Old March 8th, 2017, 12:17   #31
smelly621
Sorry for my question on the hose routing - it was an effect of the engine cover and the angle that made it look like it may be switched.
Hottest point is coming out of the back of the head - so may as well measure close to there.
smelly621 is offline   Reply With Quote
Old March 8th, 2017, 12:41   #32
GoFaster
Moderator at Large
Just to make sure we are on the same page ... The TDI engine is not "reverse flow", the coolant comes out the top/rear (top/right, in this case) of the head as described. The thing that could seem odd to someone used to how traditional cooling systems are arranged is that the thermostat is at the water pump housing (bottom/front/left in this case) and it regulates the inlet temperature of the water pump.
You need to have the bypass loop connected - the flow through the heater core, which also goes out the top of the engine and returns back in at the smaller connection at the thermostat/water pump housing.
The spherical bottle is part of the pressurized part of the system.
If you hook it all up the way it was in the original VW installation and use as many of the original bits and pieces as possible (including the coolant bottle but obviously the radiator will be different), it will be fine.
Best spot for a coolant temperature gauge sender is the outlet from the cylinder head (top/rear/right). Best spot for a cooling fan thermoswitch is in the return flow from the bottom of the radiator to the water pump and have it set a little below the thermostat opening temperature. That way the cooling fan will only come on when it really has to, i.e. when you are actually stopped with no air flow. When you are normally driving, the return from the radiator will be well below the engine temperature.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old March 9th, 2017, 13:55   #33
smelly621
Constant flow through the heater core is not needed, there is continual flow through the oil/coolant heat exchanger.
Same goes for the coolant bottle - it can be deleted and a normal pressurized radiator cap and overflow bottle can be used. Working just fine this way for a number of conversions on here.
Old March 16th, 2017, 13:08   #34
CF-FZD
TDI(s): 03 Jetta
Up and running,
https://youtu.be/IBdEy_fgeZ8
https://youtu.be/cXZjm9RjTew
CF-FZD is offline   Reply With Quote
Old March 16th, 2017, 15:16   #35
turbobrick240
turbobrick240's Avatar
Awesome! Looks great, sounds great- really like what you did with the instrument panel. Nice job!
Old March 16th, 2017, 17:20   #36
Motohead1
Nice. Are you using a lift pump? I would put some clear fuel line on the inlet and outlet lines to make sure your hickup is not air in the fuel related.
Motohead1 is offline   Reply With Quote
Old March 22nd, 2017, 13:42   #37
CF-FZD
TDI(s): 03 Jetta
First drive around the block
https://youtu.be/ZEpBGwm-gnk
It still needs some adjustments to the tune to reduce smoke.
Old March 22nd, 2017, 17:22   #38
Owain@malonetuning
Nice!!! Where's your IQ set? That's some pretty heavy smoke. Fire some logs my way when you get a chance, keen to see this thing running right.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old March 22nd, 2017, 17:44   #39
CF-FZD
TDI(s): 03 Jetta
I have absolutely no idea where the IQ is set. Justin said he was going to plug it in and adjust it. It idles a bit rough and has a misfire now and then when it's cold. We will be in touch.
Old March 22nd, 2017, 19:06   #40
Motohead1
Man looks like a fun ride for sure.
Old March 31st, 2017, 04:37   #41
jimbote
jimbote's Avatar
sounds like your clutch is slipping or is that tire slip ?
jimbote is online now   Reply With Quote
Old March 31st, 2017, 04:38   #42
CF-FZD
TDI(s): 03 Jetta
First time at the diesel pump.
I look forward to driving it more and finding out what kind of mileage it gets.
Old March 31st, 2017, 04:39   #43
jimbote
jimbote's Avatar
this^^ no bypass required
Old March 31st, 2017, 04:40   #44
jimbote
jimbote's Avatar
looks awesome
Old March 31st, 2017, 05:30   #45
CF-FZD
TDI(s): 03 Jetta
Originally Posted by jimbote View Post
looks awesome
You like it..?
Please tell me you know of a super strong clutch that will help put the power to the ground. Toyota r150 trans.
2002 Ford Ranger FX4 VW 2.0L TDI Build JstWantoRide TDI Conversions 22 June 10th, 2015 08:40
1966 Volvo 122S wagon with a TDI and Toyota 5 speed Logdog TDI Conversions 71 March 11th, 2015 21:06
Saw it on CL 1966 VW BULLI T1 TRANSPORTER joelbert TDI Cars for Sale/Wanted 2 October 2nd, 2014 11:53
WTB: Engine build parts, ALH build, BHW pistons, Rosten Rods, Big stuff! 2000tdijettafast Private TDI Items for Sale/Wanted 2 February 24th, 2014 08:40
1966 beetle question sponsorships rwtags General VW Discussion 6 June 25th, 2010 10:24
Page generated in 0.15057 seconds with 11 queries
[Output: 124.22 Kb. compressed to 103.64 Kb. by saving 20.58 Kb. (16.57%)]
