Old August 28th, 2017, 13:54   #1
Bad_Vision
Default Spend my money!
Ok guys I have completed my TDI swap.
https://r.tapatalk.com/shareLink?url...1&share_type=t
1987 Toyota Pickup completed swap.
Now I want to plan for upgrades.
I need more low end power faster boost and good toruqe.
Now whenever I ask someone what should I do they start throwing out numbers like 512 and 17/22 I'm confused because it's my first TDI and first Diesel and first turbo.
If someone can provide a link to a package or a link to good parts that will go good with a new tune from Malone please chime in!
Sent from my XT1635-01 using Tapatalk
Bad_Vision is offline   Reply With Quote
Old August 28th, 2017, 15:21   #2
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
If you are running the stock vnt15 you should have really good off-idle boost and torque. Have you done a log to make sure everything is operating as it should? How much vacuum are you sending to the turbo actuator at idle? If all you are after is early torque then I would suggest more fuel and keep the small turbo.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old August 28th, 2017, 16:22   #3
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Unless I'm missing it somewhere there is no mention of what or which TDI engine you put in.
If it is from a 1999 to 2004 it is an ALH engine and there should still be injector nozzles available from some of the club vendors. Just put bigger nozzles in, but that also involves getting the Malone re-tuned. If it's an ALH you probably have .205 stock nozzles and I think that is what the 512 means that you mentioned. 512 does not mean the nozzles are 5 times larger, just someones name for larger nozzles. I believe the 17/22 means going to a larger turbo from a 15 stock. A 17 or a 22.
The recommendation used to be to change nozzles first.
I also think if it is a 2005 and up the nozzles are much more difficult to change. But I've been wrong before this year.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.Average 1 year 30/6/16 to 30/6/17 - 50.71 Mpg - 5.56 L/h
Jetta_Pilot is offline   Reply With Quote
Old August 28th, 2017, 16:52   #4
Owain@malonetuning
What nozzles? Try a stage 3 before you consider swapping turbos
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old August 28th, 2017, 19:26   #5
Bad_Vision
Sorry forgot to put that in.
ALH with stage 1.5 tube from malone. Everything else is stock.
23lbs of boost and yes getting overboost but only in 5th gear doing 55mph. It's built to be a trail truck so it never overboost on the trails
I set the vacuum for the turbo to actuate 5hg start and 18hg full engaged.
Old August 28th, 2017, 19:49   #6
Nevada_TDI
23 pounds of sustained boost will grenade your stock turbo, There is something going wrong with a 1.5 Stage tune making that kind of boost. I would run logs and see what is really happening before you swap any parts. I am sure Owain would be glad to look at your logs and see what is causing that much boost to be happening.
_______________
2001 Jetta GL TDI, 35/15% Tint, Ventectomy, Catectomy, EGR-ectomy, Stage 4 TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old August 28th, 2017, 21:47   #7
Bad_Vision
Already did logs when I sent them to Malone all they could tell me is it wasnt supposed to do that and to set my vacuum. The vacuum is correct and the vnt moves freely. I didn't want to put a whole bunch of time and effort into that smaller turbo if I was going to upgrade anyway.
Old August 28th, 2017, 23:46   #8
Nevada_TDI
The guys at Malone are pretty sharp when it comes to this kind of thing, yet their response is really lacking, could I look at your logs? Do you have 3rd gear pull logs and highway logs as well? I am really interested in what your N75 valve is doing at WOT and at steady-state highway speed.
_______________
Old August 29th, 2017, 01:18   #9
Owain@malonetuning
https://log.malonetuning.com/chart/3...Ojw4LClsKNAAAA
N75 is maxed out and it's still off the map, only got the one log. Asked him to try adjusting the actuator and explained the behavior and correlation of each column, didn't get back to me. Only so much I can do.
Old August 29th, 2017, 08:15   #10
FraggyTDI
TDI(s): 04 Jetta
Sorry slightly off topic but your log viewer is AWESOME!!! Just another reason why I use Malone. Reminds me a lot of the software I use at work AVL Concerto.
FraggyTDI is offline   Reply With Quote
Old August 29th, 2017, 08:35   #11
Bad_Vision
When you told me to adjust the actuator I replied and told you multiple time that it was set to OEM standard starting at 5hg and full open at 18hg. It's set properly, you then suggested the vains in the turbo where bad or gummed up. So instead of messing with turbo I'm thinking replace it with a better upgrade.
The overboost issue is not a problem if I'm going for more power anyway with a different Turbo
Old August 29th, 2017, 09:28   #12
greengeeker
I agree with Owain on the condition of the turbo...you're not tracking with requested at all. Unless the vane control ring is significantly worn, your problem lies with the control system and will persist even after you swap turbos.
Considering your application I wouldn't go with a 17/22 or even a GTB. I would go with one of the newer gtc or gtd smaller turbos which provide awesome off-idle boost capabilities but are capable of very decent power. It likely will require a fair amount of fabrication but if you're this far I think you would be well within your capability.
- Nick -
Old August 29th, 2017, 10:11   #13
Owain@malonetuning
Thanks Fraggy Sean (one of the web developers) and Mark put a lot of work into it. Many more things to come, that is the start of a complete platform. Site might not have changed much over the last five years but there are some massive back end changes going on.
It's fairly common that the OEM setting will need adjustment. In this case, it seems to be WAY off. I'll see a wave of over to underboost back to overboost through 2000-3500 or so with the N75 over-correcting on probably around 10% of tuned cars with new turbos. Slight adjustment of the actuator fixes it.
The VNT15 is a fantastic turbo and they're pretty well bulletproof, plus you can pick them up at junk yards for cheap. Running one on a fairly smokey tune should give you plenty of bottom end torque. Something like a 1756 is going to sacrifice 200-300RPM of low end spool, but is a totally different animal above 2500. For off road if you're crawling around at ~1100 and jabbing the throttle here and there in second at low speeds, the responsiveness of the stock unit would at least be worth trying out. Considering you'll be looking at nozzles anyway, it's less work and cheaper than swapping turbos.
Old August 29th, 2017, 10:44   #14
Nevada_TDI
Bad Vision, there are times when the turbo factory settings for some reason just aren't getting the job done; my turbo doesn't operate properly if I use the "factory settings." On the ALH motors the N75 valve works backwards to what we would think is normal... When the N75 is at, say 25%, that is the N75 applying full vacuum to spool thew turbo, when the N75 valve is at, say 90%, it is trying to bleed off the vacuum to reduce boost. So regardless of what the factory settings are for "start and stop" on the actuator vacuum wise, I will bet a box of doughnuts that if you make the actuator arm longer the spikes will come under control so you can get a set of meaningful logs. I would imagine Owain has said something very similar to this--minus the doughnuts of course--give this suggestion a try, will you?
_______________
Old August 29th, 2017, 13:13   #15
Bad_Vision
I will play with it but I for sure want injectors because I have heard that when you do that it creates a totally different machine.
So let's get a tune and injectors.
Keeping the stock vnt 15
What injectors and nozzles would you recommend then? And is it worth monkeying with the adjustment before the nozzles and injectors?
Spend my money for me. mrfrankmrfrank TDI Power Enhancements 6 April 20th, 2015 14:51
spend my money for me blackout06 Upgrades (non TDI Engine related) 6 March 2nd, 2007 12:39
Spend my money 1fastredsc TDI Power Enhancements 54 October 15th, 2006 23:02
Help me spend my money Cabrales OBD Scanners 5 July 27th, 2006 06:29
I have some money to spend H's '97-TDI TDI Power Enhancements 5 April 16th, 2001 18:30
Page generated in 0.18779 seconds with 11 queries
[Output: 132.13 Kb. compressed to 111.09 Kb. by saving 21.04 Kb. (15.93%)]
