Old September 7th, 2017, 18:01   #1
PHOEN1X
Default stage 5 malone custom tune need help
HI everybody!
First sorry for my bad english i'll try do my best
I have some questions about a tune that I've just done on my volkswagon golf tdi 2006 BEW.
Before I put the stage5 custom I changed:
-vnt15 smart actuator for custom one without EGR pipe and smart actuator.
-dualmass flywheel for Corrado single mass flywheel who can handle about 300lbs of torque.
-2.5 map sensor for a 3.0 map sensor.
-make it strate pipe without muffler.
And everything else is stock part. When I went to tune it at VAG motosports I said the modification i've made and they tuned it. Since that time I'm running on a stock pipe from the turbo up to the intake manifold and they begin to leak and put me into limp mode some times.
So my questions is that I was wondering on puting a bigger intercooler like a front mount but it will make a big diference on a TDI engine? and I was wondering too if I had to put a blow off valve or something like an antilag boost systeme on it? my peak boost is aroud 35psi and maybe over.
If you think I missed something on my mecanic modification and my engine or other part is going to die if I don't do it please tell me what it is in the comment and also thank you in advence guy!
PHOEN1X is offline   Reply With Quote
Old September 7th, 2017, 18:57   #2
Owain@malonetuning
You could always contact us directly. What turbo and nozzles are you running? a VR clutch is not suitable for a heavily modified BEW.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old September 7th, 2017, 19:58   #3
Nevada_TDI
^^^ Just ask Owain, he can get you where you want to go.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old September 9th, 2017, 11:52   #4
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Stage 5? is that like 400+ hp? just joking but it sounds ridiculous if its not something like DS car
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old September 9th, 2017, 13:00   #5
eddie_1
eddie_1's Avatar
fais attention! 35psi signifie la mort pour le turbo!! Malone a vous donne un tune stage 5 pour un vnt15???!!!
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old September 9th, 2017, 13:15   #6
Owain@malonetuning
Yes it's only for big turbos/custom builds 1756 minimum, not super popular on the PDs over here unfortunately but nice to see the crazy builds now and again. Normally done direct with data logging etc since they're all unique beasts.
I
As mentioned, it sounds like you bought the wrong file. Haven't heard from you but that poor turbo is not going to last very long if you're requesting way too much boost from it. Please get this resolved sooner than later so you're not shopping for parts.
Old September 9th, 2017, 19:22   #7
Enabled
If it hasn't blown up yet, you significantly reduced bearing life anyways.
I can't imagine stock-ish fueling hardware ever needing that much air anyways. But I've seen plenty of users slap on large turbos, get them tuned to 22-24psi, and run stock pump and nozzles (on VE TDI)... just silly.
-2003 Jetta TDI GLS Manual (Mods: SBC II Daily, .681 5th, VNT17 & PP520, Self Tuned)
-BMW 328is Manual (heavily modded 220whp, track toy)
-BMW Z3 Roadster (Fun in the sun car)
-BMW Z3 M Coupe (1 of 36)
-BMW 328d wagon (Self tuned ~230hp)
Enabled is offline   Reply With Quote
Malone stage 1.5 tune lbundy Private TDI Items for Sale/Wanted 4 October 21st, 2015 01:23
Win a custom Malone tune installed in person by *Mark Malone* @ SOWO 2015 AARodriguez Corp. Vendor & GroupBuy items for sale 13 March 2nd, 2015 14:11
Malone stage .5 tune garrington TDI Power Enhancements 11 January 6th, 2015 18:27
99.5 ECU, Custom stage 3 Malone tune $350 shipped Peach State TDI Private TDI Items for Sale/Wanted 8 November 30th, 2014 18:03
Malone 1.5 vs Malone 2.0 vs Custom Tune skromfols TDI Power Enhancements 4 June 26th, 2014 17:57
Page generated in 0.14967 seconds with 11 queries
[Output: 83.89 Kb. compressed to 73.03 Kb. by saving 10.86 Kb. (12.94%)]
