SoaceMunky
Any way I can minimise my lights going on and off each time i start/shut down the car and turn headlights on and off?
Lightbulbs get worn out(if thats the correct term) as you are switching them on and off. I noticed each time I start or shut down the car, the lights seem to turn on momentarily for no apparant reason. Not to mention the constant use as daytime running lights....
I believe it would be beneficial to find a more efficient start up/shut down procedure that will minimise the lights turning on and off needlessly. All you really need is to turn them on once, and turn them off. Seems there are lots of relays involved each time I turn the key in the ignition.
Any ideas?
Any ideas?
