Old March 31st, 2017, 07:08   #46
jimbote
jimbote's Avatar
Originally Posted by CF-FZD View Post
You like it..?
Please tell me you know of a super strong clutch that will help put the power to the ground. Toyota r150 trans.
love it ! .... as far as clutches go my current setup with a 10" ctx-107 pressure plate and dtx-136 disc has held up the best but it's started to slip under heavy load ... i'm now looking at the competition brand dual friction clutch as a replacement
Old March 31st, 2017, 07:11   #47
vtpsd
Fuel Economy: 45mpg avg
wow, looks like a ripper. Can't tell if your clutch is slipping or if that is wheelspin. Awesome work.
current: 03 jetta wagon (pp520, malone stg3, straight pipe), ford tractor with saab turbo, Snarling Audi 90q AHU swap (holset he211w, 32psi, race 520's)
past:11 second audi 90 20vt monster, 20vt swapped audi 90 winter beater, 10vt swapped 4kq with efi and many many other 5 cylinder audis, and a few 1.8tq's
vtpsd is offline   Reply With Quote
Old April 2nd, 2017, 08:56   #48
CF-FZD
TDI(s): 03 Jetta
Please post an update when you change the clutch out. I'm running a flywheel from a 22re that's been drilled to fit the VW crank. I haven't completed the brake in period (only 10-15km so far) so I really shouldn't be driving it hard.
What flywheel are you using and have you tried the Marlin crawler setup, the rock crawling guys say they are great but they don't have 300lb/ft of torque at 2400rpm like a big turbo TDI.
In my video I think it was part wheel spin on the dusty road and part clutch slip as it was in the first 5 min of driving on the clutch😳. I'll be good to it from now on.
02' Jetta TDI is the DD.
1966 Ford F100, crown vic suspension swap, ALH TDI. 11mm, GTB1756vk, .216, 3" exhaust, FMIC, Malone stage 5, Toyota 5 speed.
CF-FZD is offline   Reply With Quote
Old April 12th, 2017, 18:41   #49
CF-FZD
TDI(s): 03 Jetta
Truck is on the road now, I've put a few hundred trouble free kilometres on it and everything is working a expected. Fuel mileage was 9L/100 on the (166km) trip I checked while doing 110-115km/h with some stop and go traffic. It has more then enough power to move the truck down the road, it's much faster then my 02' Jetta with a 1.5 tune. So far I've had it doing 150km/h. The GTB1756 starts to spool at about 19-2000 and hits 27psi by 2400rpm it keeps pulling right past 4000. I wouldn't change a thing with the performance. To my surprise the clutch I have is holding just fine, it's just a bit grabby when taking off with low rpm. It holds well enough to spin the tires in first and second on dry pavement or a full boost pull up a hill in 5th.
The biggest downfall so far is the exhaust and engine noise. It currently has 3" strait off the turbo, a 4" long 3" fleet pipe then a 2 bolt flange just aft of the firewall. Then about 4' of 3" pipe and a bend then exits just ahead of the back right tire. I have enough pipe and a bend to make another back half. I'm on the hunt for a 3" free flowing muffler that will quiet down the drown. The floor of the truck already has some insulation and full carpet.
The truck had a sturdy rear bumper so I decided to make it into a trailer hitch. I bought a receiver and a 2" ID hitch tube. Cut the hole and welded it in. When the hitch isn't in use I can leave it in but facing the opposite way out of site under the truck. I'll limit towing to 3500lbs or so.
Old April 12th, 2017, 19:08   #50
jimbote
jimbote's Avatar
very cool .... thanks for the update... does the turbo feel laggy at all ?
Old April 12th, 2017, 19:53   #51
Motohead1
Nice. What rear gear are you running?
Motohead1 is online now   Reply With Quote
Old April 15th, 2017, 04:53   #52
CF-FZD
TDI(s): 03 Jetta
Not at all it spools as fast as my stock turbo ALH Jetta (Malone 1.5). The difference between the two is I may have to drop a gear in the truck where I may have stayed in 3rd in the car. It may all be in my head but in the car I'll turn onto my street and climb a hill, in the car I'll start the pull in 3rd at 17-1800 but the truck needs the drop to second. It will accelerate in 3rd but takes a few seconds to spool and puts out a lot of smoke before the boost hits. I tend to just drop to 2nd and it pulls away smoke free. Other factors may be the truck is 3-400lbs heavier then the Jetta, the gear ratio in the trans and diff are different and I probably take the corner slightly faster in the car. If I give the truck full throttle in 2nd on a corner it will go sideways and that's not a good idea when I'm on my own street. In a strait line it will spin the Goodyear Eagle GT tires in first and second without using the clutch. I have absolutely no complaints about the power and have no desire to squeeze more out of the engine. That said I may have found a Ford Coyote 5.0 and a 6 speed manual from a 14' mustang for a good price. If I buy it I'll be doing another engine swap next winter.
The gearing in the truck 9" rear is 3.31/1 I think. It has 235/55/17 tires and revs about 2400 at 100km/h (62mph). 3800 @ 147km/h (90mph). I may try to find a set or 235/60 or 253/65 tires for the rear and see how it does. The speeds were done with the iphone gps.
Old April 22nd, 2017, 06:39   #53
CF-FZD
TDI(s): 03 Jetta
A little towing action with the TDI Ford. I plucked my boat (bayliner 2651) from the farm where I store it to my house to get it ready for water. I think it weighs about 5500 plus the 1500 trailer about 7000 pounds. The truck is #3400 on its own 10k in all. 2400rpm in 4th gear, 80km/h, 10psi boost it would sit at 400*C EGT and 500-600 degrees C if I held 80 up any hills. Climbing away from a stop sign up a hill was interesting, trying not to spin the tires at first then a steady 600 on the EGT in first gear at 3000rpm. Plenty of power to go faster on level ground but it was a big load for the truck.
Old April 22nd, 2017, 07:46   #54
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
...Wow!
1.9ZOOK is offline   Reply With Quote
Old April 22nd, 2017, 19:20   #55
Motohead1
Thats great. Love to have seen the faces of people as you passed by.
Old May 6th, 2017, 21:23   #56
mjensen
Wow! Better than I would have expected for mileage! Looks great and sounds great! Trying to do the same thing in a 83 f150. Gives me some push! Good job!
mjensen is offline   Reply With Quote
Old May 22nd, 2017, 17:06   #57
CF-FZD
TDI(s): 03 Jetta
The old truck goes down the road rather well
https://youtu.be/nI-nUh8XJzw
Old May 22nd, 2017, 17:19   #58
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Very Nice!
Old May 22nd, 2017, 19:44   #59
jimbote
jimbote's Avatar
well done vid .... a few years ago folks didn't think a lil' 1.9 would even tote a 4x4 yota with ease, now seeing them in full size trucks and mid size pigs like durangos and dakotas ... lot to be said for power density
Old May 22nd, 2017, 20:27   #60
Motohead1
Man thats a clean truck. Its hard for dust to settle on things at 100MPH.
2002 Ford Ranger FX4 VW 2.0L TDI Build JstWantoRide TDI Conversions 22 June 10th, 2015 09:40
1966 Volvo 122S wagon with a TDI and Toyota 5 speed Logdog TDI Conversions 71 March 11th, 2015 22:06
Saw it on CL 1966 VW BULLI T1 TRANSPORTER joelbert TDI Cars for Sale/Wanted 2 October 2nd, 2014 12:53
WTB: Engine build parts, ALH build, BHW pistons, Rosten Rods, Big stuff! 2000tdijettafast Private TDI Items for Sale/Wanted 2 February 24th, 2014 09:40
1966 beetle question sponsorships rwtags General VW Discussion 6 June 25th, 2010 11:24
Page generated in 0.20377 seconds with 11 queries
[Output: 128.05 Kb. compressed to 106.94 Kb. by saving 21.12 Kb. (16.49%)]
