teleskier
- Joined
- Mar 14, 2001
- Location
- Boston, MA
I thought I had a 100K mile timing belt in my stock 2001 Golf TDI. Reading the forum on Wednesday made it unclear to me how long my belt should last, but many seem to think it is 60K miles.
This caused me a bit of panic since I was already at 81K miles. I scheduled my timing change with my local mechanic for the next day.
I’m not recommending that people wait as long as I did, but FWIW, the old belt looks fine to me. It looks no different than the new belt – no worn edges on the sides or on any of the inner square steps. The rubber on the older belt is a little less supple than the new one, but much less than what you might expect from four year old rubber. If you force bend the old belt with a lot of arm strength to extreme limits, you do see the starting signs of some scaling. But on the whole the belt looked MUCH better than the forum panic had me expecting.
In full disclosure, my local mechanic said “Well maybe it would have started cracking more in the cold of winter, but yeah, it would have made it to at least then.”
Your mileage may vary. I wanted to pass this along in case anyone else panics thinking their belt would be as frayed as some of the pictures I saw here (as I feared).
