Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old September 1st, 2017, 09:51   #1
Default 80K maintenance problems
As I was finishing the transmission oil filter change 0n my 2013 TDI SE my dash lit up when I started the vehicle to bring it up to temperature. After finishing the transmission, I shut the vehicle down and read the codes that were responsible for the lights. First one that caught my eye was a bad O2 sensor, these had just been checked and replace with the diesel recall a couple of weeks prior. A clearing of these code bought me new ones when I started, ran in place and rechecked. A 4629-ECM Power Relay load Circuit, and 17262 Terminal 30. Checked each of the relays as suggested in another thread, all were good. Only affect electrical component during this maintenance was the removal and replacement of the battery to gain access to the transmission filter. After starting it several times in a row, it failed to start on the fourth try-power flashed on and off at that point. Had no other sign of any problem up until this time. A quick battery check showed that it had gone bad, the movement of taking it out and put back in had been enough to disturb the internals. Replaced battery cleared codes and started and drove, by the time I went 100 foot the rest of the codes for the ABS, steering, and tires pressure cleared. Doing maintenance is not a good time for something like this to happen!
pikewrench is offline   Reply With Quote
Old September 3rd, 2017, 09:25   #2
TDI(s): 2010 jetta
Fuel Economy: best tank 50.6, worst 36
better now in your driveway than later in the snow out in a parking lot. If it was that close to failure it would have been soon. I think you got lucky.
My battery decided to give out several years ago 10 pm, leaving on a long trip next morning early. But I felt lucky also. could have lasted 12 more hours, until at a rest stop middle of nowhere. It gave out at the fuel station across street from Walmart. I usually avoid that place, but they were open and there.
2010 jetta, 6sp man, & tdiclub plate frame ..build date 08-09
1956 Buick Special (my dad bought it brand new)
1946 Luscombe 8E
jetlagmech is offline   Reply With Quote
Old September 4th, 2017, 09:25   #3
Ol'Rattler's Avatar
So what happened? I didn't see anything out of the ordinary.
What was the "quick check" you did? Doing any kind of check on a dead battery usually gives you erroneous results.
What I do is put it on a charger overnight the day before it goes back in the car and if the charging amps gets down to two and the battery voltage is correct, the battery is good. The charging amps on a bad battery will stay at 4 to 6 amps and if there are shorted cell(s) the battery voltage will be low.
Of course a 5+ year old battery owes you nothing.............
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
80k maintenance cost gte770m VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 August 18th, 2016 19:11
80k maintenance & then ECM relay went...could this be related? imtnbike VW Passat Family (NMS and B7) TDIs (2012+) 0 June 14th, 2016 18:28
80k BRM 5m maintenance ssamalin TDI 101 12 July 16th, 2009 19:22
80k maintenance program FL2AK-tdi VW MKIV-A4 TDIs (VE and PD) 1 April 3rd, 2007 09:22
80K Maintenance 3rs VW MKIV-A4 TDIs (VE and PD) 2 September 13th, 2005 23:20
Page generated in 0.11789 seconds with 11 queries
[Output: 58.85 Kb. compressed to 53.51 Kb. by saving 5.33 Kb. (9.06%)]
