duteman
- Joined
- Jan 9, 2002
- Location
- Connecticut
Took family to a restaurant, car wouldn't start after! '96 Passat TDI. 99965 miles. The lights in the dash, including glow plug, go on then off in a odd pattern. Quick no delay. The dash cluster lights otherwise seem normal. I've read the posts about the 109 relay, don't (yet) have a Bently manual, but from what I've read on these posts the 109 is in up under the dash by the fusebox? Recent battery, good lights, power itself seems fine. NO CRANK WHATSOEVER. Starter not getting juice, Have had the ign. switch replaced, but that was some time ago, perhaps six months, daily driver, thousands of miles since, and the symptoms are not the same. I suppose it could be that, but, doubt it... Checked the two clear plastic covered fuseable links, they seem fine, but the one next to the firewall has a relay, the coil of which is semi-exposed, that is buzzing. Purring, really, and it does so with the ign in the ON position. Bumping the key to start causes headlights to drop, as usual, but no clicking or turning at starter. To be honest, I can't remember if the purring stopped during the key-to-start position or not. Does the 109 relay up under the dash send power to that relay? Of course, it's night time and raining! The car is still at the restaurant, near home thankfully, and we bummed a ride home from a friend who lives nearby. I suspect some kind of relay problem, and if it is, are they available from regular sources or stealer only? THANKS SO MUCH IN ADVANCE for your help, guys...
