Old January 25th, 2017, 04:09   #1
mk1-83
Fuel Economy: 1:15
Default electronic actuator bmw 300hz pwm
Hello,
Im surging for a bmw actuator that works on 300hz pwm
all that im have tested working on 140hz.
mine ecu have a 300hz pwm as n75
So if there is anyone nows the number of the actuator theat works on 300hz im very pleased.
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old January 25th, 2017, 13:55   #2
hatemi
Bmw works with 300hz. As do Volvo 2056vl actuator. But you can change the frequency in the software. We managed to get audi 2.5tdi v6 ecu converted to 300hz from original 250hz last weekend.
www.tdituning.fi
hatemi is offline   Reply With Quote
Old January 26th, 2017, 10:08   #3
mk1-83
Fuel Economy: 1:15
Hi I found the 6nw009228 works 300hz I tested it on mine 18p ecu.
https://www.facebook.com/bernard.van...85381785018524
Yes the ferq must be in the software but really hard to find so whe did easy way.
Im very pleased where sits the freq in software
Lupo 1.9 tdi
300+ HP 500 nm
Old April 8th, 2017, 06:14   #4
B3n
B3n's Avatar
I also have a BMW actuator working with EDC17 N75. Output test in VCDS is working. So this seems to be easy if the right actuator with 300hz is used.
Now I have the problem nobody of my known tuners has experience with electronic actuators. They are all doing vacuum conversion. I want to use the electronic actuator which comes with my new turbo.
How hard is it to adapt the EDC17 maps for an electronic actuator? Or is it maybe possible to copy the maps from the EDC17 where the turbo was fitted originally?
B3n is offline   Reply With Quote
Old April 8th, 2017, 06:58   #5
mk1-83
Fuel Economy: 1:15
ask Rub87 about this
Lupo 1.9 tdi
300+ HP 500 nm
Old April 8th, 2017, 14:41   #6
Rub87
Id say if the actuator has a feedback its pretty easy, hook it up to original feedback wire and calibrate voltages
If it does not its I think just a matter of disabling the position feedback in the ecu. I never did this as I like a system with feedback a lot, but I guess a lot of other 'tuners' do this frequently when a different than stock turbo is used and they are too lazy/incapable of setting the actuator up correctly.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old April 8th, 2017, 18:59   #7
B3n
B3n's Avatar
OK, thanks. I'll try that next week when i'm back home. I hope 6nw009228 has some feedback output. There was no info on google. I'll measure pin 3 and 5.
VW Passat B7 Variant Highline 2.0 CR-TDI CFGB/PDT 2011 KM: 275,000
Old September 10th, 2017, 01:55   #8
B3n
B3n's Avatar
I was trying to find a position output on this actuator but it doesn't seem it has one. there is something like 9 volts at pin 3 and 5 when position is at 0%.
It also seems not very tolerant with the input voltage. i could get the actuator only working by using an external 12v power adapter. in the car with a battery charger connected there are more than 13 volts at the N75 + cable. Connected to this the actuator cannot be controlled. in my opinion there needs to be some additional electronics to make the actuator work with edc17.
Electronic Actuator Pinout prowler0 TDI Power Enhancements 37 April 18th, 2016 19:19
GTB1756VK electronic actuator ONLY poisas Private TDI Items for Sale/Wanted 0 January 30th, 2015 11:58
Wtb gtb2260vk w/ electronic actuator. PIERTEK Private TDI Items for Sale/Wanted 2 September 26th, 2014 12:32
WTB: electronic actuator greengeeker Private TDI Items for Sale/Wanted 2 February 9th, 2014 09:46
Any way to use the electronic turbo actuator on an ALH? mannytranny TDI Power Enhancements 10 July 27th, 2009 10:32
Page generated in 0.12768 seconds with 11 queries
[Output: 85.37 Kb. compressed to 73.41 Kb. by saving 11.96 Kb. (14.01%)]
