Old September 9th, 2017, 02:17   #16
altz1
TDI(s): Allroad, A8
Very good job!
Sorry if its dumb question, but this engine has solenoid injectors or piezo? Probably solenoid as piezo still nobody makes larger?
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
Audi Q7 4.2TDI 410hp, 900nm. - Sold
Allroad C6 under construction, 420hp goal.
BVN 4.2TDI project twin gtd2060vzk, 650hp goal.
altz1 is offline   Reply With Quote
Old September 9th, 2017, 02:27   #17
ryanp
ryanp's Avatar
We chose Solenoid for simplicity, we can sell larger Piezo too.
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old September 9th, 2017, 06:35   #18
eddie_1
eddie_1's Avatar
Brilliant! Congrats! Almost a clean lambda too.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old September 10th, 2017, 05:54   #19
mk1-83
Fuel Economy: 1:15
Nice to see it all workd out fine setting a good time for a fwd tdi.
With 52/74 comp like bw efr
What turbine wheel ? There are not many choices to fit in the vnt.
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old September 11th, 2017, 08:26   #20
[486]
TDI(s): 02 golf ALH
Originally Posted by ryanp View Post
We have a larger pump almost ready to install, we mod them here effectively. Over winter we are going to fit the pump to the Aux belt so we can be a little more experimental without busting rockers and engines! I dont think we will ever need the stroker pumps etc. 2 small ones would be a cheaper solution if we need to!
Compressor is 52/74 iirc. The turbo works so well i'm very happy, we have fitted the same turbo to daily cars and it works a treat!
a Mk1 golf could be lighter!
Yeah when you're making brackets anyways it's certainly cheaper to run two factory cp3s than an aftermarket one that can be sold. Can sell the brackets too, once they're figured out.
Now I'm wondering what that thing'd do with an s475 strapped on top of what you've got there. Once it's back to having enough fuel, that is.
Mk1 might be lighter, but def. not cheaper than a 10yr old generic economy car, especially around here where we get salt on the roads :\
[486] is online now   Reply With Quote
Old September 13th, 2017, 21:52   #21
Diesl
To make it from 0 to 60 mph in 2.26 seconds, you need very very very sticky tires, since you are accelerating at something like 1.25g. Not saying it's impossible, but getting a friction coefficient greater than 1 is not easy. You're sure that was not a typo?
If it works, take it apart and find out why!
Diesl is offline   Reply With Quote
Old September 14th, 2017, 00:14   #22
ryanp
ryanp's Avatar
This information is taken from our performance box and is accurate for the 1/4 mile time compared to the slips. We had more than one low 2s time. The track and tyres are very good. On road tyres it would be 4 or 5s at best if you could get a good hook up
Old September 14th, 2017, 06:34   #23
mk3pd
Lupo 3L Ryan
Can't be much lighter than that,or perhaps a completely rusted out MK1 he-he
www.rosten-performance.com
mk3pd is offline   Reply With Quote
Old September 14th, 2017, 06:45   #24
ryanp
ryanp's Avatar
Rust is lighter than steel!
Some guys have less than 750kg!
Old September 14th, 2017, 06:46   #25
ryanp
ryanp's Avatar
Johan has the 3L Lupo with TFSi, not sure on his weight, would have been faster with TDI, ahahaha
Old September 14th, 2017, 06:58   #26
mk3pd
Almost exact time and trap speed i believe
9,77 something,but only got a run or two due to broken gearbox
I guess traction is the same issue wether its diesel or gasoline...
Old September 14th, 2017, 07:02   #27
ryanp
ryanp's Avatar
Yeah its odd that Johan (or Iwan who is driving!) breaks things more than the TDi. I think they are a good comparison as we have about the same torque as they have power and vise/versa (at a guess)
They would be quicker as the day progressed, shame we did not have spare gearbox to get them back on the track!!
Old September 14th, 2017, 07:46   #28
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Fits and motivates a mk2 GTI very well, even basically stock (minus basic emissions delete tune)
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
schnellvw.com
GTiTDi is offline   Reply With Quote
Old September 16th, 2017, 01:31   #29
ryanp
ryanp's Avatar
Just checked, at a 'bad' track we pull 1g, at Santa pod according to the Racelogic Performance box we pull 1.3g with a spike to 1.4g
Old September 21st, 2017, 14:51   #30
prodrive
We start with GTB core, lots of machining!
How do you know if it's not you who make them?
Bmw compact 3.0d gt40v
TurboTech
prodrive is offline   Reply With Quote
153mph Darkside Volkswagen Jetta TDI - 146mph Standing Mile ryanp TDI Power Enhancements 35 January 3rd, 2013 17:09
Common Rail TDI Heater Kstjarre_TDi TDI 101 11 January 16th, 2011 06:38
2.0 common rail tdi enhancements! tdipower4me TDI Power Enhancements 11 October 13th, 2006 13:05
Honda Common Rail TDI dieselmeister TDI Fuel Economy 25 January 15th, 2003 17:52
Honda Common Rail TDI dieselmeister TDI Fuel Economy 4 December 30th, 2002 11:32
Page generated in 0.16738 seconds with 11 queries
[Output: 137.02 Kb. compressed to 115.16 Kb. by saving 21.86 Kb. (15.95%)]
