Old August 31st, 2017, 04:29   #1
Ethankei
Default Speedometer not working on my TDI
Hi the speedometer on my 2003 tdi won't work. The jetta had a automatic to 5 speed swap, and it hasn't worked since. I put a new gearbox speed sensor in it, and the gear is not striped out in the transmission so It has to be electrical. I have seen that some people run the speedometer wires from the gear box speed sensor to the original automatic transmission control module. If anybody has had problems with this or knows what is is please let me know
Ethankei is offline   Reply With Quote
Need help diagnosing speedometer not working MadScience VW MKIV-A4 TDIs (VE and PD) 6 March 19th, 2017 16:41
Speedometer/Odo/Cruise Not working (99.5 TDI Golf 5-speed) Roma VW MKIV-A4 TDIs (VE and PD) 7 January 19th, 2015 15:48
speedometer not working, new speedsensor Karmaxl OBD Scanners 0 May 10th, 2013 09:31
Help, Speedometer Stopped Working mike VW MKIV-A4 TDIs (VE and PD) 15 January 17th, 2011 17:42
speedometer/odometer not working '88 golf diesel?? Other VW Group TD(I)s 6 October 20th, 2006 08:20
Page generated in 0.12035 seconds with 11 queries
[Output: 46.25 Kb. compressed to 43.58 Kb. by saving 2.67 Kb. (5.78%)]
