Old August 9th, 2017, 06:39   #1
andrewjb
Default Rocketchip MK3 ECU turbo issues UK
Hi All,
I own a 1990 MK2 GTI with AHU engine conversion, the car has the following added to it:
AHU engine, ARP head studs, SAAB FMIC, PD130 turbo setup, .216 nozzles, straight though exhaust and downpipe, EGR delete.
The ECU has a stage 2 rocketchip chip on it, the chip was added when the old owner was running a hybrid PD150 turbo.
The car quite often goes into limp mode, not sure if its just the car requesting too much boost for the stock PD130 turbo to flow or if the turbo is on its way out.
I'm really struggling in the UK to find anybody who can re-tune this ECU.
Does anybody know how the Stage 2 rocketchip tune will work with a BV43 PD170 turbo and .216 nozzles?
Andrew
andrewjb is offline   Reply With Quote
Old August 9th, 2017, 07:35   #2
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Have you tried emailing Rocketchip directly?
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
schnellvw.com
GTiTDi is online now   Reply With Quote
Old August 9th, 2017, 09:53   #3
shortysclimbin
shortysclimbin's Avatar
I'm running a very similar setup with the the bv43 turbo and 11mm pump. I am working on fixing the little issues currently. you would need a new tune to fit either the vnt1749va (pd130 turbo) or the bv43 (Im using the CR turbo not pd170).
Honestly there is some smaller differences in the pd130 and pd150 turbos so I suspect your tune right now isn't optimized for the boost request vs. actual. Have you tried logging what you are seeing to see what the car is doing? what are the codes it throws when it goes into limp mode?
shortysclimbin is offline   Reply With Quote
Old August 9th, 2017, 14:24   #4
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
Where in the UK are you? If in the midlands I can help with getting some logs and working out what you need to do to resolve..
m1ketdi is offline   Reply With Quote
Old August 10th, 2017, 02:08   #5
andrewjb
MK fella. Doesn't throw any codes for limp mode.
Old August 10th, 2017, 02:09   #6
andrewjb
I was told the CR turbo wouldn't fit or at least wouldn't fit with the PD130 manifold.
Old August 11th, 2017, 09:09   #7
m1ketdi
TDI(s): Leon BKD
I'm up in Leamington Spa. Do you have vcds to log anyway?
Old August 24th, 2017, 02:45   #8
andrewjb
Just OBD Eleven
Old August 24th, 2017, 02:49   #9
andrewjb
I now have these error codes:
EGR is fully removed so that just needs mapping out, I lost the throttle a while ago, fitted a new brake pedal sensor but error has never gone away.
Guessing the 3rd error is for MAP sensor?
Old August 24th, 2017, 14:33   #10
m1ketdi
TDI(s): Leon BKD
MAP sensor Fault Looks like a wiring issue. Trace the wires back from the map to the ecu checking for damage. Also check each wire for shorts to ground or positive of the battery with a multimeter. And will likely be why the fault happens intermittently.
The brake pedal plausibility fault sounds like the sensors may not be working... Do you have both switches and a clutch switch. This thread may help.
http://forums.tdiclub.com/showthread.php?t=287699
Do you have obdeleven pro to log live data?
Old August 24th, 2017, 17:03   #11
jsrmonster
Veteran Member - TDIClub Enthusiast
jsrmonster's Avatar
The RC tunes come in many flavors for both variable vane and waste gate versions. What is your ecu pn# and RC version ? Get a screen pic of vagcom/vcds ecu module and let me know what you sw you have. Jeff
15 Golf SW DSG, 00Jetta 6spd race, 99.5Jetta Rocket ARL-PD150 6spd 2260, 2003.5 5.9L Cummins QCLB 4x4 Blue Monster, 00Passat1.8T, other tdi's: 97J, 98J, 99.5J2x, 00-C5 6spd - EFILive, HPTuner, Diablo Sport!
Never argue with an idiot.They will just bring you down to their level and beat you with experience.
The beatings will continue until the morale improves!
Good judgement comes from experience, and experience comes from bad judgement !
"DIESEL TUNING PROFESSIONAL" 1-5-3-6-2-4=;-)
jsrmonster is online now   Reply With Quote
Old August 29th, 2017, 01:30   #12
andrewjb
ECU is 028906021ED
S 1444 VW Sofware number
000002 Software revision
H s3PC EDC 15P
I took these off MPPS when I tried to read the ECU.
Old August 29th, 2017, 01:31   #13
andrewjb
I do have OBD Eleven Pro.
Map sensor is on the ECU.
Old August 29th, 2017, 02:12   #14
bhodgkiss
I'm just down the way in Brackley and do remapping
First thing I'd do is log boost and see how hard you're pushing the pd130 turbo
1.5 bar max is safe. You might be asking 1.8bar+ with a hybrid tune
Shame it's not a separate map sensor (it's built onto ecu)
I presume soldered on?
It may well be an upgrade 3bar MAP sensor if a hybrid pd150 has been run, although 10mm pump/0.216 nozzles wouldnt give enough fuel to need to run more than 1.5bar boost....
Has the ecu got sockets and chips? (most likely, otherwise the modified chips have been soldered back on)
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old August 29th, 2017, 03:51   #15
jsrmonster
jsrmonster's Avatar
That ED ecu supports oem Usa/ahu wastegate turbo. It is RC stage 3 and won't run right on your vnt-turbo based engine. It is socketed, but if you remap it with euro (vnt) afn110 firmware it will need the matching eeprom programmed also to work properly with immo deleted.
I offer this service every day. If you mix up wrong sw and hw you can expect problems. You can use a boostvalve to limit max boost at a minimum so you can drive it.
Jeff
Mk3 B4 1z / AHU - ECU / ECM + RocketChip Stage 2 vwsnaps Private TDI Items for Sale/Wanted 21 January 7th, 2015 14:32
ALH Caddy 9K1 turbo issues after playing with ecu's... poxxxy TDI 101 1 October 31st, 2014 06:58
FS: MK3 TDI Rocketchip Stag 2 ECU mazrik Private TDI Items for Sale/Wanted 0 August 29th, 2014 11:24
FS: Rocketchip stage 2+ mk3 ECU mastermechanic5 Private TDI Items for Sale/Wanted 7 July 11th, 2013 09:23
99.5 Rocketchip ECU RC2/3/3+ euro ECU For sale. turbocharged798 Private TDI Items for Sale/Wanted 6 June 23rd, 2012 08:45
Page generated in 0.19467 seconds with 11 queries
[Output: 126.07 Kb. compressed to 105.50 Kb. by saving 20.57 Kb. (16.32%)]
