Old August 23rd, 2017, 00:57   #1
speedy223
Default intake upgrade question
have an Old man intake upgrade from kerma. does not have CCV input. worth installing on alh to replace cruddy plastic pipe that hooks between turbo and accordion from airbox or just leave it alone. again. no way to route ccv in to intake since no ccv hole in it. best to leave it alone and just cuss kerma for selling a newb that pipe 3 years ago or so with no warning as to deletes it would require? or worthwhile to install? paid an armload for that thing when i was first building an alh and had no idea what i was doing...still dont know much but know enough to tell that kerma was really sorry on their support.
speedy223 is offline   Reply With Quote
Old August 23rd, 2017, 09:13   #2
Yourbuddysatin
I have the darkside TIP which is almost the same. I didn't put my ccv in the intake. I just left I plugged in and tucked it behind the pipe work.
Yourbuddysatin is offline   Reply With Quote
Old August 23rd, 2017, 09:55   #3
FraggyTDI
TDI(s): 04 Jetta
You can vent it to atmosphere. I would either get a longer hose and run it to the ground or get a catch can setup for it.
FraggyTDI is offline   Reply With Quote
Old August 23rd, 2017, 11:38   #4
speedy223
thanks for the replies. no problems or regrets at all deleting ccv? , no chance of sucking dust in to my valve cover at any point? i drive on a really dusty road
Old August 23rd, 2017, 12:21   #5
\/\/0J0
\/\/0J0's Avatar
Fuel Economy: At least 2x that of my TJ
Your engine produces some amount of blow by with each combustion event. Couple that with the vacuum pump that empties into the crankcase and you should have no worries about sucking anything in through the ccv
Sent from my mobile look-at device
I miss my TDi
"Those willing to sacrifice Liberty for Security deserve neither" -Ben Franklin
\/\/0J0 is online now   Reply With Quote
Old August 23rd, 2017, 12:33   #6
FraggyTDI
TDI(s): 04 Jetta
You can put a small filter on it but usually it gets saturated with oil. You won't have any problems with dust.
Old August 23rd, 2017, 13:27   #7
20IndigoBlue02
20IndigoBlue02's Avatar
drill a hole into the OMI and line it with a grommet, so it looks like a OMI with a CCV hole
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old August 23rd, 2017, 17:30   #8
Yourbuddysatin
Not at all. Do like the other guys said to. Put your own catch can on. That way you don't get blown by on the valve cover and misc other things.
Old August 25th, 2017, 21:50   #9
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Most tractors back in the day vent straight out to atmosphere. More dust in daily field work then a gravel road once in a while.
Sent from my SM-G900V using Tapatalk
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car-4 door, 1.9 TD aaz, 5 spd
1981 Caddy VW truck-Topper with it
2004 Golf-2 inch lift, Q-loader stage 1 tune
Vag-Com owner
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old August 31st, 2017, 19:10   #10
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
Semi trucks vent to atmosphere, all heavy equipment does as well.
I have the same pipe from Kerma and love the look, and I purposely purchased it because it didn't have the bung. I vent straight to the ground.
Oil doesn't need to be in the intake. Just my 2 cents.
2K jetta gl tdi 5spd 391k, RC5+, 17/22, PP764's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Upgrade Intake morpwr TDI Fuel Economy 4 October 6th, 2013 16:44
Intake manifold upgrade Jakobicev TDI Power Enhancements 9 December 24th, 2010 01:53
AHU Intake Attachment Upgrade darkscout VW MKIII-A3/B4 TDIs 16 August 16th, 2010 03:57
PD100 Intake Upgrade ???'s 3L3M3NT TDI Power Enhancements 3 July 28th, 2009 19:59
Intake Manifold upgrade v8 coupe TDI Power Enhancements 6 July 1st, 2009 12:28
Page generated in 0.14547 seconds with 11 queries
[Output: 95.75 Kb. compressed to 81.26 Kb. by saving 14.49 Kb. (15.13%)]
