Old September 5th, 2017, 20:31   #1
Bobob729
TDI(s): Jetta
Default 07 Gti Fahrenheit CJAA Swap
I have my 07 gti fahrenheit 33/1200 that i will be swapping in a cjaa and also doing a manual swap at the same time. I will be posting pics here soon when i can figure out what to use now that photobucket seems to want to charge you now to show photos other places.
Mods to the cjaa will include
malone gtb turbo manifold
gtb2260 turbo
dpf and egr delete
darkside intercooler upgrade
4 bar map sensor
cp3 pump upgrade
intake flapper delete
southbend stage 3 clutch
30lb flywheel
fluidampr harmonic balancer
2 micron filter housing and filter
stock diesel lift pump
3" Darkside Dpf Delete Downpipe
hoping to make close to 240hp ish
and will be swapping it in the starting sept. 22 and hoping to have it done within a few days this one should be pretty simple just like my audi tt swap i did. Biggest part of this swap will be the wiring. Which i have started looking at wiring and biggest changes will be in the bigger ecu plug. But i think i have all that figured out. Will end up having to wire in glow plug relays and few other things.
Bobob729 is offline   Reply With Quote
Old September 6th, 2017, 13:06   #2
vwztips
vwztips's Avatar
Good luck. I am doing something similar except into a 2012 Tiguan. I have spent the past couple of weeks on the 2 wiring harnesses to try and make sure it goes as smooth as possible. I have most of it done. Now on to the mechanical part!
vwztips is offline   Reply With Quote
Old September 6th, 2017, 16:04   #3
Bobob729
TDI(s): Jetta
Ya the wiring is by far the worst of the swaps. But really not to terrible just have to move a few pins and should be fine
Old September 18th, 2017, 17:34   #4
dieselherb1
Like 50+ pins
dieselherb1 is offline   Reply With Quote
Old September 18th, 2017, 18:53   #5
vwztips
vwztips's Avatar
Well the CJAA in the Tig is now running and have all relevant code issues taken care of. Now on to the tune, some deletes and cleaning up the wiring harness. Just takes a lot of patience and persistence. Also help from Marin, and a couple of guys at MyTiguan which are in Portugal and Russia
Old September 18th, 2017, 20:06   #6
Bobob729
TDI(s): Jetta
Originally Posted by dieselherb1 View Post
Like 50+ pins
ya but shouldnt be to big
Old September 18th, 2017, 20:15   #7
Bobob729
TDI(s): Jetta
how did you go about setting up the cruise to work correctly. Right now that's my only issue with wiring i'm trying to figure out
Old September 19th, 2017, 07:18   #8
vwztips
vwztips's Avatar
Mine was probably more straightforward since I went from a 2013 Golf to a 2012 Tig. I was able to bring the ECU and IC from the Golf, then make sure the clutch and brake signal were getting to the ECU, then finally making sure the ABS and IC were coded correctly.
FWIW, the both cars use a non-mechanical sensor to detect the brake pedal position and it is on the bottom of the master cylinder in the engine compartment. I did have to put the one from the Golf into the Tig as there was a difference and my brake lights stayed on all the time with the Tig switch and the Golf ECU
Old September 19th, 2017, 08:08   #9
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
What did you do for gearing in the Tig? Retain the stock transmission or frankenstein the golf trans with the existing Tig differentials?
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old September 27th, 2017, 23:23   #10
Bobob729
TDI(s): Jetta
Well finally got started last Saturday and got the engine in and started swapping the fuel tank. Then Sunday finished the fuel tank and routed lines, added fuel filter setup, swapped from Auto to manual parts,. Then Sunday decided it was time to start wiring so started and finally finished on Wednesday just have to crank engine to start once I get a new starter. But only codes I have are for stuff I don't have installed so I think my wiring is all good but will find out tomorrow
Old October 7th, 2017, 22:26   #11
Bobob729
TDI(s): Jetta
So still working the tune out. And swapped to newer abs module just need to code it. And does anyone know much about making cruise control work?
Old October 18th, 2017, 05:35   #12
dieselherb1
Matt the cruise control wiring is on here.
Old October 18th, 2017, 13:50   #13
Bobob729
TDI(s): Jetta
i got the cruise and everything wired correctly, it shows it's supposed to work in vagcom just isn't activating even though everything is showing correctly i'm gonna try to figure it out more next week when i get back in town
Old October 24th, 2017, 06:28   #14
dieselherb1
Having issue with turbo not boosting. Actuator is pushing the vanes closed I think, it is pushing down when engine is running. Getting code for MAF and MAP.
Old March 18th, 2018, 09:12   #15
Strider17
TDI(s): MK4 and MK5
im doing a b6 passat swap to CJAA has 2.0 TSI with auto.
did you run into any issues swapping the auto to manual?
Strider17 is offline   Reply With Quote
GTiTDi's 2.0 CJAA swap-->mk2 GTI STANDALONE GTiTDi TDI Conversions 28 March 8th, 2018 20:49
Instaliing GTI leather seats in 07 TDI Gabbaking TDI 101 1 February 29th, 2016 09:54
rear brake pad replace 07' GTI sgnhis TDI 101 1 December 21st, 2010 15:45
Pics of 18" GTI Fahrenheit Charleston Rims on MK6 biby VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 21 March 27th, 2010 18:45
GTI Fahrenheit? Deezel77 Ontario 18 September 13th, 2008 17:34
Page generated in 0.17154 seconds with 11 queries
[Output: 121.98 Kb. compressed to 101.55 Kb. by saving 20.43 Kb. (16.75%)]
