Old August 31st, 2017, 07:56   #1
3baudios
3baudios's Avatar
TDI(s): 00 golf GLS
Fuel Economy: 49
Default tdi into 80's toyota van
Has this swap been done? they are RWD so i would assume they share the transmission with a toyota 2wd truck? is there enough room?
91 Audi 200 20v 35r 400ish WHP
00 Golf GLS, Evry mod, 2.5" buzzken exhaust
93 Eurovan CE
00 suzuki drz400e
3baudios is offline   Reply With Quote
Old August 31st, 2017, 09:13   #2
Bad_Vision
The alh TDI is taller then the 22r engine. For my swap I had to do 2" body lift to shut the hood and to clear the vacuum pump against the firewall. Not sure the van would clear but as for the trans it will mate for sure with the adapter plate sold by Acme.
Sent from my XT1635-01 using Tapatalk
Bad_Vision is offline   Reply With Quote
Old August 31st, 2017, 10:06   #3
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
I didn't get a chance to work on many of these back in the day, but my memory is that the stock gasser engine is canted at something like 45 degrees from vertical.
My guess is that you would need to do the same, perhaps working to shorten the height of the intake manifold.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old August 31st, 2017, 15:00   #4
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Raise the dog house!
1.9ZOOK is online now   Reply With Quote
Old August 31st, 2017, 18:58   #5
GoFaster
Moderator at Large
The Toyota TownAce sold in North America as the Van used the 4Y pushrod engine and it's sitting vertically. I don't know for sure but I suspect that engine is even shorter than a 20R/22R. The obviously OHC engine in the photo is probably a 2C non-turbo diesel. I'd say there's a fighting chance that the VW engine block and head would fit in the van but the accessories around it are anyone's guess; it's a pretty tight engine compartment. I can tell by the photo that the intake manifold on the VW engine is on the "wrong" side compared to the original Toyota diesel engine. The later Previa is the one with the engine canted over at a steep angle.
It's been a long time since I've seen one of the TownAce-style Vans on the road. Around here, they all rusted out a long time ago, and weren't considered to be worth saving. I drove one of these once when shopping for a vehicle back in the day. Slow, and yet scary at the same time. Best way to describe ride and handling is that there wasn't any.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old September 1st, 2017, 02:12   #6
jimbote
jimbote's Avatar
i have a 2ct lite ace and the engine is nowhere near 45 degrees, maybe you're thinking of the previa that had a nearly horizontal four config ? i think an ALH could be made to fit as it's not really much taller than a 2c and i have to disagree on it being taller than a 22r (which was never offered in a NA toy van) 22r is a very tall four banger with it's massive VC housing an oversized rocker rail ... ALH is a relatively compact power dense unit
Old September 1st, 2017, 02:17   #7
jimbote
jimbote's Avatar
the van trans, if manual, is a modified version of the w series truck box, so theoretically you could use a 22r bell and a craptastic a**e adapter ... or you just buy this entire lite ace 2ct 4wd i have rotting away and swap the entire driveline
Old September 1st, 2017, 03:28   #8
3baudios
3baudios's Avatar
TDI(s): 00 golf GLS
Fuel Economy: 49
The van sold very quickly. I'm trying to find something that will seat the whole family and I can put my ALH into
93 Eurovan CE
00 suzuki drz400e
Old September 1st, 2017, 03:35   #9
Windex
Windex's Avatar
Mazda 5
Old September 1st, 2017, 04:20   #10
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Lots of Vanagon VAG inline engine swaps running around. Someone here even has one with an ALH in it.
oilhammer
www.cardocautomotive.com
Old September 1st, 2017, 05:27   #11
vtpsd
Fuel Economy: 45mpg avg
ALH jetta wagon? already comes with factory TDI conversion.
current: 03 jetta wagon (pp520, malone stg3, straight pipe), ford tractor with saab turbo, Snarling Audi 90q AHU swap (holset he211w, 32psi, race 520's)
past:11 second audi 90 20vt monster, 20vt swapped audi 90 winter beater, 10vt swapped 4kq with efi and many many other 5 cylinder audis, and a few 1.8tq's
vtpsd is offline   Reply With Quote
Old September 1st, 2017, 05:59   #12
3baudios
3baudios's Avatar
TDI(s): 00 golf GLS
Fuel Economy: 49
I've had a vanagon, they rust out quickly and are now becoming very very expensive. Looking for something that seats six or seven and was built before 1995 . Don't want to have to plug it in for state inspection
93 Eurovan CE
00 suzuki drz400e
Old September 1st, 2017, 06:27   #13
Windex
Windex's Avatar
FWD, seats 6 - 1966 Olds toronado:
Perfect car to convert
Old September 1st, 2017, 08:37   #14
3baudios
3baudios's Avatar
TDI(s): 00 golf GLS
Fuel Economy: 49
Awesome!!!
93 Eurovan CE
00 suzuki drz400e
Old September 1st, 2017, 08:43   #15
oilhammer
oilhammer's Avatar
And the Toyotas didn't????
In your area especially, ANYTHING from 1995 and older is likely to be riddled with rust issues, and anything that you'd buy from that era that has not been subjected to the salt will soon be.
I am not sure what exactly you are after here, nor do I know how large your family is (or will be). However I do think that any older vehicle, especially something as fiddly and hands on as something that has an engine swapped into it that was not there before, is going to fall far more into the hobby car category than a reliable family vehicle.
And I am also not sure that going for something that old strictly to avoid an annual inspection is necessarily the wisest choice either, given the fact that it will almost certainly be less of a headache to maintain a newer as-built vehicle, inspections and all, to carry your family around. Even if it is gasoline fueled.
oilhammer
Tdi Van! Funguy Sightings 3 October 28th, 2006 21:34
Just drove a diesel Toyota Van Mike_04GolfTDI General Automotive 10 February 14th, 2005 09:48
80's Toyota diesel pickup Greck57 Non VW Group Diesels 1 January 31st, 2005 20:44
1996 Toyota HDJ-80 in the US for sale! Oil_Burner Non VW Group Diesels 10 January 1st, 2005 02:08
"VAN-VAN" Social Event - Baseball Game Frank Doherty West Coast Canada/USA 7 June 6th, 2001 11:39
Page generated in 0.15763 seconds with 11 queries
[Output: 130.47 Kb. compressed to 108.68 Kb. by saving 21.79 Kb. (16.70%)]
