Old September 7th, 2017, 01:46   #1
ryanp
ryanp's Avatar
Default 500hp+ Common Rail TDi - 9.7s 1/4 Mile @ 146mph - Aiming for 600hp, 9.49 @ 150mph+
VIDEO of 2 Runs
SPEC LIST and PICS
Some quick figures
0-60mph - 2.26s
0-100mph - 4.76s
1/2 Mile Top Speed - 164.031mph (30% Nitrous)
I think the time with Zero Nitrous is also worth a mention - 10.4908s @ 130.27mph
We still have plenty more work to do and have never had 100% NOS! We are on the limit of the fuel pump but have larger injectors and a larger turbo to test once we have that fixed.
Happy to answer any questions!
Thanks for all the help from certain individuals and companies!
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old September 7th, 2017, 02:32   #2
Johnny10bx
TDI(s): 1.9 M-TDI
Nice results. 👍🏻
Which turbo are the basic for gtd2874vr?
GTD2060vz or a other one?
Johnny10bx is offline   Reply With Quote
Old September 7th, 2017, 03:14   #3
ryanp
ryanp's Avatar
We start with GTB core, lots of machining!
Old September 7th, 2017, 04:05   #4
Johnny10bx
TDI(s): 1.9 M-TDI
BMW or Audi GTB?
Old September 7th, 2017, 04:07   #5
Jukums
As can seen in picture, then there is used BMW GTB2260 CHRA and hot side. And in BMW CHRA ar milled in ball bearing without water cooling ? There is used ceramic ball bearing ?
Is there still used 5mm shaft ?
What boost are you running ?
And how much rpm engine revs with power ?
Jukums is offline   Reply With Quote
Old September 7th, 2017, 11:12   #6
DkZ
Fuel Economy: 7.5 / 6 / 4.5
Little beast on fire, great job guys, keep showing us what the 2.0 tdi CR is capable of :P
DkZ is offline   Reply With Quote
Old September 7th, 2017, 11:31   #7
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
good job
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old September 7th, 2017, 14:01   #8
TDIsyncro
TDIsyncro's Avatar
TDI(s): Audi/TDI x 2
Fuel Economy: 50-60mpg HWY, depending on speed and wind
Most excellent achievements Ryan! Lets keep pushing it!!
2001 Audi A4 - New Project - 2.0TDI CR 450HP All Turbo
http://forums.tdiclub.com/showthread.php?t=270527
2007 Canyon w/2011 TDI CJAA CR
http://forums.tdiclub.com/showthread.php?t=415533
TDIsyncro is offline   Reply With Quote
Old September 7th, 2017, 15:19   #9
Owain@malonetuning
Congrats! Been waiting to see deeper 9s all season, so close to that 150 mark. Keep up the great work, this build is mental. Always nice to see people push the envelop like this.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old September 7th, 2017, 20:26   #10
andy2
andy2's Avatar
I was almost going to post your results in the 1/4 mile times thread thinking that you might not bother
What is the car weight including driver ?
Congrats on the achievement ! That engine sure snaps to life quickly when taking off.
andy2 is offline   Reply With Quote
Old September 8th, 2017, 00:21   #11
ryanp
ryanp's Avatar
Originally Posted by Johnny10bx View Post
BMW or Audi GTB?
BMW hot side but larger than BMW compressor
SHaft is a little larger, no Water cooling. Running 3bar boost, makes 400+hp NO NOS and did 10.4s 1/4mile.
Dyno graph on link, makes full boost at 3400rpm without trying, full power almost to 5800rpm. EMP are very low.
YES WE WILL!
the 9.72 run was with a 0.1s slower 60ft than the previous fastest run and a late gear change that hit the limiter
I'll share the slip on there shortly.
Weight is around 860kg with driver so 1895lbs. 785kg without driver.
We are still 0.1 to 0.2s away from our 60ft target but getting that is not achieved by power, its just practice and car set-up!
Old September 8th, 2017, 06:59   #12
InfoSec
Fuel Economy: 48-55mpg
You can crate that bad boy up and ship it to me in Grand Rapids, Michigan... I'll IM you my credit card number...
The Master of InfoSec - Current '03 Jetta GLS TDI: 02M, Wavetrac LSD, Whitbread downpipe and custom IC piping, Race 520's, VNT1756vk, upgraded SMIC, EGR Delete (obviously), Buzzken 2.5" cat-back w/ turndown, Malone Stage 5 custom, PDlift pump, ARP Head Studs, Phase II: head work, bigger turbo, hotter cam, better pistons/rods, new tires...at least the front ones.
InfoSec is offline   Reply With Quote
Old September 8th, 2017, 07:17   #13
ryanp
ryanp's Avatar
I'll sell anything for a price! haha
Old September 8th, 2017, 19:28   #14
[486]
TDI(s): 02 golf ALH
Neato!
Smaller turbo than I'd think. Says something for how well you've got the motor flowing. Compressor dimensions?
Gonna stick another CP3 on it, or get together some custom pump?
man, I wish we got lupo chassis cars here
[486] is offline   Reply With Quote
Old September 9th, 2017, 01:57   #15
ryanp
ryanp's Avatar
We have a larger pump almost ready to install, we mod them here effectively. Over winter we are going to fit the pump to the Aux belt so we can be a little more experimental without busting rockers and engines! I dont think we will ever need the stroker pumps etc. 2 small ones would be a cheaper solution if we need to!
Compressor is 52/74 iirc. The turbo works so well i'm very happy, we have fitted the same turbo to daily cars and it works a treat!
a Mk1 golf could be lighter!
153mph Darkside Volkswagen Jetta TDI - 146mph Standing Mile ryanp TDI Power Enhancements 35 January 3rd, 2013 17:09
Common Rail TDI Heater Kstjarre_TDi TDI 101 11 January 16th, 2011 06:38
2.0 common rail tdi enhancements! tdipower4me TDI Power Enhancements 11 October 13th, 2006 13:05
Honda Common Rail TDI dieselmeister TDI Fuel Economy 25 January 15th, 2003 17:52
Honda Common Rail TDI dieselmeister TDI Fuel Economy 4 December 30th, 2002 11:32
Page generated in 0.17751 seconds with 11 queries
[Output: 134.51 Kb. compressed to 112.79 Kb. by saving 21.72 Kb. (16.15%)]
