Old September 1st, 2017, 05:43   #1
Jetmugg
TDI(s): None
Default TDI swap into '73 Opel Manta - which transmission?
For "inline" conversions, what is a good/popular transmission to use behind an mTDI converted AHU?
I see the off-road crowd using Toyota truck 5-speeds or JEEP stuff, but it seems like this might not be a great choice for a small, light, sporty car like an Opel Manta.
I've done a google search, but haven't come up with anything handy in terms of a modern 5 or 6 speed trans that is readily adaptable to a TDI engine for a longitudinal conversion.
I figured it would be a good idea to start with this question on the best source of TDI info before digging too deep down any other rabbit holes.
Thanks,
Steve.
Jetmugg is offline   Reply With Quote
Old September 1st, 2017, 17:36   #2
Zeitgeist
Zeitgeist's Avatar
First off, you probably need to find out the ring and pinion ratio before settling on a transmission. I think the original Opels of that era used a 1.9L gasser with sub-100hp, so the R&P ratios were probably short to compensate. It could be a cool project.
'87 300TD OM606t
'90 300D OM602t
'89 Vanagon Bluestar ALH mTDI
'01 Eurovan Weekender AXK --> (ALH Syncro?)
Past: '96 Passat 1Z
Zeitgeist is offline   Reply With Quote
Old September 5th, 2017, 12:47   #3
Jetmugg
TDI(s): None
Will most likely be an ALH (or possibly AHU) 1.9L TDI, converted to mechanical TDI by way of a Dieselmeken-modified injection pump and injectors. The stock rearend ratio is either 3.44 or 3.67 (need to check this particular car), but there is also a 3.18 ratio available from an Opel Kadett. It looks like I will be running 205/50/15 tires, so about 23" diameter.
Old September 5th, 2017, 12:49   #4
Jetmugg
TDI(s): None
I can picture it in my mind, blowing puffs of black smoke between shifts, carving corners and turning heads....
Old September 5th, 2017, 12:54   #5
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Well unless it is sick or overfueled, it won't be blowing black anything.
The Toyota 20R/22R/22RE was also used in Celicas and Coronas, not just trucks. And the later Aisin 6sp manuals that are used in the later trucks are also used in the IS250 and the Cadillac CTS, oddly enough. So I would not brand the "truck" transmission all that special that it cannot or should not be used in anything else.
Neat project. There was a guy here not all that long ago at a show that I saw that had a Manta with a "modern" Opel driveline in it from a Saturn Sky.
oilhammer
www.cardocautomotive.com
Old September 5th, 2017, 14:29   #6
Jetmugg
TDI(s): None
Thanks - I'll have to look into the IS250 / CTS versions of the Aisin transmissions. The key will be getting it to "bolt up" to the VW block, typically by means of an adapter plate.
Any idea if the Aisin versions use an integral bellhousing, or a design with interchangeable bellhousings?
Steve.
Old September 5th, 2017, 14:43   #7
A-man930
Steve.
As I understand what is the Jeep AX15 5-speed exists in multiple forms across multiple makes. Of notable mention are the Supra and the Sky / Solstice; "sporty cars" that used variants of this design. Some have interchangeable bells but some do not. I'll have to re-find some of the resource articles that have been written on this and post up the link(s).
An adapter from EVguy or Acme or whoever should be available to get you hooked up to a trans. in this family that suits your needs.
A-man930 is offline   Reply With Quote
Old September 5th, 2017, 15:02   #8
Nice swap idea. I always liked the Opel Manta. I had the good fortune of renting one with my Dad on my first trip to LA in 1974, and we drove up the coast to San Francisco. Nice driving car, despite the rental being an automatic, of course. Great idea for a TDI swap.
I'd encourage you to consider swapping an engine harness and not going mTDI. There's a lot to gain from keeping the drive by wire aspect of the TDI, in power and fuel economy. And it's not too difficult, at least according to folks who've done it in Rabbits and Ford Rangers, if you get an non-immo ECU and engine harness. Something to consider.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old September 6th, 2017, 09:51   #9
smelly621
If using a EVguy or Acme adapter plate for the 22r you will need to use a w56 (G52 may also work?) bell housing. You can then bolt several different w-series transmissions to that same bellhousing depending on what gear ratios fit best with your application as discussed.
I would second the advice to stay eTDI - ditching the wiring for the pump doesn't really save you that much work - and then you lose a lot of tuneability. IMMO is no big deal to turn off if you find a newer donor. Most tuners charge very little to do this - or if you find the right software online you can do it yourself in 5 min.
smelly621 is offline   Reply With Quote
Old September 6th, 2017, 10:22   #10
Jetmugg
TDI(s): None
Thanks, everyone. I still have a lot to learn about the various transmission options / adapter plates / combinations. This forum is a big help.
As far as the mTDI versus electronic control, I have worked with Goran Lindgren (Dieselmeken) on several projects previously. He will be supplying the injection pump and injectors for this engine. The Manta may be used as a test-mule for a 1.9L TDI which could find its way into a land speed racing application.
Steve.
AHU/ALH Eurovan T4, about transmission (5th gear swap, 02A swap) X@V TDI Conversions 46 March 24th, 2014 16:15
tdi swap transmission speedpepino VW MKIV-A4 TDIs (VE and PD) 5 February 22nd, 2014 19:28
VW Golf TDI BlueMotion gets 73.5 mpg trev0006 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 12 June 27th, 2013 08:03
Opel GT swap? jimbobb2 TDI Conversions 8 December 5th, 2012 09:09
Opel TDI TDItech TDI Conversions 6 October 6th, 2005 05:25
Page generated in 0.14404 seconds with 11 queries
[Output: 97.01 Kb. compressed to 82.74 Kb. by saving 14.27 Kb. (14.71%)]
