Old August 4th, 2017, 20:33   #16
WrEkkED
WrEkkED's Avatar
Xman sells a 1756. I originally bought this turbo then changed my mind and went bigger. But its good to 210 bhp. May be a good option. Sopposedly does not get turbo creep like the 17/22 and has lower emp's as well, but flows mucj better and spools quickly.
2004 Jetta TDI Sport Edition
WrEkkED is offline   Reply With Quote
Old August 5th, 2017, 01:51   #17
mk1-83
Fuel Economy: 1:15
Thats because he upgrade turbine wheel .
And you can make large wheels in a small frame turbo this make things bad.
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old August 25th, 2017, 11:34   #18
faulknern
TDI(s): 2004 BEW
Thanks for the suggestion wrekked. I will inquire about that option as well.
faulknern is offline   Reply With Quote
Old August 28th, 2017, 23:14   #19
Nevada_TDI
Depending upon the desired use, not all large compressor wheels in small frame turbos are a bad thing: I live at 4600 feet elevation and the air here is quite thin; even a standard vnt-17 wouldn't like being pushed at 24 PSI (corrected) all day long when needed. My 56mm comp wheel in my vnt-15 compressor housing provides boost just off of idle and solidly without surge to redline. My Stage 4 tune is more of a Custom Stage 3+ tune producing somewhere around 160 HP and that is all the power I really want as I am not interested in breaking parts on a regular basis. Had my HP goals been somewhere in the 200 HP range, then the turbo I have would have been the wrong one for the application. Sometime long ago, Charlie commented that a 17/56 using a vnt-15 cold side could be a great turbo, but I am sure his comment was application specific as well.
_______________
2001 Jetta GL TDI, 35/15% Tint, Ventectomy, Catectomy, EGR-ectomy, Stage 4 TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old September 6th, 2017, 14:56   #20
turbovan+tdi
turbovan+tdi's Avatar
Running the same 17/56 as above at sea level, no surge, runs great!
Old September 6th, 2017, 23:07   #21
Nevada_TDI
I have not yet had the opportunity to take my Jetta down to sea level for a couple of days to see what she will do with a 24 PSI hot tune and all the fuel she will take. I will imagine at sea level she will likely spool even faster than she does now, and I don't quite know how that can be possible but I am sure ready to find out.
EDIT: the 17/22 (17/52) that originally came on the VW Transporters was known for surge issues simply due to the design of the snail and compressor wheel. It was for a work truck and the boost island wasn't really compatible for high performance applications. A vnt-17 with a 52 mm compressor wheel upgrade is an entirely different beast and is not prone to surge as I believe the A/R is a lot smaller than the A/R of a standard 17/22.
_______________
FS: VNT 17/22 Hybrid Turbo Set (BEW) strtshark Private TDI Items for Sale/Wanted 7 April 22nd, 2013 14:33
wtb: 17/22 hybrid for BEW (pd motor) GotEuroCorrado Private TDI Items for Sale/Wanted 0 October 5th, 2011 07:15
How much can I get with 1752 Milo0p TDI Power Enhancements 24 September 13th, 2009 09:02
gt 1752 passat hybrid sislianli TDI Power Enhancements 0 April 25th, 2009 16:36
wich hybrid do you recomend? 1752 or 1756 correcaminos TDI Power Enhancements 2 July 6th, 2007 03:17
Page generated in 0.12936 seconds with 11 queries
[Output: 76.57 Kb. compressed to 67.01 Kb. by saving 9.55 Kb. (12.48%)]
