Old September 7th, 2017, 12:05   #1
archemitis
archemitis's Avatar
Default ALH coolant flow question
Sorry to ask such a seemingly easy question to answer, but... Which way does the coolant flow on an ALH? Thermostat routed to the lower radiator hose or upper? Thanks in advance. Every diagram I clicked on was a bad link.
archemitis is offline   Reply With Quote
Old September 7th, 2017, 13:50   #2
2many diesels
Tstat is on the lower hose. Coolant flows in there and out through the head to the top radiator hose...Hope this helps
2many diesels is offline   Reply With Quote
Old September 8th, 2017, 16:16   #3
archemitis
archemitis's Avatar
Talking
Thanks so much! I was pretty sure untill I saw a few conversions done backwards!
Old September 10th, 2017, 05:16   #4
jimbote
jimbote's Avatar
yeah, and those guys will find out soon enough that when the coolant gets just a little bit low the water pump stops pumping
Old September 10th, 2017, 08:47   #5
Lone Ranger
TDI(s): TDI Ranger
It is still odd the way VW plumbed it
Normally the tstat is on the hot hose on top(relatively speaking)of the engine
Took me awhile to get my head around this, as there is a passage in the block where the coolant(hot) passes over the tstat
Lone Ranger is offline   Reply With Quote
Old September 10th, 2017, 20:30   #6
A-man930
Having the thermostat at the lower hose is quite common in all modern-ish engines from all manufacturers. When the thermostat opens in this arrangement, the relatively low temperature coolant from low part of the radiator comes into contact with it immediately, causing it to shut sooner or at least not open as far as it otherwise would if it were at the upper hose. The effect is less drastic swings in engine temperature during operation. Emissions
A-man930 is offline   Reply With Quote
Old September 14th, 2017, 08:24   #7
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
emissions, and far more stable operating temperatures. That gives you more consistent performance and makes it easier to tune
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old September 16th, 2017, 16:08   #8
Lone Ranger
TDI(s): TDI Ranger
Yep, I wasnt knocking it. It performs flawlessly.
Just for a small block ford guy this arrangment is kinda backwards
In winter with no coolant glow plugs and egr put to the lowest possible it struggles to stay in the 80s. As soon as it idles its 55-60 in about 3 minutes. I've thought about a temp jerry rig to move it to the top hoses and would if I knew it would make it a little warmer haha
Old September 20th, 2017, 09:33   #9
TDIJetta99
TDIJetta99's Avatar
Get yourself a 92C thermostat and call it a day.. Napa part number ATM-143992K2 for a Calorstat brand, or ATM-TX1392D for Behr brand.
I have the Calorstat one in mine and it will run 197-204F on my Torque app on the highway even when it's -15F outside..
Old September 20th, 2017, 09:41   #10
vanbcguy
vanbcguy's Avatar
Veeeery common for these thermostats to stick partly open or start opening early as they age... The location is fine, you may have a weak t-stat.
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old September 27th, 2017, 09:24   #11
AndyBees
AndyBees's Avatar
The return coolant from the Oil Cooler, Expansion Tank, EGR Cooler, and Heater Loop all end up at the Water Pump housing where the T-stat is located. That source of "hot" coolant is what causes the T-stat to open and allow flow from the radiator bottom hose. That design or very similar, goes all the way back to the 1974 VW Rabbit engines.
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
AndyBees is online now   Reply With Quote
Old September 27th, 2017, 16:56   #12
jimbote
jimbote's Avatar
good point
Old September 27th, 2017, 17:12   #13
diesel sammy
What happens when there is no thermostat installed.
I just found that my AHU did not have one
diesel sammy is offline   Reply With Quote
Old September 27th, 2017, 18:06   #14
AndyBees
AndyBees's Avatar
Diesel Sammy, with no T-stat, the engine could actually run hot as the coolant would flow through the Rad too fast (especially in summer). During the winter months, the Engine would not warm up to normal operating temp.
Old September 27th, 2017, 18:16   #15
AndyBees
AndyBees's Avatar
FWIW, I've seen Threads/Posts about "trapped" air in engines, especially Subie engines in the Vanagons. My experience, the VW engine coolant system purges air extremely well. I've never had an issue purging air out of the coolant system in the ALH in my Vanagon ................ long rad hoses and heater hoses all the way to the front (engine in rear)...... never an issue!
The Water Pump is extremely efficient moving the coolant. I have the expansion tank tapped for a fitting, tube, etc., to a pressure gauge up front in my Vanagon. The gauge registers from 0-15 PSI. The coolant system very seldom goes above 7 to 9 psi. ........... As for efficiency, when I rev the engine or as I go through the gears, RPMs climbing, I can see the pressure drop because the water pump is pulling coolant out of the expansion tank (as well as the other returns)... very interesting !
ALH Hard Coolant Pipe question tophergrace TDI 101 4 June 25th, 2014 22:39
General Coolant Flow Question shinghi VW MKIV-A4 TDIs (VE and PD) 6 April 4th, 2013 05:40
99.5 Jetta w.alh coolant temp sensor question veedubcanuck TDI 101 2 November 5th, 2012 05:18
ALH coolant question (sorry, no time to search) CubbyChowder VW MKIV-A4 TDIs (VE and PD) 5 November 3rd, 2010 13:01
Coolant flow question (98 jetta) Vinyl_Addict TDI 101 0 April 6th, 2008 10:19
Page generated in 0.14370 seconds with 11 queries
[Output: 127.64 Kb. compressed to 106.39 Kb. by saving 21.25 Kb. (16.65%)]
