Old September 2nd, 2017, 06:32   #1
DDCS
Default Audi A4 B7 BRD couple upgrade questions
Hi! Some cool cars around here! I've decided to make my car a bit faster. I've read a lot of threads, but just want to be sure, so here goes:
Now I have a pipercross free flow airfilter added, and next week I'm gonna have custom exhaust (60mm) made dpf and egr are already off and removed, new injectors are fitted. My goal is to have reliable 210-230bhp. I have some concerns: 1. Is stock turbo enough for that? 2. I'm concerned about intercooler, because those stock SMICs looks ****ty and just for safety and health of the engine I'm thinking of adding fmic: 550x140x65. It seems like an easy fit below the licence plate bar. Does this help with intake temps? Because afaik it will have a direct flow of fresh air and wouldn't be trapped somewhere on the side with no way for hot air to disappear. Or maybe smic will cope just fine with the power I need? I don't see point of adding a larger fmic because it would partially be covered behind number plate bar in the grill...
DDCS is offline   Reply With Quote
Old September 2nd, 2017, 07:37   #2
DDCS
If you're a bit confused with description, the circled area in photo is what I meant for ic placement, obviously behind the grill.
https://ibb.co/b5Au4F
Old September 4th, 2017, 01:11   #3
duke21
TDI(s): 2.0 TDI BMN
Fuel Economy: 7.0L/100km
Your stock turbo is enough for 220hp. I had run 216 and 430nm in Octavia. Only had DPF removed. You can go to 250 if you want, and best route is gtb1756 turbo.
duke21 is offline   Reply With Quote
Audi a4 b7 2.0tdi brd turbo upgrade letkuteb TDI Power Enhancements 1 September 6th, 2017 06:19
Audi A4 B7 (8ED) Power Upgrade zak196 TDI Power Enhancements 0 December 2nd, 2015 10:57
Theos Audi A4 B7 Quattro TheoSweden TDI Power Enhancements 219 October 5th, 2015 13:37
Audi A4 3.0TDI B7 Quattro A430TDI TDI Power Enhancements 15 January 3rd, 2015 02:30
Audi A4 B7 engine/tuning questions. TheoSweden TDI Power Enhancements 3 August 9th, 2011 11:42
Page generated in 0.11585 seconds with 11 queries
[Output: 57.93 Kb. compressed to 52.45 Kb. by saving 5.48 Kb. (9.47%)]
