Old August 30th, 2017, 10:13   #16
andrewjb
Originally Posted by jsrmonster View Post
That ED ecu supports oem Usa/ahu wastegate turbo. It is RC stage 3 and won't run right on your vnt-turbo based engine. It is socketed, but if you remap it with euro (vnt) afn110 firmware it will need the matching eeprom programmed also to work properly with immo deleted.
I offer this service every day. If you mix up wrong sw and hw you can expect problems. You can use a boostvalve to limit max boost at a minimum so you can drive it.
Jeff
Can had been running fine for 2-3 years previously, its not just been done recently. its just started playing up recently.
I'm not sure if the map sensor is playing up its giving an error code of 00519 manifold abs .press . sens short circuit to b+
andrewjb is offline   Reply With Quote
Old August 30th, 2017, 10:15   #17
andrewjb
Originally Posted by bhodgkiss View Post
It may well be an upgrade 3bar MAP sensor if a hybrid pd150 has been run, although 10mm pump/0.216 nozzles wouldnt give enough fuel to need to run more than 1.5bar boost....
Was told by old owner it is a 3bar map sensor from "Audi RS2" never seen the inside of my ECU.
Old September 1st, 2017, 23:13   #18
andrewjb
god news the ECU is socketed
what is the map sensor? and best way to replace?
Old September 4th, 2017, 11:21   #19
andrewjb
Anybody know of a replacement map sensor I can have resoldered onto the ECU that acts as a 3 bar one?
Old September 4th, 2017, 13:33   #20
Owain@malonetuning
More likely to be a solder point, got ya covered if you can't find one domestically. Please downsize those photos though
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old September 5th, 2017, 06:38   #21
andrewjb
most forums I go on automatically scale them lol
Old September 8th, 2017, 04:21   #22
andrewjb
map sensor now on the way from Malone Tuning
Old September 29th, 2017, 06:22   #23
andrewjb
Still on the way, bloody snail mail.
Mk3 B4 1z / AHU - ECU / ECM + RocketChip Stage 2 vwsnaps Private TDI Items for Sale/Wanted 21 January 7th, 2015 15:32
ALH Caddy 9K1 turbo issues after playing with ecu's... poxxxy TDI 101 1 October 31st, 2014 07:58
FS: MK3 TDI Rocketchip Stag 2 ECU mazrik Private TDI Items for Sale/Wanted 0 August 29th, 2014 12:24
FS: Rocketchip stage 2+ mk3 ECU mastermechanic5 Private TDI Items for Sale/Wanted 7 July 11th, 2013 10:23
99.5 Rocketchip ECU RC2/3/3+ euro ECU For sale. turbocharged798 Private TDI Items for Sale/Wanted 6 June 23rd, 2012 09:45
Page generated in 0.12898 seconds with 11 queries
[Output: 83.85 Kb. compressed to 72.25 Kb. by saving 11.60 Kb. (13.83%)]
