plomagli
I have an 03 jetta that was running fine when I parked it. I went to start it and it starts up for 2 seconds then dies. The only thing I did was take my key apart because the case was broken and put the guts in a new case. I dont really thing that would have anything to do with it.
I took the fuel cut of solenoid valve out and removed the plunger and tried it...still nothing.
I also unplugged the MAF and still nothing.
Anti shudder valve is not stuck closed thats the first thing I checked
I cracked all 4 injector lines at the injectors and made sure there was no air in the system.
Any ideas? I do not have Vag Com.
Thanks!
Thanks!
