Old September 12th, 2017, 07:59   #1
tom101
Default External Wastegate on exhaust TDI with DPF
Hello,
I'm thinking about install a wastegate on the exhaust manifold. I have the egr pipe avaliable on the manifold.
I'm going to remove downpipe and mount DPF due to MOT every year (the car has 10 years), so I have to detune so much due to dpf.
and a waste gate in the exhaust seems to me a good option to avoid excesive exhaust gas pressure.
Anybody has mounted one like this?
My car is a 3.0 tdi, but it may be usefull for any tdi with dpf
thanks
tom101 is offline   Reply With Quote
Old September 12th, 2017, 08:06   #2
diffas
diffas's Avatar
So your plan is to bypass dpf with wastegate? You need at least 60mm wastegate for that
diffas is offline   Reply With Quote
Old September 12th, 2017, 09:23   #3
740GLE
and a waste-gate that can handle what? 1700F?
typical wastegates/bypass valves are used on the charged air circuit right? Maybe the exhaust flapper valve on the CR may work better but doesn't seal 100% as its a rough butterfly valve.
740GLE is online now   Reply With Quote
Old September 12th, 2017, 09:28   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I have no idea what problem you are trying to find a solution for.
oilhammer
www.cardocautomotive.com
Old September 12th, 2017, 09:53   #5
diffas
diffas's Avatar
Charged air in the exhaust? Well these normally work around 850-950c on gasoline engines so adding it to to the exhaust to bypass dpf you probably see only 600-700c. There are also watercooled wastegates.
And indeed flap is way better and smaller to bypass dpf
Old September 12th, 2017, 10:03   #6
tom101
My 3.0 tdi has bigger turbo and upgraded CR fuel pressure. 360hp and 800n/m
I'm looking for someting that help me to detune less.
Not a full bypass, just something to reduce EGP
something like that. but works only with a spring, when the egp is high, opens. Will reduce egt and egp.
thanks you very much
Old September 12th, 2017, 10:34   #7
tom101
install a flap and a system to command it, seems difficult.
I'm looking for something easy to install. Have seen this wastegates on ebay, and springs to change open pressure.
But I don't know what pressure would be ok to set up the spring
Old September 12th, 2017, 12:08   #8
diffas
diffas's Avatar
Exhaust flaps can be controlled by vacuum, boost or electronic. If you have boost creep with wg helps, otherwise not that much. What kind s turbo you have if you have emp problem? Some silly hybrid?
Old September 12th, 2017, 16:15   #9
tom101
is the original turbo of new 3.0 tdi 272/286ps. I run 105mg and 2.05 bar boost
Now with downpipe I have no problems, the car is amazing,
but I will install dpf soon, and I will have to detune so much, or the dpf will burn.
I'll lose many hp (60 hp at least.)
So I'm thinking about wastegate to allow me get some extra power with dpf. And easy to install
Old September 12th, 2017, 17:43   #10
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
This.
Old September 13th, 2017, 05:58   #11
740GLE
So that bypasses the DPF and the turbo? how is that better? how will that help when you don't have to pass the MOT and want the turbo to boost as much as possible? Unless you want the valve after the turbo and only divert EG to the DPF under MOT testing and normal testing free flow.
Old September 13th, 2017, 09:19   #12
turbobrick240
turbobrick240's Avatar
The wastegate is pre-turbo. You'll also lose power when it opens. I'd just tune out a few hp if it's really a problem for the dpf(going to need a new tune regardless). Really doubt it would be necessary to tune out 60 hp.
Old September 13th, 2017, 17:12   #13
GoFaster
Moderator at Large
Why are you attempting to do this?
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
GoFaster is online now   Reply With Quote
Old September 13th, 2017, 17:28   #14
tom101
Hope you are right. I'm asking my chiptuner a soft al least agressive as stage 2+, but with safe limiters when high temperatures or pressures are reached.
I got the dpf cleaned with liquid in a machine. The result was so good.
If I got dissapointed with the result, probably I will try a wastegate, my first idea was to place it between turbo and dpf, but it's not that easy as use EGR pipe.
Old September 13th, 2017, 17:33   #15
Enabled
It seems he is trying to bypass the DPF partially when exhaust pressures are high (high engine load). Bypassing it would reduce the soot accumulation somewhat, yes, and car wouldn't complain on emissions inspections.
I don't think it's too terrible idea, just don't know how much it would help though, if it's not too much exhaust being rerouted.
-2003 Jetta TDI GLS Manual (Mods: SBC II Daily, .681 5th, VNT17 & PP520, Self Tuned)
-BMW 328is Manual (heavily modded 220whp, track toy)
-BMW Z3 Roadster (Fun in the sun car)
-BMW Z3 M Coupe (1 of 36)
-BMW 328d wagon (Self tuned ~220hp)
Enabled is offline   Reply With Quote
A4 3.0 TDI (B8) DPF back full 3" exhaust system Bobby Singh Private TDI Items for Sale/Wanted 3 February 24th, 2016 08:34
VW Mk6 TDI exhaust / DPF , EGR ETC. F/S Sctdi123 Private TDI Items for Sale/Wanted 16 December 3rd, 2015 13:27
Mk6 tdi dpf/exhaust for sale. Diesel252 Private TDI Items for Sale/Wanted 2 October 13th, 2015 07:41
Milltek GTD DPF back exhaust on CR 140 TDI??? baj0411 TDI 101 0 February 18th, 2015 18:18
WTB: rawtek full exhaust/dpf kit for my TDI. tbone1989 Private TDI Items for Sale/Wanted 5 May 20th, 2013 18:40
Page generated in 0.16562 seconds with 11 queries
[Output: 130.07 Kb. compressed to 108.36 Kb. by saving 21.71 Kb. (16.69%)]
