Old August 14th, 2017, 21:26   #1
Machineman
Default Possibly the first v10 tdi dpf/egr delete w/o pulling engine?
I just wanted to say I managed to do a DPF and EGR Delete without pulling the motor on my v10 treg I have done a lot of research prior with many results coming up as drop engine. For anyone contemplating this it is doable with a lot of patience.
Start by removing all the EGR up top this will gain in the room to get your arms behind to remove the bolts for the downpipes the driver side is a lot easier three of my studs snapped off this was very painful to remove
Machineman is offline   Reply With Quote
Old August 15th, 2017, 06:57   #2
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
Nice work!
Not sure why the picture shows up rotated on my end.
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline   Reply With Quote
Old August 15th, 2017, 08:06   #3
psst1997
psst1997's Avatar
Very nice! Previous owner of mine dropped them and gutted them without engine removal. Maybe I need you to make me dpf delete pipes along with the EGR delete's as well!
97 Passat - VNT 17, PP520, PD130 intake manifold, PD150 lift pump, 2.5in turbo back straight exhaust, 2.9Bar Map, Malone Stg4 tune.
psst1997 is offline   Reply With Quote
Old August 15th, 2017, 11:40   #4
Lightflyer1
Lightflyer1's Avatar
Rotated and huge! Please resize pics to fit the page to stop having to scroll to read the posts. Or post a thumbnail linked to the full size photo.
2015 Beetle TDI.
Old August 15th, 2017, 15:54   #5
Machineman
Thanks for the link I actually have always had this problem
Old August 15th, 2017, 16:19   #6
1.4TDI PD
TDI(s): 2.5TDI V6
Nice work when i was doing the egr delete on my 2.5tdi v6 i thought that i am going need to remove the turbo but after 3 hours of work i finally removed the egr pipe underneath the turbo and instaled egr delete kit. I still need to do a cat delete then my engine will be runing even nicer.
1.4TDI PD is offline   Reply With Quote
Old August 15th, 2017, 21:17   #7
kooyajerms
grocery getter
kooyajerms's Avatar
Next task for you is to figure out how to pull the turbos without fully dropping the engine
On blocks and in the driveway even better. I'll mail you some west coast IPA's.
kooyajerms is offline   Reply With Quote
Old August 16th, 2017, 19:46   #8
Machineman
I think that might be impossible have you done it before?
Old September 11th, 2017, 13:55   #9
Premier Sprinter
I didn't remove my engine to delete my DPFs and EGR last winter... but the engine is out now. The turbos really didn't like all of the freedom and one let go.
I posted the ECU files that I wrote so that there is no CEL once deleted in the Facebook TDI tuning group. It's definitely worth getting a KESS and saving the $1,000+ to have a tuner do it for you.
Premier Sprinter is offline   Reply With Quote
Mk7 golf TDI DPF/EGR DELETE onykid978 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 44 November 15th, 2017 05:51
CR DPF delete, mid pipe, & Darkside EGR delete. GTSLOW Private TDI Items for Sale/Wanted 10 May 29th, 2017 15:23
Brand New/Unused Buzzken MK5/6 TDI Downpipe dpf/egr delete eurojet Private TDI Items for Sale/Wanted 2 April 29th, 2015 17:47
WTB: CR TDI DPF/ EGR delete Biggu Private TDI Items for Sale/Wanted 0 April 19th, 2015 09:44
Page generated in 0.12988 seconds with 11 queries
[Output: 90.13 Kb. compressed to 76.94 Kb. by saving 13.19 Kb. (14.63%)]
