Old July 3rd, 2017, 05:10   #1
dieselherb1
Default 09 CR engine manual into 06 Jetta PD auto
Have everything installed have issues with ECM not communicating with VCDS. Have Bentley and Mitchell Prodemand printouts. Am I adapting the ECM to ECM or reverse? Using 09 ECU with immo delete. Help Please!
Herb
dieselherb1 is offline   Reply With Quote
Old July 3rd, 2017, 05:12   #2
jimbote
jimbote's Avatar
does the car run ?
jimbote is online now   Reply With Quote
Old July 3rd, 2017, 11:37   #3
dieselherb1
No not yet
Old August 1st, 2017, 23:40   #4
dieselherb1
Still trying to get the wiring right
Old September 3rd, 2017, 05:02   #5
dieselherb1
Got all the wires swapped from 06 to 09 positions, still no power to ECM. #100 relay energizes for a second then off. Can turn engine over with key but no power to start?
Old September 9th, 2017, 08:52   #6
dieselherb1
Got the wires swapped around, engine trys to start but shuts down. I have a IMMO deleted ECU in the car(was on 09 engine) Friend told me it could be acc. pedal. So called dealer got part# for pedal, but I see it is used on gas cars as well. So is it for manual only? the car was a DSG part#1K1723503L. Any ideas?
Old September 19th, 2017, 20:46   #7
Syncrogreg
Hit me up if you want a ECU +harness that will run right away!
Instagram: boxeer_llc
Or boxeer.com
Cheers
Syncrogreg is offline   Reply With Quote
Old September 20th, 2017, 02:44   #8
jimbote
jimbote's Avatar
Or boxeer.com
Cheers
you need to register as a vendor
Old October 3rd, 2017, 05:43   #9
dieselherb1
WoW!!! prices!!!
Old October 6th, 2017, 06:07   #10
dieselherb1
Update. Got the engine started and running, still have a few wiring issues but it moves on its own. Big Thanks!!! to Matthunter on here he has done 2 swaps now. And Brian from Texas, more of a encourager. And to the others on here who said they would help, 000.
Old October 7th, 2017, 22:24   #11
Bobob729
TDI(s): Jetta
What ended up being wrong? Not the pedal? I'm matthunter just use a. Different name on here
Bobob729 is offline   Reply With Quote
Old October 13th, 2017, 17:20   #12
dieselherb1
I know Matt. Bad wire connector in T94 plug. Still chasing the wire rabbit. Now brake lite on all the time, fuel pump relay no signal. And turbo actuator is acting on its own
Old October 24th, 2017, 06:01   #13
dieselherb1
Turbo not boosting, looks like actuator is pushing vanes closed. Brake light on all the time.
09 CR swap into 06 PD car ECM issues dieselherb1 OBD Scanners 12 July 1st, 2017 04:31
WTT '09 Jetta Sportwagon dsg for '06 manual Gabe TDI Cars for Sale/Wanted 4 June 7th, 2015 16:12
'09 US-spec 140HP CR -> '09 EU-spec 170HP CR (in '06 body) maloosheck TDI Power Enhancements 20 January 13th, 2010 13:40
WTB: 06-09 Jetta TDI manual near Austin Tx BioJetta2001 TDI Cars for Sale/Wanted 0 August 11th, 2009 11:04
FT: my 06 Jetta pk2 manual for your 06+ Jetta AUTO ErikR TDI Cars for Sale/Wanted 4 May 12th, 2008 05:58
Page generated in 0.14489 seconds with 11 queries
[Output: 107.48 Kb. compressed to 89.84 Kb. by saving 17.64 Kb. (16.41%)]
