Old September 1st, 2017, 05:02   #1
bhodgkiss
Default 03G145702F (2.0tdi 140bhp turbo) max boost?
Hi All
This is a GT1749VA turbo fitted to the 2.0tdi 140bhp Audi A4 b7 model
Does this have the same max boost capacity as the slightly older VA's as fitted to pd130 awx/avf B5.5 Passat's? So a safe 1.5bar?
To me it looks the same other than having an egt boss
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old September 1st, 2017, 12:35   #2
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Basically same yes. In lower rpm range you can boost up to 1.6-1.8bar for good torque. In upper rpm 1.5 is fine.
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Max Stock Turbo Boost Pressure? (+ Other Turbo Talk) AceTdi VW MKIV-A4 TDIs (VE and PD) 10 May 26th, 2017 11:11
MK6 GOLF 2.0tdi 140bhp - help identifying map addresses WoodieGuthrie TDI Power Enhancements 1 October 29th, 2015 08:28
GTB2260 on 3.0TDI, max safe boost? BuzzKen TDI Power Enhancements 17 May 8th, 2015 15:17
buying a 2005.5 Audi A4 2.0TDI 140bhp Carl2k7 TDI 101 12 December 8th, 2010 15:14
Turbo VW/Audi HGR 03G145702F 2.0 TDI TURBO 05-08 dieseldragon Private TDI Items for Sale/Wanted 7 November 24th, 2010 04:07
Page generated in 0.10937 seconds with 11 queries
[Output: 52.33 Kb. compressed to 48.20 Kb. by saving 4.13 Kb. (7.89%)]
