Old September 5th, 2017, 19:05   #61
CF-FZD
TDI(s): 03 Jetta
Transmission #1 and 2 have gone in the trash. Apparently the little Toyota G52 can't handle this much torque of a 27psi TDI.
I found my 3rd transmission of the summer for $250. A Toyota W58 from a 80's supra, I used the bell housing from the G52 cut the shifter hole a little and moved the trans crossmember back an inch. The sports car trans is geared quite a bit higher then the truck trans but it will have to do. I hope the W58 stays together better then the G52's did. I've put 100km on the W58 so far and 5th gear is noticeably taller.
02' Jetta TDI is the DD.
1966 Ford F100, crown vic suspension swap, ALH TDI. 11mm, GTB1756vk, .216, 3" exhaust, FMIC, Malone stage 5, Toyota 5 speed.
CF-FZD is offline   Reply With Quote
Old September 6th, 2017, 04:11   #62
Growler
Got Soot Vendor
Growler's Avatar
Lets hope this one lasts a little longer for you. do you think its a matter of the gearing in the trans not being compatible with the torque at such low RPMs? or are you just hammering on it and they are breaking from rough use?'
would a rear end ratio change help things perhaps?
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old September 6th, 2017, 05:13   #63
jimbote
jimbote's Avatar
the G series is a pretty weak trans, another option is a W59 from a tacoma ... a little stronger than the 56 but you probably won't need it now
Old September 6th, 2017, 13:49   #64
turbovan+tdi
turbovan+tdi's Avatar
Which gear is stripping out?
Old September 6th, 2017, 17:17   #65
Motohead1
Looks like 1st gear. Drag racing.
Motohead1 is offline   Reply With Quote
Old September 6th, 2017, 17:42   #66
jimbote
jimbote's Avatar
that's actually the input gear, first gear is father down the line ... however power flow travels through the input gears for all forward gears and reverse except fourth which bypasses the cluster entirely and goes straight through the mainshaft... this is why a car with a stripped input still pulls in fourth
Old September 6th, 2017, 17:47   #67
jimbote
jimbote's Avatar
you can't actually see first gear in the photos, it's just out of frame beside the straight cut set which is reverse and just beyond that is fifth
Old September 7th, 2017, 18:13   #68
Motohead1
Yep your right I was a little dyslexic looking at the gears.
2002 Ford Ranger FX4 VW 2.0L TDI Build JstWantoRide TDI Conversions 22 June 10th, 2015 08:40
1966 Volvo 122S wagon with a TDI and Toyota 5 speed Logdog TDI Conversions 71 March 11th, 2015 21:06
Saw it on CL 1966 VW BULLI T1 TRANSPORTER joelbert TDI Cars for Sale/Wanted 2 October 2nd, 2014 11:53
WTB: Engine build parts, ALH build, BHW pistons, Rosten Rods, Big stuff! 2000tdijettafast Private TDI Items for Sale/Wanted 2 February 24th, 2014 08:40
1966 beetle question sponsorships rwtags General VW Discussion 6 June 25th, 2010 10:24
Page generated in 0.14438 seconds with 11 queries
[Output: 89.86 Kb. compressed to 77.54 Kb. by saving 12.32 Kb. (13.71%)]
