Old August 13th, 2017, 19:44   #1
Paulsta
Default Loss of power and hight EGT
Hi i have a AHU with a unknown tune .215 injectors in a Westfalia.
This setup has been running fine for 3 years, and all of a suden, i have very little power, and my EGT is around 1500F.
i connected a vagcom and would like to know if these are normal values.
Test was done on a flat road no hills
At 3300 RPM accelarating EGT 1500F
injection quantity is 49.6
mod piston displ. is 4.240
coolant 87
MAP is around 1450 to 1550
Paulsta is offline   Reply With Quote
Old August 16th, 2017, 05:58   #2
mk1-83
Fuel Economy: 1:15
Stuck timing cylinder in pump
Loss of pump case pressure check valve
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old September 6th, 2017, 07:07   #3
Paulsta
I also found that i had fault code 00550
i tried changing the 3rd injector sensor, and that didn't solve the probleme.
Eventualy ( yesterday ) i changed the injection pump, and that solved the probleme.
Paul
Old September 10th, 2017, 07:02   #4
mk1-83
Fuel Economy: 1:15
Nice its solved
Dissamble the pump and see if something is wrong
Lupo 1.9 tdi
300+ HP 500 nm
Old September 10th, 2017, 12:58   #5
Owain@malonetuning
I would try measuring block 11 to see how boost is behaving, sounds like you have a leak or something which is resulting in excessive fueling. You can drag/drop .csv files onto our website as well to graph them and then zoom in/out as you please.
MAP should go up more towards 2 bar, or 14.5 PSI.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
B4V Loss of MPG, intermittent power loss tibbittsa VW MKIII-A3/B4 TDIs 4 March 29th, 2017 23:07
Voltage loss/ power loss/ 04 golf cuts off Wine Master VW MKIV-A4 TDIs (VE and PD) 25 October 3rd, 2016 08:16
Loss of accel. power/now loss of electrical power Christina VW MKIV-A4 TDIs (VE and PD) 8 February 1st, 2014 21:51
01 Gold TDI, power loss, more power at half throttle, has power add ons. Help? TRICKTDI TDI 101 7 October 29th, 2011 18:01
small loss of power, large loss of mpg JeffTDI TDI 101 0 July 21st, 2008 04:29
Page generated in 0.14541 seconds with 11 queries
[Output: 67.92 Kb. compressed to 60.13 Kb. by saving 7.79 Kb. (11.47%)]
