Old August 30th, 2017, 14:56   #16
papasmurf
papasmurf's Avatar
Yes those are the measurements but the inlet and outlet are on opposite sides. Top left and bottom right
papasmurf is offline   Reply With Quote
Old August 30th, 2017, 15:40   #17
diesel sammy
That radiator is for the 200tdi there opposing sides 300tdi are on yhe same side from what I have seen.
Thank you for confirming the measurements for me I really appreciate it.
diesel sammy is offline   Reply With Quote
Old August 30th, 2017, 18:06   #18
papasmurf
papasmurf's Avatar
Ahh yes thats right. 300tdi is on the same side. We don't do a lot of 300tdis, just 200tdi, 2.5,2.8 international and well, a bunch of ls3s that we put in defenders. If there are any other things you need me to look at, just let me know. Sometimes I get real busy but I will get back to you
Old August 31st, 2017, 02:21   #19
diesel sammy
Cool I appreciate the offer.
Old August 31st, 2017, 06:27   #20
compu_85
Gadget Guy
compu_85's Avatar
Originally Posted by vanbcguy View Post
The IDI stuff definitely generates a lot more heat in the coolant faster. At full load (keeping in mind there's a lot more output at full load on a TDI) I don't think their requirements are that different.
Having owned a couple IDI cars, I can tell you their overall heat output to the coolant is much higher than a DI engine. Even with a larger aluminum radiator my Mercedes will sometimes need to kick the fans on to stay cool on the highway. IDI engines generate an incredible amount of heat in the cylinder head, no matter what operating condition.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old August 31st, 2017, 07:15   #21
diesel sammy
That kind of what i thought that they put out more heat.
Being this radiator is for a tdi diesel and it bigger diesel it should work
Old August 31st, 2017, 08:10   #22
papasmurf
papasmurf's Avatar
Yes a lot of these trucks are not that bad, takes a bit to get up to temp and I'm in Florida not to mention pushing a 5k lb brick down the road
Turbocharger for Land Rover 300tdi kepsu TDI Power Enhancements 8 February 20th, 2017 14:19
Land Rover's 2015 Defender (Diesel) MarcusW General Automotive 5 October 24th, 2011 19:05
Diesel Land Rover Defender on e-BaY gearhead Non VW Group Diesels 1 September 16th, 2002 01:47
Land ROver 300TDi Tad Non VW Group Diesels 9 July 16th, 2002 01:05
Page generated in 0.13932 seconds with 11 queries
[Output: 80.48 Kb. compressed to 70.03 Kb. by saving 10.45 Kb. (12.99%)]
