Hi guys, any insight to my 5 faults seen below:
Sunday,15,May,2016,13:42:53:04551
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: * License Plate:
Mileage: 98080km-60944mi Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: * Mileage: 98080km-60944miles
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
Part No SW: 03L 906 012 DE HW: 03L 907 309 S
Component: R4 2,0L EDC H24 8401
Revision: 71H24--- Serial number:
Coding: 001D0012842400008000
Shop #: WSC 01041 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906012DE 004008
ROD: EV_ECM20TDI01103L906012DE.rod
VCID: 6AD0CDD88D6E2E6EC0-803E
5 Faults Found:
9655 - Control Circuit for Reductant Tank Heating
P202A 00 [237] - Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 95192 km
Date: 2016.03.31
Time: 07:17:23
5306 - Throttle Position Sensor (G69)
P0122 00 [040] - Signal too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 96758 km
Date: 2016.04.29
Time: 12:24:35
9617 - Control Circuit for Reductant Heating 1
P20B9 00 [175] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 95246 km
Date: 2016.04.04
Time: 07:18:52
9123 - Throttle Actuator Control System
P2112 00 [032] - Stuck Closed
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
9124 - Throttle Actuator Control System
P2111 00 [032] - Stuck Open
Freeze Frame:
Readiness: 1 3 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3527
Revision: 05651213 Serial number: 00001302250793
Coding: 0000020
Shop #: WSC 09003 957 00200
VCID: 244CE3E0E7CA381E3A-8070
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: C54BC0F5492600FFA31103EB921E0042271000
VCID: 7DFAF684E4E0A9D615-8028
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 97129 km
Time Indication: 0
Date: 2016.05.06
Time: 15:34:11
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 51457
Count: 0
Count: 65534
Count: 0
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0206966623
Coding: 130C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G.rod
VCID: 346C13A09F2AA89EAA-8060
1 Fault Found:
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
B116C 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 254
Reset counter: 202
Mileage: 92270 km
Date: 2016.02.22
Time: 13:16:33
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 561 907 044 AB HW: 561 907 044 AB
Component: Climatronic H03 0505
Revision: 00001K01
Coding: 0010019012
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 57B6842C2E1CA3866F-8002
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0168
Revision: BL121001
Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
VCID: 74ECD3A0D7AAE89E6A-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 280213 05 54 0403
Coding: 22300A
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM01WYZ9
Coding: 00005033
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 75EAEEA4D4D0F1965D-8020
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y130000TTAF0B
Coding: 303047
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME256F217AZZZ+
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME6442227AZZZV
Crash sensor for side airbag; rear; driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME1A082322ZZZH
Crash sensor for side airbag; rear; passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME4A392023ZZZN
Crash sensor for front airbag; driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME34006C21ZZZM
Crash sensor for front airbag; front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME2E226B21ZZZZ
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20130313202037
Coding: 001A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DFAF684ECE0A9D615-8028
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-YVJ H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 561 920 870 C HW: 561 920 870 C
Component: KOMBI H07 0705
Serial number: 00000000000000
Coding: 331E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 1932C214188875F699-804C
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 19051303290131
Coding: 461000
VCID: 76E8E9A8C1D6FA8E54-8022
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0705
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
1 Fault Found:
9456681 - Key
B104C 29 [008] - Implausible Signal
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 95317 km
Date: 2016.04.13
Time: 13:34:18
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 12000283951002
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 30641FB06B3294BECE-8064
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664709485
Coding: 010100
VCID: 2A500DD845EEEE6E00-807E
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000057529473
Coding: 00581B0000000000000021010100202020202120202020
VCID: 60C4AFF07352643E1E-8034
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 G HW: 3C0 035 684 G
Component: RNS-MID H03 3696
Revision: AB001001 Serial number: VWZ6Z7N4092009
Coding: 24090042010000A6000B
VCID: 2756F4EC56FCD3061F-8072
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Reset counter: 202
Mileage: 92264 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 92930 km
Time Indication: 0
Date: 2016.03.08
Time: 17:40:40
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0006572616
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C3CDB0017BA00DE82-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B
Component: J388__TSG_HL 006 5470
Serial number: 14102630130508130210
Coding: 800000
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 377624AC465C43868F-8062
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0044634
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 2648F9E859F6CA0E24-8072
2 Faults Found:
9457664 - Function limitation due to excessive temperature
B1050 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 96964 km
Date: 2016.05.05
Time: 17:42:50
9637138 - Loudspeaker 2 in Double-Subwoofer
B130D 12 [009] - Short to Plus
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 92269 km
Date: 2016.02.22
Time: 12:17:58
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030108
VCID: 6FE6DCCCBE8CCB4697-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0006486351
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D3AD6040CA009D675-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B
Component: J389__TSG_HR 006 5470
Serial number: 14202631130513062546
Coding: 800000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 202
Mileage: 92264 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 92930 km
Time Indication: 0
Date: 2016.03.08
Time: 17:40:40
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664535355
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A703D98BD4E5EEE70-806E
End-------------------------(Elapsed Time: 03:39)--------------------------
www.Ross-Tech.com
52 56 62 72 77
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 95192 km
Date: 2016.03.31
Time: 07:17:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 96758 km
Date: 2016.04.29
Time: 12:24:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 95246 km
Date: 2016.04.04
Time: 07:18:52
Freeze Frame:
Freeze Frame:
Coding: 0000020
Revision: 00H31001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 97129 km
Time Indication: 0
Date: 2016.05.06
Time: 15:34:11
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 51457
Count: 0
Count: 65534
Count: 0
Coding: 130C0C
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 202
Mileage: 92270 km
Date: 2016.02.22
Time: 13:16:33
Revision: 00001K01
Coding: 0010019012
Revision: BL121001
Coding: 22300A
Coding: 00005033
Coding: 303047
Coding: 001A140000
Coding: E30000
Coding: 331E01
Coding: 461000
Serial number:
Coding: 000007
1 Fault Found:
9456681 - Key
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 95317 km
Date: 2016.04.13
Time: 13:34:18
Coding: 010100
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 202
Mileage: 92264 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 92930 km
Time Indication: 0
Date: 2016.03.08
Time: 17:40:40
Coding: 0405FD
Slave Driver:
Coding: 800000
Revision: 00H22000
2 Faults Found:
B1050 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 96964 km
Date: 2016.05.05
Time: 17:42:50
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 92269 km
Date: 2016.02.22
Time: 12:17:58
Coding: 01030108
Coding: 181100
Coding: 0405FC
Slave Passenger:
Coding: 800000
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 202
Mileage: 92264 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 92930 km
Time Indication: 0
Date: 2016.03.08
Time: 17:40:40
ROD: EV_UHVNA.rod
