Old August 31st, 2017, 11:08   #1
Nevada_TDI
Default Another Nozzle Balancing Option
I just heard from Mark@DFIS in Portland; although they do not sell aftermarket nozzles if you supply them with your own nozzles they will mount and balance for $36.00 each.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old August 31st, 2017, 19:18   #2
Rrusse11
http://www.conestogadiesel.com/services/injectorrebuilding.html
For those in the NorthEast, these folk have done 2 sets for me.
With supplied nozzles and a set of injectors, cost me $120 for 4.
Give Suzy a call, nice folks to deal with.
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3bar MAP:2.5" Exhaust: Koni Reds HD Springs, ~1"lift:VR6 fr swaybar, Top strut & rear tie bar: XXIO Racing Rims, 215/55ZR16 GMax AS03's, 10mm/20mm spacers, 35# @: Ventectomy: Atlas skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: Bosal Hitch: VW racks:
Rrusse11 is offline   Reply With Quote
Old September 2nd, 2017, 15:55   #3
Nevada_TDI
Thank you Mr. Russell, now everybody knows there's one place on the west coast and one place on the East Coast.
_______________
Old September 2nd, 2017, 20:27   #4
Rrusse11
I would like to point out that diesel technology is widespread. There are a LOT of industrial diesel applications. In rural areas, find out who the farmers are taking their tractors too. Big trucks are everywhere, so are the shops that fix them. On the coast? Check out marine mechanics; fishing boats, trawlers, tugs, are running all kinds of diesel motors. Look for who is supplying those backup generators to hospitals.
These forums are automobile oriented, think outside the box. If the local diesel shop can't do the work, they should be able to help you at least find, or recommend, the appropriate person/business who can clean, test, and balance your VW injectors.
My $.02,
R*2
Old September 2nd, 2017, 21:54   #5
Nevada_TDI
Mr. Russe11, you are correct there are many different application for diesel motors from boats and ships to 18 wheelers, and tractors to high powered toys; I will have to plead ignorance when it comes to the TDI injectors specifically; I don't know if most diesel shops have the right tooling and testing equipment to work on our TDI injectors and nozzles. I know that DBW of course does, and DFIS as well as they rebuild the VE pumps our TDI's use. Maybe I have tunnel vision when it comes to this subject; speaking strictly of of my personal ignorance of the rest of the diesel powered world, I will send my stuff only to businesses that have a positive track record of rebuilding/repairing the equipment specific gear that I use. If I have to wait a few extra days (which is the situation I am in now due to the USPS) so be it, but the next time I hear a strange noise under the hood, I won't wonder if it is due to my being a hurry or trying to save money using an un-tested shop to rebuild my parts.
_______________
Old September 3rd, 2017, 04:13   #6
Most any Bosch fuel distributor can mount and pop test rotary pump TDI nozzles.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old September 3rd, 2017, 05:40   #7
Rrusse11
For those on the other side of the pond;
http://uniteddiesel.co.uk/
Good information on the whole injector process.
Darksidedevelopments.co.uk also offers a variety of nozzles and
mounting services.
Old September 3rd, 2017, 10:55   #8
Nevada_TDI
IBW, thank you for the heads up, I learned something new today for those of us on this side the pond.
_______________
Old September 4th, 2017, 18:25   #9
MRGRNJNS
@IndigoBlueWagon, I stopped by the local Bosch Injector Repair Shop in Akron Ohio. They are not equipped to do 2-Stage Pop Testing. I may be giving Suzy a call!
MRGRNJNS is offline   Reply With Quote
Nozzle replacement injector balancing? Northern Mike TDI 101 23 June 14th, 2014 10:44
Can someone please explain Nozzle balancing?? blu_jet_92 TDI Power Enhancements 3 April 5th, 2011 13:39
Nozzle Pop Testing / Balancing DownLow Atlantic Canada 3 November 17th, 2010 10:54
vnt15 .46 nozzle. larger than .42 stock nozzle *Garrett* TurboBugger Private TDI Items for Sale/Wanted 5 October 1st, 2010 04:15
VW Drivers Option finance option kwa General VW Discussion 3 August 8th, 2003 00:35
Page generated in 0.14529 seconds with 11 queries
[Output: 93.62 Kb. compressed to 80.11 Kb. by saving 13.51 Kb. (14.43%)]
