23
Time: 23:35:13
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: C54BC0F5492300FAA31303E892210042A71000
VCID: 7DDF1BBCE4EAC7F6FF5-8028
1 Fault Found:
00668 - Supply Voltage Terminal 30
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 26
Mileage: 28214 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 14
Count: 4096
Count: 129
Count: 65280
Count: 0
Count: 253
Count: 6144
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: ----------
Coding: 130C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G.rod
VCID: 3449FE989F20C6BE40B-8061
1 Fault Found:
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 26
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 561 907 044 M HW: 561 907 044 M
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 0018001012
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411.rod
VCID: 216707CC30D24316BBD-8074
3 Faults Found:
9473137 - Motor for Left Temperature Flap
B108C 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 28214 km
Date: 2016.14.20
Time: 07:04:32
9473393 - Motor for Right Temperature Flap
B108D 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 26
Mileage: 28214 km
Date: 2016.14.19
Time: 00:39:58
9474161 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 28063 km
Date: 2016.14.12
Time: 02:55:40
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: EFC3B1F436862566FD9-80BA
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number:
Coding: 303047
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number:
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number:
Crash sensor for side airbag; rear driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number:
Crash sensor for side airbag; rear passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number:
Crash sensor for front airbag; driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number:
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number:
No fault code found.
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: --------------
Coding: 000A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DDF1BBCECEAC7F6FF5-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-YVJ H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 561 920 970 E HW: 561 920 970 E
Component: KOMBI H07 0705
Serial number: 00000000000000
Coding: 641E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 1C19363817B06EFE68B-8049
1 Fault Found:
13893888 - Function Restricted due to Exessive Voltage
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 26
Mileage: 28214 km
Date: 2016.14.23
Time: 23:30:13
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 T HW: 7N0 907 530 K
Component: J533 Gateway H40 1632
Revision: H40 Serial number: 21061203290341
Coding: 461000
VCID: 41A7A74CD8926316DBD-8014
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0705
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAF5A0E00D64C04EAA7-80BF
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: --------------
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F43F1F47606E5663D9-807A
1 Fault Found:
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 26
Mileage: 28214 km
Date: 2016.14.23
Time: 23:30:15
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: ----------
Coding: 010100
VCID: 2A75E0E045E4804EEA7-807F
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: --------------
Coding: 00581B0000000000000021010100202020202120202020
VCID: E0E1C2C8F3588A1E743-80B5
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 J HW: 3C0 035 684 G
Component: RNS-MID H02 4366
Revision: AB001001 Serial number: --------------
Coding: 0409004204000090000B
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V6 7963
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: ----------
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Serial number: --------------------
Coding: 800000
1 Fault Found:
131584 - Motor for Rear Window Regulator
B11EE 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 3753C99446562DA6659-8062
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System (R12) Labels: 3T0-035-456.clb
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: --------------
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: E5EFD3DCE47AEF36875-80B0
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 K
Component: EZE_2 H40 1632
Revision: H40 Serial number: --------------
Coding: 01030108
VCID: EFC3B1F43E862566FD9-80BA
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0004
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: ----------
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D1F3B3C0CAA67F69F5-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Coding: 020000010100010000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_SE36.rod
VCID: 24690ED82FC0563ED0B-8071
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
17262 - Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 0000020
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 28214 km
Time Indication: 0
Date: 2016.14.23
Time: 23:35:13
Revision: 00H31001
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 26
Mileage: 28214 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 14
Count: 4096
Count: 129
Count: 65280
Count: 0
Count: 253
Count: 6144
Coding: 130C0C
1 Fault Found:
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 26
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: 00001K01
Coding: 0018001012
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 28214 km
Date: 2016.14.20
Time: 07:04:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 26
Mileage: 28214 km
Date: 2016.14.19
Time: 00:39:58
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 28063 km
Date: 2016.14.12
Time: 02:55:40
Cannot be reached
Coding: 00003548
Serial number:
Coding: 303047
Serial number:
Serial number:
Serial number:
Serial number:
Serial number:
Serial number:
Coding: 000A140000
Coding: E20000
Coding: 641E01
1 Fault Found:
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 26
Mileage: 28214 km
Date: 2016.14.23
Time: 23:30:13
Coding: 461000
Serial number:
Coding: 000007
1 Fault Found:
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 26
Mileage: 28214 km
Date: 2016.14.23
Time: 23:30:15
Coding: 010100
Coding: 0405FD
Slave Driver:
Coding: 800000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Revision: 00H22000
Cannot be reached
Coding: 01030108
Coding: 181100
Coding: 0405FC
Slave Passenger:
Coding: 800000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
