Old September 5th, 2017, 11:13   #1
stefan2m
Default Rate my intended combination (pd130)
There are so many combinations to make when upgrading parts.
My car is a '03 Euro 3BG pd130 and is stock other than a remap, resulting in a healthy 174hp and 374Nm(/275lb) on the dyno.
Because of it's age and mileage, the car nearing economical end of life, so other than maintenance I don't really want to pump a whole lot of money in this car anymore to get the most out of it; the exhaust is rusty, dented and patched up, has a rattle so I was thinking of replacing the old chimney front to back.
One thing that is not expensive, is a 2.5" downpipe; on a turbo petrol car I owned years ago, a step up from a 2.5" dp and 2.25" exhaust to a full 3" system (and supporting remap) meant a healthy power increase and a much broader powerband and a nicer engine character.
So I was wondering what I should expect from a bigger downpipe (I can piece together an exhaust myself to keep cost low, but I'll have to buy the downpipe) and what I can expect from upgrading the 2" iirc exhaust too.
All I've come across is fears about sound levels, so I already know what to expect there; I'd like to know how the engine will react to the mod.
2003 3B6 PD130/AWX H5 'Reflex Silver'
VVT remap 175hp/375Nm
stefan2m is offline   Reply With Quote
Old September 7th, 2017, 19:18   #2
3L3M3NT
3L3M3NT's Avatar
With the larger exhaust you'll notice faster spool up of your turbo and a throatier sound to your car when you get on it in each gear.
I'm not sure how much of a power increase you'll see with going to a larger exhaust system...
Sturgeon Bay, WI GTG/Cruise October 21st, 2017
http://forums.tdiclub.com/showthread.php?t=480490
3L3M3NT is offline   Reply With Quote
P2015 and now P0544 -- what to do? had intended on buyback but not so soon codex VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 7 November 15th, 2017 13:41
Ethanol Not As Green As Intended jbright General Automotive 18 December 2nd, 2013 22:26
Comments on intended path for VE/2003 Wagon Genesis TDI Power Enhancements 6 August 9th, 2012 16:11
What are good aftermarket oil filters (not intended for TDI) NewbieBaby VW MKIV-A4 TDIs (VE and PD) 0 December 5th, 2001 21:18
Cetane 101 or What Fuel Was Intended For Our TDI Turbo Steve Fuels & Lubricants 71 January 6th, 2001 10:10
Page generated in 0.10063 seconds with 11 queries
[Output: 53.17 Kb. compressed to 49.05 Kb. by saving 4.12 Kb. (7.74%)]
