Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old September 1st, 2017, 10:39   #1
Default Transmission oil change kit
Instead of buying the kit they sell to change tranny oil, I bought a 2 gallon pump up garden sprayer for 16 bucks, ordered a new oil plug for the tranny, drilled it out and tapped for a 1/4 inch threads. bought a 1/4 male x barbed brass adapter at the local hardware to install into the tapped drain plug. and about 8 foot of clear 1/4 id tubing. Installed the tubing thru the adapter on the sprayer housing and feed enough for it to rest in one of the molded foot depressions inside on the bottom, and pushed the other end on the barbed fitting (got to tighten the housing adapter and ensure the plastic ferrel is installed correctly). Got about 26 bucks in this and it works really well. Have used it at 40K and again at 80K. Have this one marked for VW usage. Have done the same with a one gallon to use with Ford LV Mercon to flush the lines and Torque converter out. Garden sprayer should have the right seals/O-rings to withstand the chemical used in lawn and garden applications
pikewrench is offline   Reply With Quote
Old September 7th, 2017, 04:36   #2
Victor Huge
Victor Huge's Avatar
TDI(s): 2001 Jetta
Do share some photos, sounds like a good tool you made up. Have to do this soon as well
Victor Huge is offline   Reply With Quote
Old September 7th, 2017, 11:51   #3
Dunno513's Avatar
Fuel Economy: 44.5 lifetime
Default even easier way with no waste
$2 oil fill tube / adapter sold at Walmart and a Gatorade bottle. Tip of oil tube is a tight fit in the oil filter orifice, cut the bottom of the bottle out, small bungee cord to keep it upright and fill er up. 5l out, 5l in. bing bang boom. Tube even has a handy cap to keep oil drippings to a minimum.
I believe I owe Herm the honors of the tube adapter to speed it along. I had used a long transmission funnel before. Much faster and no watching oil drain out of the housing.
its called a trans and oil spout Walmart # 554059544.
Dunno513 is offline   Reply With Quote
OEM VW/Audi DSG transmission fluid change kit $100 shipped bmwM5power Private TDI Items for Sale/Wanted 0 May 18th, 2017 16:05
FS: 6L Castrol TXT 505.01 & A5 BRM Oil Filter (Oil Change Kit) Nash_TDI Private TDI Items for Sale/Wanted 9 December 15th, 2010 08:36
Oil change kit??? Sheepfarmer Fuels & Lubricants 29 September 8th, 2010 09:04
Oil Change Kit Price Change? clean97z VW MKV-A5 Golf/Jettas 5 October 17th, 2007 04:02
Transmission Oil Change Big Red Fuels & Lubricants 4 June 12th, 2000 04:52
Page generated in 0.11525 seconds with 11 queries
[Output: 58.18 Kb. compressed to 52.67 Kb. by saving 5.51 Kb. (9.48%)]
